    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 379.9k Views 71 Watching
      @hsjzyangbin said:
      @tig said:
      Here's an EEbyRails new V2 example of making a 'flat-topped' sinuous roof barrel, with one end arched and the other angular, in two halves...[attachment=2:3i3yr7t7]<!-- ia2 -->EEbyRailsV2_FlatTop.png<!-- ia2 -->[/attachment:3i3yr7t7]
      HI,TIG,This is way more than an improvement ,But it does not get the results I wanted, it seems that these two Profiles control only two rails of the endpoint, I want the result is the same curvature and hope to improve it, above are my small suggesting on V2 versions thanks again
      It is doing what you tell it.
      Picking the Profile twice will give a different result.
      Try making half rails (~semicircle) and two concave profiles at its ends, then copy/mirror the mesh and combine into one group...
      It the rail is circular use my Lathe.rb tool on its center with a profile on the circumference and at 360 degree revolution.
        driven
        Thanks for all of the permutation testing...
        I'm unclear about this one missing small triangle - did EEbyR miss it out or did you ?
        • N Offline
          notareal
          Seriously sketchstatic script... I can't imagine what's the next step for this!
            driven
            @tig said:
            driven
            My pleasure, I know there's a few people needing very accurate meshes for different things and quantifying what affects the outcome adds POL to your excellent script. {Principle of Least Surprise~ to quote Kirril}.
            My contribution is minor compared to the effort you put in, and I don't write scripts (yet) so the least I can do is pass on some learning (and point out my errors).
            I deleted the the inner edge of the wayward point (instead of fixing it) to keep tabs on when it did and didn't appear during my testing, and then decided it was tidier to leave it exposed then to fix and label it, I don't need to use the drawing.
            why it's happened? I initially used 'paste in place' to add the top line sans surface for the top rail, later on I used 'paste in place' for the whole profile, to use it as the top rail. I was using group layers to keep everything separate, but when I did my final cleanup I had two identical ungrouped but separate polylines occupying the same space on my drawing layer, so maybe it was there all along and SU got confused by that, I certainly am...
            I take it the file link works?
              hsjzyangbin
              Here's a brief tut' on making Lathed shapes with EEbyRv2 - if you want a pure 'Lathed' Vase then use my Lathe.rb Tool - [Type D] instead... If the lathed 'rail' path isn't circular then make it an arc initially and then scale the mesh group later to distort it to suit ?EEbyRv2_and_Lathing.pngEEbyRv2_and_Lathing.skp
              • H Offline
                hsjzyangbin
                Thank you TIG for detailed answers, which helps to me , I am now able to make alot of mesh surface, SKETCHUP will eventually develop into a more powerful software than 3DMAX step by step,TIANK Again
                • H Offline
                  hsjzyangbin
                  I think Extrude Edges by Rails had replaced Extrude Edges by edges ,SO I use Extrude Edges by Rails only ,did you? ➑
                  • U Offline
                    Ultimatez 32
                    Hip-hip hooray TIG! Finally a patch tool for sketchup! thanks again TIG. πŸ‘
                    Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                      EEbyRails does most of what EEbyEdges can do ... but with EEbyEdges you can make groups of two sets of separate edges, arcs etc and they'll mesh with gaps etc - though that mesh is limited to one rail and one profile...
                      EEbyRails won't replace Lathe as the method and results are quite different...
                        red_shift
                        Any idea why on a MAC (os 10.6.2) and SU 7.1.58 the EEbyR plugin runs successfully then causes SU to go into a stall and then crash?
                          driven
                          no, but I could test your 4 profiles on 10.5.8 and see if it's a 10.6 issue, if you want.
                          at first I had problems which I now think were caused by using one of Kirrel's or one of Chris's tool earlier in the session, since then I've been restarting once I've done the curve construction and haven't had any problems.
                            red_shift
                            Same thing happens with Loft tool...it runs..then SU goes into a full CPU use and eventually crashes...
                              How many profiles/rails/faces are reported in the VCB area ?
                              Over ~2000 faces will take a while to format...
                                red_shift
                                It's something about the model as a whole...when I copy the rails and profile into a new SU file it works fine..so for now I'll do that and import the result back in...
                                  Geometry sometimes gets muddled in the database.
                                  Have you trued Model Info > Statistics > Fix Problems ?
                                  Have you tried grouping a rail and immediately exploding it ?
                                  Or Edit>Cut'ting a rail and Edit>Paste-in-Place in the same Model?
                                  Or Edit>Copy a rail and the Erase it and immediately Edit>Paste-in-Place in the same Model?
                                  Or rail Select and right-click Explode Curve and immediately Welding it again ?
                                  These sometimes fix the
                                  • H Offline
                                    hsjzyangbin
                                    I chose the semi-circle as a profiles,I finally get the same effects of lathe
                                    here is test:
                                    • H Offline
                                      hsjzyangbin
                                      If 2face +2 path can do it, it would be a pioneering
                                      • H Offline
                                        hsjzyangbin
                                        Further to say, I chose as a semi-circular and semi-rectangular as their path, get the desired effect of lathe will not be able to do
                                          driven
                                          the curtain draws open on a New Year, have a good one
                                            Extrude edges by rail v2 is better than Soap Skin Bubble! πŸ˜‰
                                            Drawing Mesh is more regular!
                                            That will be better for the UV!
                                            • 19
                                            • 20
                                            • 8 / 20
