    Can I have this for SketchUp Please?
    extensions
    11 Posts 7 Posters 2.7k Views 7 Watching
    • KrisidiousK Offline
      Krisidious
      Power Nurbs Pro
      http://www.npowersoftware.com/nurbs/pnoverview.htm
      By: Kristoff Rand
        johnsenior1973
        A $1,000 plugin for a $3,500 piece of software. Would next week be quick enough?
          You have a beginning with the Extrude Edges By Rail! by TIG ☀
          And seems "box modeling" is some different than Nurbs modeling 😉
            Krisidious
            nice Pilou... Tig always delivers... thanks for the tip...
            By: Kristoff Rand
            • charly2008C Offline
              charly2008
              I looked many times at many such presentations of 3D programs. Everything shown seems as if it were very easy. First in practice, you will experience how long the learning curve is.
              Karlheinz
                Krisidious
                thanks Pilou, this is exactly what I wanted... TIG you rock buddy and you know it!
                here's what I was able to lay down last night while learning.
                I've also been using the power nurbs pro and while it is somewhat difficult, it's a very powerful organic modeling tool... the steps needed to perform just one rail are so convoluted that it takes away the pleasure of modeling.
                while TIG's Edges and Rails are simple, fast and intuitive... modeling organics is fun again... and I can stay in SketchUp.
                COT with Tig's Extrude Edges By Rail!
                By: Kristoff Rand
                  Krisidious
                  hey just wanted to drop an update on my project and thank you guys again for the great plug and the help finding it...
                  By: Kristoff Rand
                  • soloS Offline
                    Looking great Kris.
                      kwistenbiebel
                      Great results Kris!
                      I haven't had the time to really dig into the edges by rail plugin but will try it out next few days...
                      Any tricks to share to get us going?
                        Krisidious
                        it's all in TIGs description... the key is to control the number of vertexes on each rail try to keep them either the same number or divisible by it's self... and you can do this by converting any type of line into a polyline converter... then sit back and let it do it's magic...
                        warning: fine lines with tons of vertex points makes for a long build time...
                        By: Kristoff Rand
                        • TIGT Online
                          EEbyRails v2 has been optimized so the number of segments in rails/profiles isn't so critical BUT for the 'smoothest' meshes use the same number of segments in each pair of rails/profile, or at least multiples (20+10 say)
                          Version 2 also has a final 'melding-profile' option so you can control the pairs of sides in a mesh - both rails and profiles, so that all edges will 'mesh' with adjoining surfaces... get it here http://forums.sketchucation.com/viewtopic.php?p=201286#p201286
