    SU7.1 OSX camera aspect ratio vs. export 2D
    26 Posts 6 Posters 6.4k Views 6 Watching
    • jeff hammondJ Offline
      @thomthom said:
      What I wonder SKindigo do is that it might not properly reset the aspect ratio - but instead matches the camera aspect ratio tot he SU viewport ratio. After you use SKindigo to reset, what happens if you resize the SU window?
      everything works as expected afterwards..
      i think whaat did something with setting the aspect ratio and not the resetting of it?
      if i use skindigo to set the aspect ratio then reset via the ruby line using 'Sketchup.active_model.active_view.camera.aspect_ratio=0.0', the model will then zoom out.. i can set the aspect ratio via skindgo then reset using a method other than skindigo and the SU view will infact continue to zoom out
      fwiw, in skindigo, it's not asking for an aspect ratio per se.. it's asking for render output dimensions in pixel size (1024x768 etc.).. the grey bars do appear however and resetting with rick's ruby etc does clear the bars.
        I think I'll have to have a look at Skindigo. sounds like it's correcting SU's odd behaviour. I'm qurious to study the other camera properties to see what's going on.
        So when you set SKindigo's render output to 1024x768, then Sketchup.active_model.active_view.camera.aspect_ratio returns 1.3333, right?
          correct
          • JD HillJ Offline
            JD Hill
            Update: this bug is still present in SketchUp 8.
            Developer - Bella Render
              but not in 8.0.481 πŸ˜„
              update
                driven
                yes it works...
                One down,
                but it handles, xray oddly when exporting tiff.... with transparency on...
                • 2 / 2
