    Final streetscape - sketchup, twilight, photoshop
    66 Posts 16 Posters 13.8k Views 16 Watching
    • olisheaO Offline
      olishea
      in reality the gradient isn't so steep. so no need for a landing or anything in the real proposal. the topo survey wasn't very good so my model terrain isn't amazing. this was an absolute biatch of a model to make-and the texturing was just so intense. more images to come.....
      i really wanna play with podium version 2....but i gotta get this out of the way 😡
      no worries d12dozr 👍 😆
      oli
        sepo
        We do not have ADA... In England access is controlled by Building Regulations and DDA. It is not necessery to have access at every point. I presume there is access to properties from the carpark and/or from the pavement higher up.
        Renders are nice ...bit saturated for my taste and slightly dark ...but still nice. Gabions are cool btw.
        • olisheaO Offline
          olishea
          thanks Sid!!
          yeah there is level access to all houses. front and back. lots of provision for disabled access....but yeah like you say Sid, access is not required everywhere.
          i think architect did a great job to be honest. remember these are council houses!!!
          I agree about saturation sid....sometimes you need someone else to look at it, thank you. ive updated original.
          still working away........ 😡
          oli
            Nice work Oli 👍
            Are these houses or flats? Either way, it's a funky housing design that'll look great when developed.
            • olisheaO Offline
              olishea
              council houses. or association housing....whatever you wanna call it. the form and materiality takes influence from the industrial context-saw tooth roof mills etc, north lights (oldham, greater manchester, uk).
              i think it'll really improve the lives of the people who live there ☀
              this is what St Mary's estate looks like at the moment (neighbouring estate).
              oli
              • olisheaO Offline
                olishea
                and wtf man
                "Oh, it not personal, but I absolutely abhor gabion baskets in any way, shape or form."
                this isn't even constructive... personal taste means nothing in this game. what would you suggest?.....a big brick wall? gabions were chosen for visual lightness and the fact that plants can grow from them further softening their appearance. gabion material is reclaimed too so its a great choice IMO
                oli
                  dylan
                  I love the architecture and I love the render.
                  The thing that really stands out to me and in a good way, is just how good the road looks!
                  Is that and image you have used Oli?
                  http://dmdarchitecture.co.uk/
                  • olisheaO Offline
                    olishea
                    im so glad somebody finally noticed!! I spent a lot of time getting the road right! I adapted a texture from cg textures.com. its as close to a typical british road as I could make! I made a bumpmap for it too and applied a rough stone template in twilight. I got the curb texture from this forum and projected it over the curb.
                    I made most of the textures so if you would like any (including bumps) let me know and I will post them. Got higher res version of road texture too if you want it.
                    oli
                      dylan
                      I would love the road texture and bump Oli.
                      Also the kerb if possible too.
                        sepo
                        Road texture would be quite nice to have.
                        • olisheaO Offline
                          olishea
                          PM me your email guys and I'll send it to you. its too large and its not worth reducing.
                          i'll post a photobucket version in meantime here:
                          dylan you can use the kerb texture itself as a bump map in the twilight bump channel.
                          http://i654.photobucket.com/albums/uu269/olishea/Roads0021_L.jpg
                          http://i654.photobucket.com/albums/uu269/olishea/Roads0021_L_bumpmap.jpg
                          here is kerb texture:
                          http://forums.sketchucation.com/viewtopic.php?f=40&t=22057&p=194908&hilit=side+walk#p194908
                          oli
                          • olisheaO Offline
                            olishea
                            here are material settings (to rough stone template)
                            oli
                              rickgraham
                              @olishea said:
                              and wtf man
                              Sorry, but it is from personal (mis) use here in the states. The wires in gabions have a tendency to break and then you have these nice pointy wires that can cause problems. Yours might be completely different gabions that what I am used to here in the states. We use them at stream edges. I am a proponent for natural scapes ( take a look at http://www.wildlandhydrology.com/). So if you are asking for an alternative within those parameters, a vertical green wall might work well.
                              Again, this was not meant as a personal attack - honest.
                              Rick
                              • RichardR Offline
                                Richard
                                Man I love Gabions in any shape or form! We use tham a lot here without any structural failure of the mesh!
                                Though in Oli's case though I like them I would like to see a material break every now and then!
                                Nice work by the way Oli!!!! My only crit would be as someone else suggested the colours are a bit saturated and the grass could use some work. And there are a lot of people for a simple street scene IMHO!!
                                Those ramps give me the jitters a bit though, nice wide steps are so much more appealing.
                                As I said though, great work! I didn't really expect less!
                                [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                                • olisheaO Offline
                                  olishea
                                  Thanks for the comments Richard, always welcome and helpful.
                                  The architect wanted more people in the scenes but I secretly deleted them haha!
                                  I keep the colours a bit saturated for printing because the printer is always dull.
                                  Rick: no worries pal
                                  Here are the two other images. I rushed the PP on these so please forgive any mistakes! And don't slag the car off because its identical to mine, thanks to majid for the car paint!
                                  Cheers
                                  http://i654.photobucket.com/albums/uu269/olishea/23_final_small.jpg
                                  http://i654.photobucket.com/albums/uu269/olishea/25_final.jpg
                                  oli
                                  • olisheaO Offline
                                    olishea
                                    This is with Podium Version 2 Beta!! Materials only took 5 minutes to setup and this render took only 40 mins as opposed to 5-10 hour unbiased.
                                    I removed the trees because the current beta doesn't render dirty PNGs too well, but the team is working on it I hear.
                                    Little bit of photshop, but generally all Podium version 2! the colours are lovely compared to the previous podium.
                                    http://i654.photobucket.com/albums/uu269/olishea/v2jpg.jpg
                                    oli
                                      dylan
                                      Agree about the Podium colours, they really work well.
                                      Just needs a better glass reflection and it will make a big difference imo.
                                      • FrederikF Offline
                                        Frederik
                                        Perhaps I shouldn't comment on this, but I really can't see the huge difference you guy's can... 😕
                                        Cheers
                                        Kim Frederik
                                          meak
                                          bravo,
                                          pretty light and textures.
                                          lovely ambience.
                                            kwistenbiebel
                                            I find the architecture quite interesting....
                                            and you seem to visualise the idea quite well. Nice renders.
                                            The Podium v 2.0 (beta) colors are indeed very nice. I am looking forward at the Christmas break to get into the new render engine.
                                            The Twilight renders are nice as well. Any pure Physical sky shots?
                                            • 1 / 4
