    Final streetscape - sketchup, twilight, photoshop
    66 Posts 16 Posters 12.8k Views 16 Watching
      sepo
      We do not have ADA... In England access is controlled by Building Regulations and DDA. It is not necessery to have access at every point. I presume there is access to properties from the carpark and/or from the pavement higher up.
      Renders are nice ...bit saturated for my taste and slightly dark ...but still nice. Gabions are cool btw.
      • olisheaO Offline
        olishea
        thanks Sid!!
        yeah there is level access to all houses. front and back. lots of provision for disabled access....but yeah like you say Sid, access is not required everywhere.
        i think architect did a great job to be honest. remember these are council houses!!!
        I agree about saturation sid....sometimes you need someone else to look at it, thank you. ive updated original.
        still working away........ 😡
        oli
          Nice work Oli 👍
          Are these houses or flats? Either way, it's a funky housing design that'll look great when developed.
          • olisheaO Offline
            olishea
            council houses. or association housing....whatever you wanna call it. the form and materiality takes influence from the industrial context-saw tooth roof mills etc, north lights (oldham, greater manchester, uk).
            i think it'll really improve the lives of the people who live there ☀
            this is what St Mary's estate looks like at the moment (neighbouring estate).
            oli
            • olisheaO Offline
              olishea
              and wtf man
              "Oh, it not personal, but I absolutely abhor gabion baskets in any way, shape or form."
              this isn't even constructive... personal taste means nothing in this game. what would you suggest?.....a big brick wall? gabions were chosen for visual lightness and the fact that plants can grow from them further softening their appearance. gabion material is reclaimed too so its a great choice IMO
              oli
                dylan
                I love the architecture and I love the render.
                The thing that really stands out to me and in a good way, is just how good the road looks!
                Is that and image you have used Oli?
                http://dmdarchitecture.co.uk/
                • olisheaO Offline
                  olishea
                  im so glad somebody finally noticed!! I spent a lot of time getting the road right! I adapted a texture from cg textures.com. its as close to a typical british road as I could make! I made a bumpmap for it too and applied a rough stone template in twilight. I got the curb texture from this forum and projected it over the curb.
                  I made most of the textures so if you would like any (including bumps) let me know and I will post them. Got higher res version of road texture too if you want it.
                  oli
                    dylan
                    I would love the road texture and bump Oli.
                    Also the kerb if possible too.
                      sepo
                      Road texture would be quite nice to have.
                      • olisheaO Offline
                        olishea
                        PM me your email guys and I'll send it to you. its too large and its not worth reducing.
                        i'll post a photobucket version in meantime here:
                        dylan you can use the kerb texture itself as a bump map in the twilight bump channel.
                        http://i654.photobucket.com/albums/uu269/olishea/Roads0021_L.jpg
                        http://i654.photobucket.com/albums/uu269/olishea/Roads0021_L_bumpmap.jpg
                        here is kerb texture:
                        http://forums.sketchucation.com/viewtopic.php?f=40&t=22057&p=194908&hilit=side+walk#p194908
                        oli
                        • olisheaO Offline
                          olishea
                          here are material settings (to rough stone template)
                          oli
                            rickgraham
                            @olishea said:
                            and wtf man
                            Sorry, but it is from personal (mis) use here in the states. The wires in gabions have a tendency to break and then you have these nice pointy wires that can cause problems. Yours might be completely different gabions that what I am used to here in the states. We use them at stream edges. I am a proponent for natural scapes ( take a look at http://www.wildlandhydrology.com/). So if you are asking for an alternative within those parameters, a vertical green wall might work well.
                            Again, this was not meant as a personal attack - honest.
                            Rick
                            • RichardR Offline
                              Richard
                              Man I love Gabions in any shape or form! We use tham a lot here without any structural failure of the mesh!
                              Though in Oli's case though I like them I would like to see a material break every now and then!
                              Nice work by the way Oli!!!! My only crit would be as someone else suggested the colours are a bit saturated and the grass could use some work. And there are a lot of people for a simple street scene IMHO!!
                              Those ramps give me the jitters a bit though, nice wide steps are so much more appealing.
                              As I said though, great work! I didn't really expect less!
                              BUILTBRAND.COM.AU
                              • olisheaO Offline
                                olishea
                                Thanks for the comments Richard, always welcome and helpful.
                                The architect wanted more people in the scenes but I secretly deleted them haha!
                                I keep the colours a bit saturated for printing because the printer is always dull.
                                Rick: no worries pal
                                Here are the two other images. I rushed the PP on these so please forgive any mistakes! And don't slag the car off because its identical to mine, thanks to majid for the car paint!
                                Cheers
                                http://i654.photobucket.com/albums/uu269/olishea/23_final_small.jpg
                                http://i654.photobucket.com/albums/uu269/olishea/25_final.jpg
                                oli
                                • olisheaO Offline
                                  olishea
                                  This is with Podium Version 2 Beta!! Materials only took 5 minutes to setup and this render took only 40 mins as opposed to 5-10 hour unbiased.
                                  I removed the trees because the current beta doesn't render dirty PNGs too well, but the team is working on it I hear.
                                  Little bit of photshop, but generally all Podium version 2! the colours are lovely compared to the previous podium.
                                  http://i654.photobucket.com/albums/uu269/olishea/v2jpg.jpg
                                  oli
                                    dylan
                                    Agree about the Podium colours, they really work well.
                                    Just needs a better glass reflection and it will make a big difference imo.
                                    • FrederikF Offline
                                      Frederik
                                      Perhaps I shouldn't comment on this, but I really can't see the huge difference you guy's can... 😕
                                      Cheers
                                      Kim Frederik
                                        meak
                                        bravo,
                                        pretty light and textures.
                                        lovely ambience.
                                          kwistenbiebel
                                          I find the architecture quite interesting....
                                          and you seem to visualise the idea quite well. Nice renders.
                                          The Podium v 2.0 (beta) colors are indeed very nice. I am looking forward at the Christmas break to get into the new render engine.
                                          The Twilight renders are nice as well. Any pure Physical sky shots?
                                          • olisheaO Offline
                                            olishea
                                            frederik: the main difference is quality and colour. Podium 1.x renders were generally quite cold due to physical sky. Remember we are comparing Podium v2 to Podium 1.x (not podium vs twilight god forbid!!)
                                            biebel: I don't get you....you wanna see a physical sky render for twilight?
                                            oli
                                            • 1 / 4
