    New API doc - typos and questions
    370 Posts 35 Posters 263.5k Views 35 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      OptionsProviderObserver.onOptionsProviderChanged
      http://code.google.com/apis/sketchup/docs/ourdoc/optionsproviderobserver.html#onOptionsProviderChanged
      The onOptionsProviderChanged method is invoked when an element is added to an Pages object.
      Should read, "The onOptionsProviderChanged method is invoked when an option is changed for an OptionsProvider object."
      _
      I'm not here much anymore.
        Entities.add_curve
        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entities.html#add_curve
        Returns an array of edges - not a Curve object.
          @thomthom said:
          Entities.add_curve
          Ita's the same as add_circle which returns an array od edges and to find the just made curves curve you use edges=entities.add_curve(array_of_points) curve=edges[0].curve
          But strangely not with add_arc which returns an ArcCurve ?
          It would be unadvisable to change what the API does with these add_ methods - rather it we should keep it as is and fix the API's Guide to reflect it properly - too many scripts already get the curve from the edges array and would fail if it were updated to return the curve not the curve's edges...
            Nope, also returns an array.
            Agree.
              Agree.
              Perhaps I meant to say, "... add_arc which says it returns an ArcCurve wrongly!" πŸ˜’
                Sketchup.write_default
                Sketchup.read_default
                http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/sketchup.html#write_default
                http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/sketchup.html#read_default
                [..] the string associated with a value within the specified sub-section section of a .INI file or registry (within the Software > @Last Software > SketchUp section).
                Is it really stored under @Last any more?
                  No, / Google / Sketchup 7 / etc... πŸ˜‰
                    Group.move!
                    http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/group.html#move!
                    .move! moves to an absolute point. Worth noting in the manual.
                      Dan Rathbun
                      Geom::Point3d.+
                      http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#+
                      The '+' operator is a fast way to add to the current x, y and z values of a point, or to set the values of a point by adding to other points together.
                      The end of the sentence should read, "...by adding **two** other points together."
                      Returns:
                      vector a Vector object
                      There is no defined object named 'vector'. If we follow the example the class of the result is given as Geom::Point3d.
                      pt2 = Geom;;Point3d.new(100,200,300)
                      pt3 = pt2 + [1,1,1]
                      >> Point3d(101, 201, 301)
                      pt3.class
                      >> Geom;;Point3d
                      Arguments:
                      point2 A Point3d object.
                      An ArugemtError exception is raised if point2 is a Point3d object.
                      Valid argument classes are: Array or Vector3d. This means to use a Point3d as an argument, you must convert to Array. Example:
                      pt3 = pt1 + pt2.to_a
                      This method needs to be fixed to take a Point3d object and internally convert it to an Array...
                      # internal to + method
                      if arg[0].is_a? Point3d { arg[0]=arg[0].to_a }
                      ...or a Vector3d:
                      if arg[0].is_a? Point3d { arg[0]=[0,0,0].vector_to(arg[0]) }
                      either way. The current implementation is clumsy.
                        Dan Rathbun
                        **Geom::Point3d.-**
                        http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#-
                        Returns:
                        There is no defined object named 'vector', but there IS one named ' Vector3d'. If we follow the example the class of the result is given as Geom::Vector3d.
                        pt3 = pt2 - [1,1,1]
                        >> Vector3d(99, 199, 299)
                        pt3.class
                        >> Geom;;Vector3d
                        It seems a bit strange that + returns Point3d, but - returns Vector3d.
                          Dan Rathbun
                          Geom::Point3d.offset
                          Code example has errors:
                          [line1]replace"point ="with"point1 ="
                          [line1]use parameter delimiters both lines
                          [line3]replace".offset**!**"with".offset"
                          add comments
                          Corrected code:
                          point1 = Geom;;Point3d.new(10,10,10)
                          vector = Geom;;Vector3d.new(0,0,1)
                          point2 = point1.offset vector
                          # point1 is unchanged
                          # point2 is Point3d(10, 10, 11)
                          Geom::Point3d.offset!
                          add comments
                          point2 = point1.offset! vector
                          # point1 now equals point2
                            Dan Rathbun
                            Geom::Vector3d.x=
                            http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#x=
                            Geom::Vector3d.y=
                            http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#y=
                            Geom::Vector3d.z=
                            http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#z=
                            #Anchors: '=' char should be replaced with 'equals' in links.
                            All 3 methods suffer from the same return class anomoly as the Vector3d.[]= method, in that they return the class of the argument (which may not always be Float.) In contrast, the .x, .y and .z methods always return class Float.
                            Propose that the .x=, .y= and .z= methods should be modified to return Float as the .x, .y and .z methods do.
                            Propose to add note: "See the **.set!** method to set all three coordinates in one statement." ( .. to the description sections, of each of the three methods.)
                              Dan Rathbun
                              Geom::Vector3d.set!
                              http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#set!
                              This is a shortcut for writing:
                              Clarify: "This is a shortcut for setting all coordinates of the vector, instead of setting them individually in three statements."
                              You may also call this method with an array or another vector:
                              Confusing. (I first took this mean that the SU extended Array class had an Array.set! method; which is NOT the case.)
                              Clarify: "You may also call this method with an Array or a Vector3d object as the first argument,(and any other arguments will then be ignored.)"
                              Add: "If only one Numeric argument is supplied, or if a one element Array is supplied, then only the x value will be changed. IF only 2 values are supplied, in the same way, then the z value will remain unchanged.
                              All coordinate values must be implicitly convertable to Float class.
                              (If you pass a nil value, a TypeError exception is raised.)"
                              Arguments:
                              x ____ The x value for the vector.
                              y ____ The y value for the vector.
                              z ____ The z value for the vector.
                              vector2 ____ A Vector3d object.
                              Remove 4th argument. (There is no valid fourth argument for this method. All args beyond 3 are ignored.)
                              Clarify: (suggested Argument list)
                              Arguments:
                              x ____ The x value for the vector, a Vector3d object, or an Array.
                              y ____ The y value for the vector. (optional)
                              z ____ The z value for the vector. (optional)
                              Better Code Example:
                              vector = Geom;;Vector3d.new 0,0,1
                              vector.set! 1,0,0  # three Numeric arguments
                              vector2 = Geom;;Vector3d.new 1,2,3
                              vector.set! vector2  # one Vector3d argument
                              # vector now is (1,2,3)
                              array1 = Array.new(4,5,6)
                              vector.set! array1[2]  # one Numeric argument
                              # vector now is (6,2,3)
                              vector2.set! array1  # one Array argument
                              # vector2 now is (4,5,6)
                              vector.set! [5,4]  # one Array with 2 values
                              # vector now is (5,4,3)
                              # change x and z in one statement, this way;
                              vector.set! 9, vector.y, 8
                              # vector now is (9,4,8)
                                Dan Rathbun
                                Geom::Vector3d.[=]
                                [="]http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#[]=[/url]
                                Again the HTML anchor may cause problems in some browsers, suggest '#subscriptEquals'
                                Obviously the #[]= anchor tag in the url cannot even be displayed properly in this forum.All of the #anchor links to methods using special chars need to be changed to comply with the HTML spec, as ThomThom noted:
                                ID and NAME tokens must begin with a letter ([A-Za-z]) and may be followed by any number of letters, digits ([0-9]), hyphens ("-"), underscores ("_"), colons (":"), and periods ("."). [url:nfjuel6m]http://www.w3.org/TR/html4/types.html#type-name]("http)
                                Returns:
                                value _______ the newly set coordinate value
                                the Geom::Vector3d.[] method returns class Float
                                BUT, the Geom::Vector3d.[]= method returns the class of the argument.
                                The code example may be misleading to the unwary,
                                value = vector[i] = coordinate
                                ..if the class of the coordinate variable is Integer then the class of the value variable will also be Integer.
                                This causes a coder to do a two-step expression if they want a Float, ie:
                                coordinate = 2
                                vector[i] = coordinate # returns Integer 2
                                value = vector[i]  # value.class >> Float
                                %(#FF4000)[Two Issues:
                                1. Is 'coordinate' the correct term, or would 'component' be a better term when refering to vectors?1. If all the rest of the methods that return subscript values from a Vector3d object are Float, then perhaps this method should as well, regardless of the class of the argument.]
                                  Dan Rathbun
                                  Geom::Point3d.<
                                  http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#%3C
                                  Returns:
                                  true if the point2 is closer to the origin.
                                  Following the example, I get the opposite result.
                                  TheReturns:should probably read,
                                  " *true* if the point2 is **farther** from the origin; *false* if the point2 is closer to the origin (than the receiver.)
                                    @thomthom said:
                                    Group.move!
                                    It doesn't seem to though - we've been testing it in another thread this afternoon and it seem that it moves relative to the transformation-origin NOT the model's ORIGIN - you first have to do a transformation by vector from where it is to the ORIGIN and then off again to the absolute point ?
                                      @dan rathbun said:
                                      Ruby code can no longer use the nil return value in a conditional boolean statement.
                                      There is also no way now to determine how many Dictionary objects, there are within an AttributeDictionaries collection (No Methods: .size, .length, .count, or .empty?)
                                      There are no methods but several easy combos to do it...
                                      You make an array of it and than get its length ?
                                      len = AttributeDictionaries.to_a.length
                                      or use 'each' ?
                                      len = 0;AttributeDictionaries.each{|d|len += 1}
                                      Where len is the AttributeDictionaries length ?
                                        AttributeDictionaries.to_a.length works.
                                          ComponentInstance.explode
                                          http://code.google.com/apis/sketchup/docs/ourdoc/componentinstance.html#explode
                                          Code example is irrelevant - doesn't show the use of .explode.
                                            RenderingOptions
                                            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/renderingoptions.html
                                            FogColor
                                            # FogDensity
                                            FogEnd
                                            FogStart
                                            # FogType
                                            FogUseBkColor
                                            Bold entries returns nil.
                                            The RenderingOptions I get when I iterate the collection is:
                                            BackgroundColor
                                            BandColor
                                            ConstructionColor
                                            DepthQueWidth
                                            DisplayColorByLayer
                                            DisplayDims
                                            DisplayFog
                                            DisplayInstanceAxes
                                            DisplaySketchAxes
                                            DisplayText
                                            DisplayWatermarks
                                            DrawDepthQue
                                            DrawGround
                                            DrawHidden
                                            DrawHorizon
                                            DrawLineEnds
                                            DrawProfilesOnly
                                            DrawSilhouettes
                                            DrawUnderground
                                            EdgeColorMode
                                            EdgeDisplayMode
                                            EdgeType
                                            ExtendLines
                                            FaceBackColor
                                            FaceColorMode
                                            FaceFrontColor
                                            FogColor
                                            FogEndDist
                                            FogStartDist
                                            FogUseBkColor
                                            ForegroundColor
                                            GroundColor
                                            GroundTransparency
                                            HideConstructionGeometry
                                            HighlightColor
                                            HorizonColor
                                            InactiveHidden
                                            InstanceHidden
                                            JitterEdges
                                            LineEndWidth
                                            LineExtension
                                            LockedColor
                                            MaterialTransparency
                                            ModelTransparency
                                            RenderMode
                                            SectionActiveColor
                                            SectionCutWidth
                                            SectionDefaultCutColor
                                            SectionInactiveColor
                                            ShowViewName
                                            SilhouetteWidth
                                            SkyColor
                                            Texture
                                            TransparencySort
                                            If the differences is due to changes between SU version I hope the docs will say when they where removed instead of removing them from the manual. Good to know the history.
                                            • 18
                                            • 19
                                            • 7 / 19
