    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
    • Chris FullmerC Offline
      Excellent! glad you got it working. I hope it is able to help,
        carpediem0881
        So after getting it to work and playing with it, i tried to bend text. and game up with some errors in the finished product. The text bends but creates holes and lines that are not in the original text images. I have attached a file... Any thoughts on my these holes and deformations to the letters happen? Is it something in my settings that i need to change or is this just what happens when you bend more complicated items?
        You can see in the e there is a hole, and on other letters that I didn;t picture and the t clearly has lines that are deformed.
          Sorry to say that you are just running into the glitches of the script unfortunately. But there are things you can do to help a bit.
          If you are getting holes, its possible that the model is too small for SketchUp. It struggles to make small faces. Try scaling larger by 10 or 100 times. That might help.
          The extra lines that come in are from SketchUp deforming geometry on top of my script deforming it. The best thing to do is to clean it up by softening those lines. Use the eraser tool and hold ctrl (or option or something on the Mac). That will soften them and they disappear. Also, some lines get hidden during the bending that should not be hidden. So you will want to find those and then un soften them.
          Also, try adding segmentation to the arc. That could help. Or line up your text slightly differently with the straight line. Those kinds of things can help, when you are able to do them. Its painful though when you are working on something that does not allow you to move the geometry as it must line up with something and the bending is just not working right.
          Like I always warn, this script is great, but its not perfect and its full of little glitches. So it as best you can. And it might require a bit of clean up afterwards. Good luck,
            OH also, I meant to add that text is often difficult to bend because its mesh is not as clean as it looks. You might have some better luck also if you select all the geometry of the text, right click and choose "explode curve". That might help the bending.
            • E Offline
              Edwardo
              Great Plugin Chris!
              I do have one question: is there anyway for me to take a finite length of material and bend it on a curve without stretching it?
              For example: I really want to use your plugin to build this plexiglass wall. The Plexiglass is 36' long and 8' tall when flat. I want to know what it would look like if I bent it on different radii.
              I drew some various arcs, and the shape bender does indeed bend my plexiglass wall to match the arc ... but it stretches it out to make it fit. Is there anyway I can use your plugin to take my plexiglass wall and match it to that arc without stretching it?
              Thanks very much Chris
              EDWARDO
              "build it / destroy it"
                Yes, you can control that by figuring out how long the arc is, then scale the shape to be the same length. Then draw the line to be the same length as the shape. That should help reduce the stretching. Also, draw the line underneath the shape, and line up exatly in the middle. That might help even a little more.
                Sorry its not simpler. I know it can be tricky to find the length of the curve.
                • jeff hammondJ Offline
                  if you'd rather not scale down the shape, this online calculator makes it pretty easy to figure out chord length etc..
                  http://www.handymath.com/cgi-bin/arc18.cgi?submit=Entry
                  [edit] actually, i think if i were wanting to do something similar as edwardo (testing the look at multiple radii etc.), i'd probably do something like:
                  draw an arc longer than necessary.. get its length via entity info.. draw a line the same length that's included in the group to be bent..
                  then draw my shapebender line underneath that one etc..
                  seems like the quickest way to do a bunch of tests.. after i found the right radius, i'd fine tune accordingly to do the final bend.
                  i dunno, just thinking out loud 😄
                  [something like this]
                  • charly2008C Offline
                    charly2008
                    Shape bender is one of the best tools. You can make so many incredible things with it. The arched roof element was also done so. There were also some holes, this I had to repair manually, No Problem. Nevertheless, it saves a lot of time.
                    Karlheinz
                    • E Offline
                      Edwardo
                      What an awesome calculator Jeff! This is a real time saver.
                      Now, I just need to find a plugin that will help divide up my model into material sizes. See, the reason I've been usuing sketchup is because I do set construction and many of the designers I work for need me to break apart their sketchup drwaing into construction plans. I used to use AutoCAD ... untill I discovered Layout 😄
                      Anyone out there know of a plugin where I can select a surface and see it divided up into 4' x 8' sheets? This would be a great help when ordering materials ... and it would help me quickly figure out where my seams are and where to place my toggles etc.
                      EDWARDO
                        amonserrano
                        Your new video is amazing... This is exactly what I need. Thank you
                          charly2008
                          I have a technical question to Chris.
                          Yesterday, i made this roof structure with randomly 12 objects. The objects were also evenly divided among 12 sections. This means each object belongs to one section.
                          Today I repeated the same with 3, 4 and 8 objects. These are also distributed to 12 sections. This means that a number of n-objects is always divided to 12 sections according to the sides of the arc. And the number of sides can not be changed.
                          Sorry, problem is solved! After inserting a new side value in the VCB i forgot to press Enter.
                          • bobpineoB Offline
                            bobpineo
                            Chris,
                            Just came across your shape bender script, just great thanks for sharing.
                            Now I wonder how I got through my days of modeling without it!
                            Can't wait to check out your other scripts.
                            Bob
                            Bob Pineo, Design Develop LLC http://www.designdevelop.org.
                              cupko
                              Great plugin! 😄 👍 👍
                              Thanks!!
                                t_gia197
                                When I clik straight line, after that, arc line...the comand not show ACCEPT AND TRANSFORM. It show ACEEPT = ENTER. So that, I can't do it like your Tut. Can You help me.
                                ( I'm using Vista x64 OS, SU ver. 7.0 pro )
                                  You should just be able to press the enter key and it will finish bending the shape. Does that work?, or are you having a different problem?
                                    muchado
                                    Oh good, glad you found that post and were able to get it working.
                                    I'm amazed at how many zip programs do not correctly unzip these plugins. The winzip I have at work is one of these that just ignores all folder and subfolder organization inside of .zip files, and just extracts everything to the same folder - very frustrating. And wreaks havoc on plugins dependent on folder organization...But glad its working. Of course, now you have to deal with all the bugs and issues involved with the script 😄
                                    WinZip has a setting in options where you can choose to extract all files into one folder. I suspect that this is how many people have it set up.
                                      ayieartwork
                                      Hi.im new here.why i cant download the plugin.help2!
                                      Intel Core i7-3930k with 16gb G.Skill Ripjaws
                                        Hi Fadhli,
                                        The plugin is attached to the first post of this topic. If you have problems, please, have a look at this announcement and delete your browser cookies:
                                        http://forums.sketchucation.com/viewtopic.php?f=323&t=19797
                                          driven
                                          Hi Chris,
                                          great tool, again...
                                          I'm working on a font stringer idea for 3D stainless steel printing and this does 90% of the basic component build beautifully, but as I need to now do this to a full character set, I'm was wondering if a few features could be added.
                                          the concept
                                          and this is just 'CopyRotate' version, but I have also done some test's with 'ComponentStringer' following more complex curves.
                                          the '%' are component (place holders)
                                          one of the steps that may be improved is after the second bend, of the 'letter' component, both ends need to be rotated back to the arc centre, I can't think of an easy way to do this and was thinking that being able to choose the arc centre as part of the parameters would be useful, or better still if "FindArcCentrePoint" could be utilized to find it's own on a multi-arc line.
                                          another is stipulating which is start and end on both lines (it changes from character to character even though I'm using locked templates and Copy-PastseInPlace' to generate them)
                                          To be honest I'm really just throwing some quick early ideas out there for any comments
                                          EDIT
                                          with 'A' character replacement (not fully tweaked)
                                            driven
                                            Hi Chris,
                                            I had to do a job today using Shapebender to put text on tubes, as above, but more refined.
                                            to my surprise, I actually had all the dialogs, option to select ends ,ect before running, I really didn't know they were there.
                                            however, instead of making curved fonts, when I switched ends all it did was make an empty group, click again, another empty group, hit return another group.
                                            I had outliner on, which is how I saw the groups, but suspecting it might be the problem, tuned it off, same thing.
                                            working backward through my ruby instals, functionality returned when I removed the new VitrualWindSim ruby but without the end switching bits. because I really had a lot to do and the switching ability would speed it up, I stripped out all the rubies from my MacBook and only put what was needed for SB back in.
                                            No extra bits, added VWS got all the whistles , but no Bells, so I just thought I'd let you know. I'll grab the Mac console log when I finish up and see if it shows anything.
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 63
                                            • 64
                                            • 56 / 64
