    Model this - a simple cube
    72 Posts 30 Posters 5.8k Views 30 Watching
    • charly2008C Offline
      charly2008
      I've found it at last, the earth is not a sphere but a cube. I will outline the evidence tomorrow.
      Have a good night
      • david_hD Offline
        david_h
        I found that if I modeled this correctly, I would get a perfect square. Late Password Host Allen Ludden -- the most perfect square I know. 🤣
          rev3rse
          Another attempt, in "Escher style"
          A cube thought
            Aerilius
            We should propose to Google to update the elevation maps so that it fits better into this packaging:
            http://sketchup.google.com/3dwarehouse/download?mid=20b4efaf430fa8b18be14e22ce0bc010&rtyp=lt&ctyp=other&ts=1243057686000
            Initiative for efficient packaging!
            Cube for president!
            (ok, bush had already his cube)
            • E Offline
              Ecuadorian
              They say a cube is just an infinite number of squares stacked together.
              -Miguel Lescano
              • N Offline
                nomeradona
                this is interesting.. can you please specify the step by step procedure you use... you gai..really makes my day today. 👊
                  See about half way through this video clip how to make a cube and transform it... http://forums.sketchucation.com/viewtopic.php?p=208103#p208103BallsCube.png
                    Aerilius
                    Oh! Then I did it wrong? I stacked lots of triangles...
                    because I thought 3-d
                    Can you help me?
                      Rubik's Cube made easy here
                      [flash=400,345:yqbf21xu]http://www.metacafe.com/fplayer/1222538/rubiks_cube_magic_trick.swf[/flash:yqbf21xu]
                        charly2008
                        How many parts A and how many parts B are necessary to build this solid cube?
                        Cube1.skp
                          charly2008
                          Hi TIG,
                          Excellent
                            charly2008
                            Here again, the solution exploded
                            Cube.skp
                              It's the basis of a Rubik's Snake - like a Rubik's Cube but... 😉
                              • DanielD Offline
                                Daniel
                                You guys blow me away with your advanced shape modeling. Maybe, on day, after I've mastered the line, I'll be able to catch up.
                                My avatar is an anachronism.
                                  8 A Green
                                  • RichardR Offline
                                    Richard
                                    Being from German family I could just stick a picture of my head up and fool you all that it was modelled! Blockhead!
                                    [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                                      KXI System
                                      I just crashed SU by just trying.... 👊
                                      Getting the perfect sig is hard...
                                      Google it!
                                      • Chris FullmerC Offline
                                        I almost got it. I just can't get the last piece to fit into the others. Plus I have a few pieces left over 😕
                                        • wind-borneW Offline
                                          wind-borne
                                          color by axis
                                          "To read between the lines was easier than to follow the text."OSX 10.11.6
                                          %(#BF80BF)[SU 8 pro
                                            Here's a 'Soma Cube' Puzzle to keep you amused.
                                            There are 48 symmetries and 1,195,020 different ways of making a 3x3x3 cube with these pieces, but there are only 240 independent ways !
                                            One of them has already been done for you...
                                            The faces' colors aren't important - they can be 'mixed' - just there to help see what you are doing...
                                            You just have to find one, or two... 😄SomaCube.pngSomaCube.skp
                                            • 4 / 4
