    Model this - a simple cube
    72 Posts 30 Posters 8.3k Views 30 Watching
    • daleD Offline
      dale
      Well... If were going to talk cubist....
      • charly2008C Offline
        charly2008
        Cube Tutorial
        -Do such a contour in Sketchup and print it out.
        -Cut out the outline and fold a cube.
        -Take a picture of the cube.
        -Import the photo into Sketchup.
          charly2008
          I propose that we set up a new forum for Cubists. We need the cube necessarily to develop. It is still a long way to the perfect cube. I call it the squaring of the cube. Might be worthy of the Nobel Prize.
          • soloS Offline
            I dunno, that name is too square, you need to think outside the box.
              museummaker
              Took me awhile but I think I got it so it looks square from every side.
              I thought SU was supposed to be easy to use? 😆 cube.skp
                charly2008
                I've found it at last, the earth is not a sphere but a cube. I will outline the evidence tomorrow.
                Have a good night
                • david_hD Offline
                  david_h
                  I found that if I modeled this correctly, I would get a perfect square. Late Password Host Allen Ludden -- the most perfect square I know. 🤣
                    rev3rse
                    Another attempt, in "Escher style"
                    A cube thought
                      Aerilius
                      We should propose to Google to update the elevation maps so that it fits better into this packaging:
                      http://sketchup.google.com/3dwarehouse/download?mid=20b4efaf430fa8b18be14e22ce0bc010&rtyp=lt&ctyp=other&ts=1243057686000
                      Initiative for efficient packaging!
                      Cube for president!
                      (ok, bush had already his cube)
                      • E Offline
                        Ecuadorian
                        They say a cube is just an infinite number of squares stacked together.
                        -Miguel Lescano
                        • N Offline
                          nomeradona
                          this is interesting.. can you please specify the step by step procedure you use... you gai..really makes my day today. 👊
                            See about half way through this video clip how to make a cube and transform it... http://forums.sketchucation.com/viewtopic.php?p=208103#p208103BallsCube.png
                              Aerilius
                              Oh! Then I did it wrong? I stacked lots of triangles...
                              because I thought 3-d
                              Can you help me?
                                Rubik's Cube made easy here
                                [flash=400,345:yqbf21xu]http://www.metacafe.com/fplayer/1222538/rubiks_cube_magic_trick.swf[/flash:yqbf21xu]
                                  charly2008
                                  How many parts A and how many parts B are necessary to build this solid cube?
                                  Cube1.skp
                                    charly2008
                                    Hi TIG,
                                    Excellent
                                      charly2008
                                      Here again, the solution exploded
                                      Cube.skp
                                        It's the basis of a Rubik's Snake - like a Rubik's Cube but... 😉
                                        • DanielD Offline
                                          Daniel
                                          You guys blow me away with your advanced shape modeling. Maybe, on day, after I've mastered the line, I'll be able to catch up.
                                          My avatar is an anachronism.
                                            8 A Green
                                            • 3 / 4
