    Model this - a simple cube
    72 Posts 30 Posters 9.5k Views 30 Watching
    • soloS Offline
      I dunno, that name is too square, you need to think outside the box.
        museummaker
        Took me awhile but I think I got it so it looks square from every side.
        I thought SU was supposed to be easy to use? 😆 cube.skp
        • charly2008C Offline
          charly2008
          I've found it at last, the earth is not a sphere but a cube. I will outline the evidence tomorrow.
          Have a good night
          • david_hD Offline
            david_h
            I found that if I modeled this correctly, I would get a perfect square. Late Password Host Allen Ludden -- the most perfect square I know. 🤣
              rev3rse
              Another attempt, in "Escher style"
              A cube thought
                Aerilius
                We should propose to Google to update the elevation maps so that it fits better into this packaging:
                http://sketchup.google.com/3dwarehouse/download?mid=20b4efaf430fa8b18be14e22ce0bc010&rtyp=lt&ctyp=other&ts=1243057686000
                Initiative for efficient packaging!
                Cube for president!
                (ok, bush had already his cube)
                • E Offline
                  Ecuadorian
                  They say a cube is just an infinite number of squares stacked together.
                  -Miguel Lescano
                  • N Offline
                    nomeradona
                    this is interesting.. can you please specify the step by step procedure you use... you gai..really makes my day today. 👊
                      See about half way through this video clip how to make a cube and transform it... http://forums.sketchucation.com/viewtopic.php?p=208103#p208103BallsCube.png
                        Aerilius
                        Oh! Then I did it wrong? I stacked lots of triangles...
                        because I thought 3-d
                        Can you help me?
                          Rubik's Cube made easy here
                          [flash=400,345:yqbf21xu]http://www.metacafe.com/fplayer/1222538/rubiks_cube_magic_trick.swf[/flash:yqbf21xu]
                            charly2008
                            How many parts A and how many parts B are necessary to build this solid cube?
                            Cube1.skp
                              charly2008
                              Hi TIG,
                              Excellent
                                charly2008
                                Here again, the solution exploded
                                Cube.skp
                                  It's the basis of a Rubik's Snake - like a Rubik's Cube but... 😉
                                  • DanielD Offline
                                    Daniel
                                    You guys blow me away with your advanced shape modeling. Maybe, on day, after I've mastered the line, I'll be able to catch up.
                                    My avatar is an anachronism.
                                      8 A Green
                                      • RichardR Offline
                                        Richard
                                        Being from German family I could just stick a picture of my head up and fool you all that it was modelled! Blockhead!
                                        BUILTBRAND.COM.AU
                                          KXI System
                                          I just crashed SU by just trying.... 👊
                                          Getting the perfect sig is hard...
                                          Google it!
                                          • Chris FullmerC Offline
                                            I almost got it. I just can't get the last piece to fit into the others. Plus I have a few pieces left over 😕
                                            • 3 / 4
