    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.5m Views 329 Watching
    • Chris FullmerC
      ok, it worked just fine on my system, so you do have it set up right (thanks for uploading the model to verify).
      It could be a script conflict. There have been problems with people who have an old version of component spray installed. So if you have that, try removing it. Also, there is a slim chance it might be sketchyphysics.
      But check the coponent spray first. If removing that fixes the problem, then there is a new version of component spray that is compatible. I'll find a link for you if that is the problem.
      • P
        pr0bka
        Chris! you were right afterall...removed sketchy physics and component spray and voilaaa!! it works!!! πŸ˜„
        I will try installing a new version of component spray (v.1.1?) and sketchy physics. Maybe theres a newer version? Thanks a lot for all your hard work and attention!
        -Sam
        • Chris FullmerC
          There is a greater chance that it is component spray than sketchy physics. So you might put Sketchy physics back first, then test if it still works. Then if it work, just reinstall component spray.
          • G
            glider
            Chris,
            Thank you for the Shape Bender plugin. I was working on placing some text on an Old West saloon window, as seen in a 1880 image. The name of the saloon was slightly "bent" across the window. This worked great.....great job!
            Dave
            • Chris FullmerC
              Cool Dave, thanks for posting to let me know it worked for you.
              I noticed this is your first post also, so welcome! You joined only a couple of weekS after I did in 2007. Do you visit regularly, just never post? Or is this your first time back in 2 years? I'm just curious is all.
              Thanks,
              • L
                loolytoo
                i am a beginner and strugling a bit. if someone has some time and patience i would love some help.
                Please help me install this script, i downloaded it and saved the rb file in plugins, and also the progress bar, but it dosnt work. can anyone guide me through the steps of installing properly? do i need to install another file from the zip file, there are lots more in another folder with png extentions what are they? do i need them?
                Lucy
                • massimoM
                  massimo Moderator
                  Hi Lucy. Unzip the downloaded folder and put the file and the folder contained inside (see the picture below) in your SU plugin folder.
                  That' all. πŸ˜‰
                  • N
                    nikkkko
                    I'm also having a problem at the point where I need to hit 'enter'. I usually run SU under Wine, which has been working well for me over the last year, including various ruby scripts, but when I ran into this problem also tried it under XP with the same result. I have tried removing all other scripts but with no difference.
                    Here's the ruby console output :
                    Error: #<NameError: uninitialized constant Clf_shape_bender::ProgressBar>
                    C:/PROGRA~1/Google/GOOGLE~1/Plugins/clf_shape_bender/clf_shape_bender.rb:522:in exploder' C:/PROGRA~1/Google/GOOGLE~1/Plugins/clf_shape_bender/clf_shape_bender.rb:244:in onLButtonUp'
                    Error: #<NoMethodError: undefined method /' for nil:NilClass> C:/PROGRA~1/Google/GOOGLE~1/Plugins/clf_shape_bender/clf_shape_bender.rb:671:in draw'
                    C:/PROGRA~1/Google/GOOGLE~1/Plugins/clf_shape_bender/clf_shape_bender.rb:870:in transform_it' C:/PROGRA~1/Google/GOOGLE~1/Plugins/clf_shape_bender/clf_shape_bender.rb:288:in onReturn'
                    • N
                      nikkkko
                      Replying to my own post here...
                      I don't know anything about ruby, but seeing as the first line in the console output was an error concerning progressbar, I re-downloaded it and hey presto, everything works under linux/wine, (I haven't bothered tried it under windows).
                      Thanks for a great plugin by the way. About 80% of my work is building structures with arcs - steel frames for oval shaped cabins to be precise - and this is going to save me a ton of time.
                      Nick
                      • C
                        carpediem0881
                        I just downloaded shape bender to add some text on a curve surface of a bowl and the button shows up in the top left corner of sketchup as well as the plugins tab.
                        I select my component and then try to sellect my line and curved line to follow but it will not allow me to select the lines like your videos shows.
                        I am wondering if I installed the plugin incorrectly or I am missing some instructions like holding down a button to allow me to select the lines.
                        if someone could point me in the right direction that would be great.
                        Jeff
                        • Chris FullmerC
                          Hi Jeff, there are 2 things to remember when selecting the straight line.
                          1 the straight line must be drawn on the red axis.
                          2 the cursor "hotspot" is horrible. 😳 You often have to click to the side of the line. But it will highlight plue when you are correctly hovering over it.
                          The hotspot thing holds true for selecting arc also.
                          If that does not help, upload a test model here and I'll take a look at it. Hope that helps,
                          • C
                            carpediem0881
                            1. So I tried uninstalling the plug-in and sketchup... reinstalled both and gave it another shot.
                            2. Made a line on the red axis, a arc on the red axis and a 3d rectangle to arc around the curve.
                            3. Made the 3d rectangle a group
                            4. selected the group, and activated the plugin. "please select line on red axis" appears in the bottom left corner
                            5. I then scroll over the straight line but still won;t let me select it, its doesnlt turn blue and i tried clicking on the line in numerous places. I watched your videos and did the set-up the same but nothing...
                            Do I need sketchup pro? or does it work with the standard program? any ideas?
                            Jeff
                            • C
                              carpediem0881
                              I got it to work... I am just a new mac user and didn't know how to install the plugin correctly... i only drug the one file in not the folder containing all the information... thansk for your input and this sweet plugin!!!
                              • Chris FullmerC
                                Excellent! glad you got it working. I hope it is able to help,
                                • C
                                  carpediem0881
                                  So after getting it to work and playing with it, i tried to bend text. and game up with some errors in the finished product. The text bends but creates holes and lines that are not in the original text images. I have attached a file... Any thoughts on my these holes and deformations to the letters happen? Is it something in my settings that i need to change or is this just what happens when you bend more complicated items?
                                  You can see in the e there is a hole, and on other letters that I didn;t picture and the t clearly has lines that are deformed.
                                  • Chris FullmerC
                                    Sorry to say that you are just running into the glitches of the script unfortunately. But there are things you can do to help a bit.
                                    If you are getting holes, its possible that the model is too small for SketchUp. It struggles to make small faces. Try scaling larger by 10 or 100 times. That might help.
                                    The extra lines that come in are from SketchUp deforming geometry on top of my script deforming it. The best thing to do is to clean it up by softening those lines. Use the eraser tool and hold ctrl (or option or something on the Mac). That will soften them and they disappear. Also, some lines get hidden during the bending that should not be hidden. So you will want to find those and then un soften them.
                                    Also, try adding segmentation to the arc. That could help. Or line up your text slightly differently with the straight line. Those kinds of things can help, when you are able to do them. Its painful though when you are working on something that does not allow you to move the geometry as it must line up with something and the bending is just not working right.
                                    Like I always warn, this script is great, but its not perfect and its full of little glitches. So it as best you can. And it might require a bit of clean up afterwards. Good luck,
                                    • Chris FullmerC
                                      OH also, I meant to add that text is often difficult to bend because its mesh is not as clean as it looks. You might have some better luck also if you select all the geometry of the text, right click and choose "explode curve". That might help the bending.
                                      • E
                                        Edwardo
                                        Great Plugin Chris!
                                        I do have one question: is there anyway for me to take a finite length of material and bend it on a curve without stretching it?
                                        For example: I really want to use your plugin to build this plexiglass wall. The Plexiglass is 36' long and 8' tall when flat. I want to know what it would look like if I bent it on different radii.
                                        I drew some various arcs, and the shape bender does indeed bend my plexiglass wall to match the arc ... but it stretches it out to make it fit. Is there anyway I can use your plugin to take my plexiglass wall and match it to that arc without stretching it?
                                        Thanks very much Chris
                                        EDWARDO
                                        "build it / destroy it"
                                        • Chris FullmerC
                                          Yes, you can control that by figuring out how long the arc is, then scale the shape to be the same length. Then draw the line to be the same length as the shape. That should help reduce the stretching. Also, draw the line underneath the shape, and line up exatly in the middle. That might help even a little more.
                                          Sorry its not simpler. I know it can be tricky to find the length of the curve.
                                          • jeff hammondJ
                                            if you'd rather not scale down the shape, this online calculator makes it pretty easy to figure out chord length etc..
                                            http://www.handymath.com/cgi-bin/arc18.cgi?submit=Entry
                                            [edit] actually, i think if i were wanting to do something similar as edwardo (testing the look at multiple radii etc.), i'd probably do something like:
                                            draw an arc longer than necessary.. get its length via entity info.. draw a line the same length that's included in the group to be bent..
                                            then draw my shapebender line underneath that one etc..
                                            seems like the quickest way to do a bunch of tests.. after i found the right radius, i'd fine tune accordingly to do the final bend.
                                            i dunno, just thinking out loud πŸ˜„
                                            [something like this]
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 63
                                            • 64
                                            • 15 / 64
