    SU8 - WISHLIST
    203 Posts 61 Posters 76.5k Views 61 Watching
    • ken28875K Offline
      ken28875
      Selecting vertices and merging them. Right now Sketchup allows us to select only one vertex. I would love to be able to select as many as needed to move, rotate, or merge. For example, if two vertices are 10 m apart, selecting them and clicking on the merging tool will merge them at the middle point (5m); or slecting many vetices and merging them to a point/center of the group.
      Follow Your Dreams.
      • plot-parisP Offline
        plot-paris
        thats a good idea - merging vertices.
        I would also like more control over selection options and inferencing. being able to select vertices, edges, faces only would make certain tasks easier.
        also having an option to only select visible elements (at the moment if I draw a selection frame, everything will be selected, even if its hidden behind other geometry...).
        and being able to switch off coordinate axes inferencing would be great.
        and - I think it was mentioned earlier and I didn't really understand the idea behind it 😳 - having a modifier key to lock movement/drawing to a certain plane (similar to the arrow keys locking to a certain axis already). I would implement it like that: if you press the key - no matter if you are in the middle of an operation, like drawing a line - you get a gizmo (not much unlike the rotating wheel). you then click-drag to define the orientation (exactly like with the rotating tool). now the locked plane is shown with a dotted, light grey grid and you can proceed with the operation you were executing...
          @tfdesign said:
          With the ability to split off the full screen to another monitor (if your PC supports that). This would be great for presentations (as I found out yesterday!).
          LayOut can do full screen presentation and you can even set which monitor it should do it (surely you need the pro version for LayOut)
          @plot-paris said:
          I would appreciate the option to show/hide a transformation gizmo at the origin of groups/components. at the moment you can change the axes of a component (not of a group though). and you can see the axes - and therefore the origin of the component - when editing it. if you move groups/components around however, you don't know where the origin is.
          Hi Jakob, have you tried to make the Component axes visible in the Model info > Components dialog? You could even assign a toggle on/off shortcut.
          How about the "Point Merger Tool" by BTM?
            plot-paris
            cool, thanks Gaieus. didn't know about that option...
            • ken28875K Offline
              ken28875
              How about the "Point Merger Tool" by BTM?[/quote]
              Hi Gaieus,
              Yes, that's the idea. But it is still very hard to control what to merge. I wish I can select which points to merge. I guess the merger will work better only when Sketchup allows us to select vertices.
              Thanks for the link, though.
              Follow Your Dreams.
              • ken28875K Offline
                ken28875
                UV Texture - I don't know if anyone has mentioned about UV yet. But that would be awesome to be able to UV texture the model the way Maya or Max does.
                Follow Your Dreams.
                  SU's native texturing tools are indeed rather primitive. Have you seen Whaat's UV Tools?
                  http://forums.sketchucation.com/viewtopic.php?f=323&t=10404
                  and
                  http://forums.sketchucation.com/viewtopic.php?f=323&t=23725
                  • ken28875K Offline
                    ken28875
                    and
                    Awesome. Thanks, Gaius for the link and Whaat for the plugin! πŸ‘
                    Follow Your Dreams.
                      mpowell1234567890
                      For Sketchup 8 "Free", I like to have the ability to lighten or darken shading of models especially ones that have curves.
                        remus
                        If youve got shadows on it's already possible, just go to the shadows dialog->expand it->twiddle the light and dark sliders.
                          mpowell1234567890
                          Cool, thanks.
                          • U Offline
                            Ultimatez 32
                            Looks like I need to put in my wishlist, so here it is:
                            • high poly support
                            • Object animation (would be awesome with rendering as well, but if it's a sketchy style then even more awesome! )
                              unlikely to be in su 8 though, most like su 24.. πŸ˜„
                            Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                              Well, what I can say is that at least with rendering (some renderers for the time being - but hopefully sooner or later more and more will be capable) and SketchyPhysics, object animation and animation export is at least not impossible...
                              http://www.youtube.com/results?search_query=sketchy+physics+twilight+render&search_type=&aq=f
                                tfdesign
                                Google NEED to BUY Sketchyphysics, and build it right into SketchUp!!!
                                I've been playing with Sketcher's Studio, which I think is really ace. I think physics is going to be added sometime, in the not too distant future πŸ˜„
                                  jessemorton24
                                  Give me an adjustable eraser tool!!! NO, I'll buy it..
                                  Parkways, Driveways, Gateways, Pathways...
                                    darospa
                                    is possible to have (in the next version)a "color by layer" options for each layers?
                                    could be very important when you have to highligth something in your drawing.
                                    thank you
                                      remus
                                      Already available: open the layers panel, click the details button (top right corner) then click 'colour by layer'.
                                        d12dozr
                                        As suggested by user "jgb" recently, could extra mouse buttons be assigned for shortcuts in Sketchup?
                                        http://goo.gl/f7ooYh
                                          darospa
                                          thank you
                                          but i mean just for a single or few layers!
                                          layer
                                            plot-paris
                                            I find that to be an interesting idea, darospa.
                                            especially if you could access this information via scene tabs. so in one scene you only highlight one layer (by it's colour). in the next scene you highlight another... would be a great tool for presentations
                                            • 11
                                            • 9 / 11
