Help my carpet is turning everything pink!
I'm working on one of my first interior renders with V-Ray and everything is turning pink. I feel like I should be able to fix this in the material editor but I'm not sure how? Any suggestions would be great.
Lars
Is there a way to tone down the radiosity? (not sure what they call it in Vray, but that is the result of high radiosity)
Is your ceiling the same material as walls? -
The ceiling is white and the walls are a light beige color.
The link below seems to answer my question but I'm not sure how to make a "VRayOverride GI material".
http://www.spot3d.com/vray/help/150SP1/examples_vray_overridemtl.htm#ex3
One workaround is to apply a different colour to the carpet, render out an IR map, then restore the original carpet colour and Render the image using the IR map you just created.
Lars
It Is Corrected by change of importance Saturation c 1 (is defaulted), before 0,2-0,5, good result gives 0,25.
