    Creating a ramp on a curve
    22 Posts 9 Posters 8.7k Views 9 Watching
    • GaieusG
      Ehm...
      Indeed, I didn't explain it. Funny is that I used the Drape tool to drape it on the flat surface - and the drape tool is also part of the Sandbox tools (which are essentially plugins for SU).
      • Chris FullmerC
        Here's a way you could do it using Shape Bender.
        [flash=800,600:1epzlnee]http://www.youtube.com/v/tGHTIOMm_34&hd=1&fs=1[/flash:1epzlnee]
        • Jean LemireJ
          Jean Lemire
          Hi Jonathanb, hi folks.
          See this SU file for ideas.
          Curved ramp.skp
          • W
            wyatt
            Chris,
            Awesome script and tutorial. I somehow have missed downloading Shape Bender. Off to get it now...
            Wyatt
            • GaieusG
              Also, if you add the 100mm thickness to a flat plane, you can always move one end face up like this
              unfortunately, SU's autofold function is not always flawless so you still need a bit of cleanup for a nice, final result
                Some plugs can make that πŸ˜‰
                Follow and Keep, Extrusion along a path (1001bits)... Extrude Edges by Edges, Extrude Edges by Rails, Component Stringer, FredoScale etc..Shape Bender πŸ˜‰ ...
                Depending of what do you want exactly! πŸ’š
                • troyhomeT
                  troyhome
                  [flash=800,600:3fc6wrdl]http://www.youtube.com/v/tGHTIOMm_34&hd=1&fs=1[/flash:3fc6wrdl]
                  Chris, as always- great scripts and great video tutorials!
                  I had a DUHHHH moment when i saw you use the erase tool to UN-smooth geometry! Didn't know you could do that- i thought it could only smooth it πŸ˜„
                  IOviz.com
                  SU Pro 2024 PC
                  • Chris FullmerC
                    Hehe, glad I could provide you with a "DUH" moment of your own.
                    I've always thought that watching how other people work in real time is an eye opening experience.
                      d12dozr
                      +1
                      Love the tut, Chris πŸ˜„
                      http://goo.gl/f7ooYh
                        jonathanb
                        That you tube tutorial was really helpful, i think i will get shape bender too. Seems like a relatively straight forward method especially with the help of a voice over!
                        There are so many ways to make the curved ramp i take it!
                        Jonathan
                          I've added an example of using EEbyRails to make a simple OR complex ramp on a curve - see here http://forums.sketchucation.com/viewtopic.php?p=206584#p206584
                          All you need is a curve for the cross-section [profile] and curves for the two side rails - rotated in 3D so that the landing is as you want [probably level?]...
                          • 2 / 2
