    Creating a ramp on a curve
    22 Posts 9 Posters 8.7k Views 9 Watching
    • W
      wyatt
      Gai,
      Yes, it's good to understand the fundamentals. Nonetheless, thank goodness for plugins! πŸ˜„
        jonathanb
        Gai,
        what i meant was when you first showed me how to build the ramp, the underneath of the ramp was all solid, yet i'm not sure how you did this. I understand how you get from there to the 100mm thick ramp but just not the initial making the ramp solid bit.
        Thanks Wyatt i will look out for that plug in!
        Jonathan
        • GaieusG
          Ehm...
          Indeed, I didn't explain it. Funny is that I used the Drape tool to drape it on the flat surface - and the drape tool is also part of the Sandbox tools (which are essentially plugins for SU).
          • Chris FullmerC
            Here's a way you could do it using Shape Bender.
            [flash=800,600:1epzlnee]http://www.youtube.com/v/tGHTIOMm_34&hd=1&fs=1[/flash:1epzlnee]
            • Jean LemireJ
              Jean Lemire
              Hi Jonathanb, hi folks.
              See this SU file for ideas.
              Curved ramp.skp
              • W
                wyatt
                Chris,
                Awesome script and tutorial. I somehow have missed downloading Shape Bender. Off to get it now...
                Wyatt
                • GaieusG
                  Also, if you add the 100mm thickness to a flat plane, you can always move one end face up like this
                  unfortunately, SU's autofold function is not always flawless so you still need a bit of cleanup for a nice, final result
                    Some plugs can make that πŸ˜‰
                    Follow and Keep, Extrusion along a path (1001bits)... Extrude Edges by Edges, Extrude Edges by Rails, Component Stringer, FredoScale etc..Shape Bender πŸ˜‰ ...
                    Depending of what do you want exactly! πŸ’š
                    • troyhomeT
                      troyhome
                      [flash=800,600:3fc6wrdl]http://www.youtube.com/v/tGHTIOMm_34&hd=1&fs=1[/flash:3fc6wrdl]
                      Chris, as always- great scripts and great video tutorials!
                      I had a DUHHHH moment when i saw you use the erase tool to UN-smooth geometry! Didn't know you could do that- i thought it could only smooth it πŸ˜„
                      IOviz.com
                      SU Pro 2024 PC
                      • Chris FullmerC
                        Hehe, glad I could provide you with a "DUH" moment of your own.
                        I've always thought that watching how other people work in real time is an eye opening experience.
                          d12dozr
                          +1
                          Love the tut, Chris πŸ˜„
                          http://goo.gl/f7ooYh
                            jonathanb
                            That you tube tutorial was really helpful, i think i will get shape bender too. Seems like a relatively straight forward method especially with the help of a voice over!
                            There are so many ways to make the curved ramp i take it!
                            Jonathan
                              I've added an example of using EEbyRails to make a simple OR complex ramp on a curve - see here http://forums.sketchucation.com/viewtopic.php?p=206584#p206584
                              All you need is a curve for the cross-section [profile] and curves for the two side rails - rotated in 3D so that the landing is as you want [probably level?]...
