    Front face vs back face
    10 Posts 6 Posters 706 Views 6 Watching
      was there some rule about the order of the vertices that determined the orientation of front vs back?
        remus
        I have a vague recollection of it being bogus, although that might be my imagination.
        • Chris FullmerC Offline
          I believe TIG posted an explanation of this recently. I forgot what the thread was about though.
          • W Offline
            Whaat
            From my recollection:
            face.outer_loop.vertices will give you the vertices in counter-clockwise order wrt to the front side of the face
            face.vertices will give you vertices in no particular order
              face.outer_loop.vertices ### is a counter-clockwise collection...
              loops=face.loop-[face.outer_loop] ### other internal loops...
              loops.each{|loop|verts=loop.vertices} ### each of these 'verts' collections is clockwise...
                So if the vertices are added clockwise vs counter-clockwise affects front vs back when you create faces?
                  tomasz
                  In SU there is right hand rule used. If the normal of a face is pointing towards you, the vertices has to go counter-clockwise.
                    "Towards you"? Where does one assume "you" are located? I take it it's related to the global axes?
                    • W Offline
                      Whaat
                      'You' being on the side of the face pointed at by the front face normal. Global axis is irrelevant.
                        The right-hand rule: imagine holding the face's normal vector [axis' if you will] in your right-hand, with you thumb pointing in the + direction. Your fingers will curl counter-clockwise.
                        That rule applies to a face's outer_loop's vertices array.
                        It also applies to rotations etc about an axis etc...
                        It's opposite for any inner_loops vertices array - i.e. clockwise.
                        It doesn't matter which direction/order the face's edges were originally drawn: an array of the loop's vertices is always returned ordered in that particular way - ccw or cw.
                        The vertices' order does affect the face's normal when drawing faces: however, SUp does seem to have that overriding rule to draw a face with its normal pointing down IF the face's Z=0 !!!
