    Menu Options Keeps Graying Out!
    55 Posts 15 Posters 9.3k Views 15 Watching
      chango70
      I hope they fix this soon. It is really getting on my nerves.
      • F Offline
        flyashy
        @alpro said:
        Don't think its a menu issue, I just finally upgraded last week and decided to keep my menus and toolbars as clean as possible and have only five plugins that I use most often insta....
        Mike
        Hi I started getting this since a few days too. I recently installed quite a few scripts and obviously it's one of them doing this. I thought it was lines2cyl.rb doing it because the grayed out right click seemed to happen soon after using it from the tools menu. so I removed the ruby from the plugins folder. but lo & behold, very weird, the 'convert lines/arc/etc to cylinders' command in toolsmenu is still there and refuses to go away. it's a little strange because it's supposed to be in the plugins menu isn't it?
        Now I can't even get rid of it to check if that is the one doing it.
        Sometimes the menu reactivates if I use 'Remove unsused edges' from the edit menu. ( I don't know what script does this one). sometimes not.
        So, alpro, if you just have five plugins could you list them? That way we can probably figure out the ones which are common and see if any of this makes sense.
        ta,
        flyashy
          I don't think it's one particular.
          It is reproducible without any plugins at all, if you just keep right-clicking on some geometry. Though, more plugins appear to trigger it more quickly.
          • F Offline
            flyashy
            Oh, so is this a bug with the upgrade?
              I've seen this with 7.0 - think even 6.0.
              But I think we're seeing this more as more and more people use more plugins which increases the chances for the bug to trigger.
                Just to clarify:
                This is what I'm, sure of:
                • I'm sure that this occurred before 7.1
                • I'm sure that this can be triggered without any plugins by just continuously right-clicking
                I'm guessing:
                • that the more plugins the more likely hood it'll trigger
                • that it's something that exhausts the handles for menu items in SU
                By now we should have seen a pattern if there was one particular plugin that causes it.
                A version of my Selection Toys appeared to greatly increase the chance of triggering the bug. The only thing I had added to that version was two menu items per layer. Which is why I'm suspecting some limit to the amount of menu items SU can handle. (It's not just that - as mentioned: it can be triggered by repeatedly right-clicking. But but think in the matter of right-clicking repeatedly is that the old-context-menu isn't released properly. <- guessing)
                • F Offline
                  flyashy
                  Oh you posted this while I was typing..
                  So I guess I'll just go easy on the right click for a while then..the funny thing is that when the context disables even the shortcut keys don't respond..so it's probably the handlers as you mentioned..
                  thanks,
                  flyashy
                    Although currently I don't have too many plugins installed, I have to say that I have never had this happen (heard enough about it on several forums I admit). So there is maybeanother chance that certain hardware configurations also play some role in this?
                      If you right-click on some geometry repeatedly? (Don't do anything other than right-click for about ~10-30 times.) You see it happen then? I've seen that on all the machines I've tested - which all have had different hardware and OS.
                        Hm... Interesting. Yes, it does grey out if I keep right clicking like a madman. 😲
                        Never noticed with a "normal" workflow however - and lately I had models with a lot of texture positioning, right clicking and such.
                        You guys are crazy. How would one get into such an experiment? πŸ˜•
                        • Alan FraserA Offline
                          Alan Fraser
                          I can't say that I've seen this behaviour either...even right-clicking about 50 times. I also have far more scripts installed than I could ever have any use for. I don't doubt that it's happening...just that I can't trigger it. If I ever do see it, I'll try to remember what I've just changed.
                          3D Figures
                            alpro
                            thomthom, you've had this happen in v6? This never, not once happened to me in v6. And I don't think my workflow has changed to where I'm right clicking alot more but this happens quite a bit to me in v7. Really fustrating to the point I may just go back to v6, its a real drag to be getting into a model and flowing along, then bam, not be able to do anything and have to restart Su. Can't believe more people aren't complaining about this, maybe it doesn't happen as often to some people?
                            Mike
                              I dunno who came up with that. I read it in one of the many threads on this. Only reliable way to reproduce it so far.
                              I haven't experienced this myself. But someone else in my office experienced it. Think he was using SU6 then.
                              Though it does seem the reports of this has increased after 7.0. Not sure if it's something SU7 changes, if it's more users here at the forum, or that plugin use is getting more common. Hard to tell.
                              But no, it doesn't happen to everyone. It's an obscure issue. But I know that Google is well aware of it - but they've been having big problems reproducing it - which makes debugging it very hard.
                                Found out some cause+effect for this greying-out of context-menu items... [v7.1M1]
                                I had thought it something to do with Twilight [it started with me about the time I installed TW BUT then lots of other things happened around then too]... BUT it keeps happening even with TW disabled and uninstalled - so it's not that...
                                BUT if I make some components and place them, copy edit, scale etc etc the context-menu remains OK.
                                If I explode just one of these component instances - now I get some greyed-out context-menu items that should be active!!!
                                A mystery as to why this happens... but I can get this greying-out of items to happen consistently, at the point after I explode a component instance... πŸ˜•
                                Hope this helps solve this...
                                  Explode on any model? Or a particular model?
                                    Occurs in all models - even brand new ones...
                                    Try it, open a new model make a few simple components, copy scale etc - context-menu is OK.
                                    Explode one of the Instances - you now have wrongly greyed-out context-menu items !
                                    Undoing the explode doesn't get the menu fixed !
                                    Only corrected by closing SUp and reopening model.
                                    Happens for me consistently...
                                      Can't reproduce.
                                      Only time I've ever seen it on my own machine - excluding repeated right-clicking - was with my Selection Toys when I made two context menu items per layer.
                                      It seems that the scenario where this bug crops up vary from user to user.
                                        Might be a clash of certain script combinations ?
                                        Haven't got to the bottom of it yet... πŸ˜’
                                          Right-clicking will reproduce it without any plugins. But I suspect that plugins increase the chance of triggering it.
                                          • F Offline
                                            flyashy
                                            Hi Tig,
                                            nope. didn't happen when I made copies of components and exploded one instance. In fact I went around like a madman right-clicking everything in sight too just to make sure.
                                            The only difference being I'd emptied my plugins directory. Just moved everything including the examples folder to a temp folder.
                                            I also opened up some of the fairy complex models to check if it was the complexity of the file that prompted this..nothing. No greying out.
                                            Could it be about scripts that have submenus in the context menu? I did not have any scripts that had submenus before this started happening.
                                            thanks,
                                            flyashy
                                            • 3 / 3
