    Any SU render engines that renders distorted textures?
    97 Posts 17 Posters 26.4k Views 17 Watching
      @thomthom said:
      • What UV values do you send to you renderer?
      When all textures has been loaded to TW I use:
      					uvHelper=face.get_UVHelper(true, false, tw)
      > 					point_pos=mesh.point_at(p).transform!(trans.inverse) #trans='nested transformation' of the parent
      > #thanks to Stefan Jaensch for figuring out that this trans has to be inverted and applied here
      > 					uv=uvHelper.get_front_UVQ(point_pos)
      @thomthom said:
      • If the render material has a bumpmap applied to it - how is that handled? Won't you end up with mismatching bump?
      I use same UVs. I assume that the bumpmap is the same size as the main texture.
      where do the p variable come from?
      • T
        tomasz
        It is an index(starting from 1) of a point in a PolygonMesh. You get the Polygon mesh from a face.mesh #.
        You probably can get point position in other way.
          Also, why don't you use uv = mesh.uv_at(p, true)? Appears it would give the same result.
            If you use my Probes plugin: http://forums.sketchucation.com/viewtopic.php?f=323&t=21472#p180592
            Press Tab to see raw UVQ data
            By default it will use UVHelper to get the UV data
            Press F2 to make it sample the data from the PolygonMesh
            From my testing, the data never differs.
            UVHelper seem to be made to sample UV data from a Face.
            But if you have a PolygonMesh of the Face, it includes the UV data (provided you asked for that when you used face.mesh).
            • T
              tomasz
              I simply use UVHelper because it seems to be designed to this task. What would be the purpose of it otherwise? 👊
              I am not so sure if it would give same result for two distorted faces sharing same distorted texture (the last pair in the modified skp test scene).
              BTW. I have found that there is some memory leak when using UVHelper, at least those objects are not being dumped well (rubbish collector). In my exporter I stay away from UVHelper as long as I can. I read uv coordinates in all other scenarios using uv_at.
              • T
                tomasz
                Ok. Try this. Just load a face with distorted texture to the TW, then you will see the difference if you will use same TW to get uv from UVHelper.
                What you have written is true as long as you use blank TW. It gives coordinates in relation to the original 'picture', but when you load a face to TW then it 'makes it unique inside TW' therefore uvs change.
                It looks like this thread would better fit in the new developers section 😄
                • C
                  Chris_at_Twilight
                  I have never received false negatives by checking the 1.0 with enough precision.
                  Really? That's good to know. That's a much faster test.
                  As far as why some projected textures aren't distorted, I think Al and thomthom are both right, given the respective circumstance. It could be that the texture is not truly 'distorted' as Al suggest; it could be that the level of subdivision is high enough that you just don't see the distortion, like thomthom said.
                  And Tomasz hit it right on the head as far as using tw and uvhelper; you have to make sure you are using a tw 'loaded' with the face in question, before using it in the uvhelper.
                  http://www.TwilightRender.com
                    Use a TextureWriter to get UV data? ❓
                    • T
                      tomasz
                      It is the required parameter: uvHelper=face.get_UVHelper(true, false, **tw**)
                        Aaah!!! That's why it asks for a TW. Duh!
                        That fills in a great hole in the API doc.
                        Thanks Tomaz!
                          Here's a simple test I did. (doesn't take into account nested groups etc)
                          but it's a rough ruby version of Make Unique.
                          uv_make_unique.rb
                          distort test.skp
                          • AdamBA
                            AdamB
                            Just a quick word as to what you're seeing.
                            The texture coordinates in SU are mostly 2d but there is support for projected textures in which the 3rd element of the texture coordinate is a projection. ie by dividing through by the 3 element you get a 2d texture coordinate.
                            You can get a ok approximation by doing the projection at the vertices and then interpolating across the polygon in 2d (this is what LightUp does), or you can interpolate the 3-element texture coordinate and do the divide at each pixel which is slower but you'll get the right answer. Not sure there are many renderers that do that.
                            Adam
                            • AdamBA
                              AdamB
                              Oh, and the corollary of this is that if you subdivide the faces into smaller pieces, you'll get a progressively more accurate rendering. So try cutting the distorted quad into 16 quads.
                              Adam
                              • T
                                tomasz
                                SU is using OpenGL. Does it mean that SU, for its own 'rendering', does same interpolation and sends the 'unique' texture to OpenGL?
                                • Al HartA
                                  Al Hart
                                  I suspect so - it is a lot faster to create the distorted image as a bitmap, and then send it to OpenGL - rather than starting to sub-divide faces.
                                  Also, that would explain why SketchUp makes to pre-distorted image available to 3DS output and to us.
                                  Al Hart
                                  IRender nXt from Render Plus
                                  • AdamBA
                                    AdamB
                                    No, it means SU sends 3-component texture coordinates to OpenGL and allows OpenGL to interpolate and divide at each pixel.
                                    But as Al says, given you can 'bake in' your projection to a unique texture once your happy, its not a big deal.
                                    Adam
                                    • C
                                      Chris_at_Twilight
                                      Just as Adam says, OpenGL provides methods not just for 2 coordinates (UV), but 3 and even 4. glTexCoord3f, glTexCoord4f
                                        I'm curious: for those render engines that renders distorted textures. What's the result if you add a bump map, like the one attached. Exaggerated bump so it's clearly visible.
                                        • Al HartA
                                          Al Hart
                                          "True" bump maps, where you assign the bump as a second texture, do not work, because SketchUp gives you a pre-distorted texture, which then works with UVs of 0,0, and 1,1, to use for the main texture. But SketchUp does not give you information on how to distort the second texture.
                                          Here the carpet texture is distorted properly, but the bump map is not distorted.
                                          "auto-bump" where a single texture is used for the color and for the bump map, does work, because the bump map is distorted as well.
                                          Here the bump map effect matches the distortion of the image in SketchUp.
                                          (The disgtorted SketchUp image was used as the bump map.)
                                          Distorted SketchUp Material
                                          This could be solved for multiple texture bump maps - but you would have to let SketchUp distort the main texture and then let SketchUp distort the bump map texture as well.
                                          Al Hart
                                            That's what I suspected. Which is a problem.
                                            • 5 / 5
