    Any SU render engines that renders distorted textures?
    97 Posts 17 Posters 20.9k Views 17 Watching
    • FrederikF Offline
      Frederik
      Tomasz - are you sure that the distorted texture isn't being exported as a seperate (unique) texture...?? πŸ˜•
      Cheers
      Kim Frederik
        tomasz
        @chris_at_twilight said:
        As for detecting when textures are distorted... I agree that you will very often see 'z' or 'q' (UVQ) values that are not 1.0, but I think you can get false negatives that way. Meaning, you can have distorted textures where the Q is not any value but 1. (This is speculation only)
        I have never received false negatives by checking the 1.0 with enough precision. The posted TheaExporter sample uses TextureWriter and UVHelper. They work in tandem. The texture writer will create additional ('virtual' unique) texture only when necessary. Sometimes TW can create just a single 'virtual' unique texture for two faces that are parallel to each-other an share same distorted texture.
        I have spent many hours to understand how the TW works. There is no point in writing every single face to the TW, because it will take a lot of time. I recognize first if a texture is distorted Q!=1.0.
        if ((uvq.z.to_f)*100000).round != 100000
        If it is, it goes to TW, which usually leads to a creation of a unique texture. If it doesn't one have to read the 'handle' returned by the TW. It points to the position of a texture in TW 'stack'.
        It would be interesting to learn how SU DEVELOPERS use additional Q coordinate to add perspective distortion to a texture. I have done a search and haven't found any other software using this type of projection. I hope Google staff would share the trick with authors of redering engines so a use of TW, which is creating additional textures == materials in a renderer, won't be necessary.
        I have implemented also a method without UVHelper using uv=[uvq.x/uvq.z,uvq.y/uvq.z], but the key is actually to learn how SU applies the projection. As far as I am aware no rendering software uses UVQ.
        @frederik said:
        Tomasz - are you sure that the distorted texture isn't being exported as a seperate *(unique)*texture...?? πŸ˜•
        The method uses TW which crates 'a second texture'==additional 'Thea material'. I have not found a model so far that gives me wrong projection. Unfortunately the method forces creation of multiple Thea materials.
        EDIT. I modified Thomas' test model. I have added two additional things - a group with a default mat painted face and a second face with distorted texture which will have same handle in the TextureWriter as the one right bellow.
        UVMappingTest+.skp
          why are these working?
          Maybe you curved surface is subdivided into so many smaller faces that deviation isn't visually noticeable?
            Tomasz: When you discover a distorted texture (from the Q value), and use TW to write out a unique material;
            • What UV values do you send to you renderer?
            • If the render material has a bumpmap applied to it - how is that handled? Won't you end up with mismatching bump?
            • FrederikF Offline
              Frederik
              Yeah - that's what I thought...
              This is - again - how everyone else is able to handle it...
              However, I believe thomthom is trying to find out if this can be handled differently...
              @thomthom said:
              Yea, Make Unique generates a new texture and gives the face new UV co-ordinates.
              What I'm trying to find out though, if there is any renderers that actually handles this. More importantly, I'm interesting in how they handle it.
              IMHO, I hardly never see distorted textures used and thereby it has never been a great issue, certainly not a dealbreaker...
              Cheers
              Kim Frederik
                tomasz
                When all textures has been loaded to TW I use:
                					uvHelper=face.get_UVHelper(true, false, tw)
                					point_pos=mesh.point_at(p).transform!(trans.inverse) #trans='nested transformation' of the parent
                #thanks to Stefan Jaensch for figuring out that this trans has to be inverted and applied here
                					uv=uvHelper.get_front_UVQ(point_pos)
                I use same UVs. I assume that the bumpmap is the same size as the main texture.
                  where do the p variable come from?
                    tomasz
                    It is an index(starting from 1) of a point in a PolygonMesh. You get the Polygon mesh from a face.mesh #.
                    You probably can get point position in other way.
                      Also, why don't you use uv = mesh.uv_at(p, true)? Appears it would give the same result.
                        If you use my Probes plugin: http://forums.sketchucation.com/viewtopic.php?f=323&t=21472#p180592
                        Press Tab to see raw UVQ data
                        By default it will use UVHelper to get the UV data
                        Press F2 to make it sample the data from the PolygonMesh
                        From my testing, the data never differs.
                        UVHelper seem to be made to sample UV data from a Face.
                        But if you have a PolygonMesh of the Face, it includes the UV data (provided you asked for that when you used face.mesh).
                          tomasz
                          I simply use UVHelper because it seems to be designed to this task. What would be the purpose of it otherwise? πŸ‘Š
                          I am not so sure if it would give same result for two distorted faces sharing same distorted texture (the last pair in the modified skp test scene).
                          BTW. I have found that there is some memory leak when using UVHelper, at least those objects are not being dumped well (rubbish collector). In my exporter I stay away from UVHelper as long as I can. I read uv coordinates in all other scenarios using uv_at.
                            tomasz
                            Ok. Try this. Just load a face with distorted texture to the TW, then you will see the difference if you will use same TW to get uv from UVHelper.
                            What you have written is true as long as you use blank TW. It gives coordinates in relation to the original 'picture', but when you load a face to TW then it 'makes it unique inside TW' therefore uvs change.
                            It looks like this thread would better fit in the new developers section πŸ˜„
                              Chris_at_Twilight
                              Really? That's good to know. That's a much faster test.
                              As far as why some projected textures aren't distorted, I think Al and thomthom are both right, given the respective circumstance. It could be that the texture is not truly 'distorted' as Al suggest; it could be that the level of subdivision is high enough that you just don't see the distortion, like thomthom said.
                              And Tomasz hit it right on the head as far as using tw and uvhelper; you have to make sure you are using a tw 'loaded' with the face in question, before using it in the uvhelper.
                              http://www.TwilightRender.com
                                Use a TextureWriter to get UV data? ❓
                                  tomasz
                                  It is the required parameter: uvHelper=face.get_UVHelper(true, false, **tw**)
                                    Aaah!!! That's why it asks for a TW. Duh!
                                    That fills in a great hole in the API doc.
                                    Thanks Tomaz!
                                      Here's a simple test I did. (doesn't take into account nested groups etc)
                                      but it's a rough ruby version of Make Unique.
                                      uv_make_unique.rb
                                      distort test.skp
                                      • AdamBA Offline
                                        AdamB
                                        Just a quick word as to what you're seeing.
                                        The texture coordinates in SU are mostly 2d but there is support for projected textures in which the 3rd element of the texture coordinate is a projection. ie by dividing through by the 3 element you get a 2d texture coordinate.
                                        You can get a ok approximation by doing the projection at the vertices and then interpolating across the polygon in 2d (this is what LightUp does), or you can interpolate the 3-element texture coordinate and do the divide at each pixel which is slower but you'll get the right answer. Not sure there are many renderers that do that.
                                        Adam
                                        • AdamBA Offline
                                          AdamB
                                          Oh, and the corollary of this is that if you subdivide the faces into smaller pieces, you'll get a progressively more accurate rendering. So try cutting the distorted quad into 16 quads.
                                          Adam
                                            tomasz
                                            SU is using OpenGL. Does it mean that SU, for its own 'rendering', does same interpolation and sends the 'unique' texture to OpenGL?
                                            • 4 / 5
