    Any SU render engines that renders distorted textures?
    97 Posts 17 Posters 24.7k Views 17 Watching
      Important question:
      If most other renders use 3 anchor points for UV mapping, how is a distorted texture defined? How can you define a distorted texture using only three points?
        sepo
        On side note Podium will render photomatch (distorted textures) after SU exports to 3ds and import back.
        Tried LightUp and it also does not render correctly distorted texture.
          That would be due to what Jeff described: http://forums.sketchucation.com/viewtopic.php?f=80&t=23947&start=15#p204562
          That when exported to .3ds each face gets a unique texture - So when importing back you have lots of new textures where they then are not distorted any more.
          • GaieusG
            I exported the model to kmz and reimported it. Interestingly, it created a unique material of the distorted image by itself and this rendered correctly (Twilight in this case but I guess it wouldn't matter in this case of a unique texture)
              It only creates a unique texture for the distorted? Not for the others?
              • F
                frv
                Maxwell renders distorted textures just fine.
                Francois
                  And how does Maxwell integrate with SU?
                    Hmm.. interesting programming discussion which seem to be about similar issue: http://old.nabble.com/Texture-map-a-polygon-td26394710.html
                    • C
                      Chris_at_Twilight
                      An export to Collada for the entire scene produces 1 undistorted texture and 1 distorted texture.
                      Francois
                      Maxwell can render SU files directly? Or does it import .obj, .3ds, .dae? Because if it just imports, it's as was discussed above: SU produces "pre-distorted" images. The render is just using the pre-distorted image, which any renderer can.
                      http://www.TwilightRender.com
                      • C
                        Chris_at_Twilight
                        @thomthom said:
                        So question is: how can SU's data be converted into a format that most renderer's and external program uses?
                        The fact that all of SU's built-in export methods use the "pre-distorted", unique texture method, my guess is that it can't be done (unless the renderer itself supported the same interpolation technique).
                          That's my fear.
                          Would be interesting to know what texture technique Google uses. Might try to give some of the Googleheads on this forum a prod.
                          • C
                            Chris_at_Twilight
                            http://en.wikipedia.org/wiki/Barycentric_coordinates_%28mathematics%29
                            Maybe some thoughts. Barycentric on a triangle is a very common application. But check out the Barycentric on a tetrahedra (barycentric in 3D). Maybe it's how SU uses it?
                            • jeff hammondJ
                              @chris_at_twilight said:
                              Huh. The .3ds format only supports triangles (I think), so there is a way to represent the texture interpolation used by SU using only 3 UV coordinates (and the .3ds export knows it! )
                              not sure if this will trigger any thoughts with you guys (and really, i don't understand much of what you're talking about) but..
                              if everything is triangles in SU prior to messing with the UV mapping then it will render correctly..
                              Sphere after using triangulatefaces.rb
                              After importing a texture and applying it to the sphere
                              use UVtools spherical option on the texture
                              resulting render in indigo.. no exporting or unique textures
                                richcat
                                IRendernxt straight render in sketchup, you'll have to ask Al how?
                                • C
                                  Chris_at_Twilight
                                  @Jeff: Maybe because everything is already triangles, the UV coordinates that SU generates are 'compatible' with the traditional triangular UV techniques employed by other applications. So what you see in SU, is what you get in the render. Of course, it could just be how UVTools does the sphere mapping that makes it more compatible?
                                  You are more than welcome to ask. I won't be surprised if they use the same "pre-distorted" image technique that the SU exporters use.
                                  • soloS
                                    Yup, can confirm Irender aim and renders it correctly.
                                      dedmin
                                      I tried the last version of the IrendernXT, but had a lot of problems - slow response of the interface, sometimes when adjusting textures all goes white, when tried to load a plant from the library SketchUP crashes and etc.
                                      • Al HartA
                                        Al Hart
                                        The Distorted texture is a nice feature of SketchUp - the ability to take a photo of a house for instance, from an angle, and then distort it onto the actual house so that it looks correct. SketchUp provides tools to get these distorted textures and UV coordinates properly, but it did take a lot of time and effort to figure it out and get it to work properly.
                                        SketchUp made this distortion even easier to use (without knowing that you are doing it) with their Photo Match techniques.
                                        Here is a 3D Warehouse model where the house image was placed using Photo Match. Some renderers process it correctly and some renderers do not recognize and process the distorted texture.
                                        http://sketchup.google.com/3dwarehouse/download?mid=9e0b93c387cad06c93a794ea4e64d35b&rtyp=lt&ctyp=other&ts=1251394213000
                                        3D Warehouse model
                                        Al Hart
                                        IRender nXt from Render Plus
                                        • jeff hammondJ
                                          it looks ok, right? 😄
                                          so what's irender doing so differently than the other renderers? or does it export a bunch of textures prior to rendering?
                                          • N
                                            notareal
                                            My quess is that it does export predistorted textures (like kmz export). So for Thomas' scene you will get two different textures when rendered. Sorry, have no irender, so cannot test. Wonder if it saves temp textures on disk before rendering...
                                            • 2 / 5
