    [Plugin] VisMap - Layer/Scene Visibility Map
    126 Posts 15 Posters 50.3k Views 15 Watching
      Dmitry Ushakov
      Edson,
      Thank you for reporting this problem. Could you please say what else plugins do you use in SketchUp and how often this problem happens?
      Sincerely yours,
      Dmitry Ushakov
      Director of Product Management
      LEDAS Ltd.
      http://www.DrivingDimensions.com - parametric plugins for SketchUp and Rhino
      • EdsonE Offline
        Edson
        @dmitry ushakov said:
        Edson,
        dmitry,
        i use a huge number of plugins. if you want i can make screen shots of my folder. this problem never ocurred before. it only came up when i ran the file martin asked me to.
        http://www.mahfuz.arq.br
          MartinRinehart
          Dmitry,
          Edson is unable to run my VisMap Ruby on some large models. I wrote a 20-line reporter that, I hoped, would help find the problem. Edson copied my little bit of code into "t.rb" on his machine and loaded it in the Ruby Console.
          At least that was the plan. That's what Edson's screenshot shows. Somehow, your LEDAS Driving Dimensions plugin was triggered, instead of the little reporter. Any idea how LDD could have been triggered?
          Martin
            Dmitry Ushakov
            Edson, Martin,
            Thank you for these explanation. The reason of the bug seems to be clear - our plugin tries to update a model, but fails since the model contains some corrupted piece of data (not surprising, since Edson uses "a huge number of plugins"). We are going to fix this behavior in the forthcoming version of our LDD plugin by checking the correctness of our data before updating a model.
            However, I have to ask another question: when exactly the problem happens? When you open a model or when you load 't.rb' in the Ruby console?
            Sincerely yours,
            Dmitry Ushakov
            LEDAS Ltd.
            • EdsonE Offline
              Edson
              only when I load 't.rb' in the Ruby console.
                Dmitry Ushakov
                Edson, please try the newest version (1.2) of our Driving Dimensions plugin.
                Your problem should be fixed, since we have resolved several compatibility issues.
                You can download it here.
                Sincerely yours,
                Dmitry Ushakov
                LEDAS Ltd.
                • EdsonE Offline
                  Edson
                  thanks, dmitry. i downloaded 1.2 30s ago... i will let you know how it goes.
                  • EdsonE Offline
                    Edson
                    just tried to run vismap after having updated the driving dimensions plugin. there was an error but it does not seem to be related to DD.
                      MartinRinehart
                      That is VisMap doing exactly what it is supposed to do: reporting that your model has an error. It is trying to loop through something (the "each" method) that doesn't exist.
                      Can you send me the model? (Too big? Break into pieces. Send pieces. I'll rebuild.)
                      • EdsonE Offline
                        Edson
                        martin,
                        i have sent you a model via yousendit. however, it is hard to believe all my models have problems. i tried vismap on more than 10 with the same result. i am inclined to think vismap has difficulties to handle large models.
                        regards,
                          MartinRinehart
                          @edson said:
                          martin,
                          Don't know that service. Do I have to contact someone?
                          Your workflow: do you start every model fresh, or do you grab pieces of existing models to create new?
                          Either way, with a problem model in hand, it shouldn't take long to fix the model or VisMap. Look forward to it.
                          • EdsonE Offline
                            Edson
                            @martinrinehart said:
                            @edson said:
                            martin,
                            martin,
                            you do not have to do anything. you will receive an email with a link to download the file.
                            i start my models from zero but along the way i may import pieces from others.
                              MartinRinehart
                              Nothing yet, Edson. Gmail allows messages (including attachments) up to 25MB. Zip with maximum compression reduced a model I tested by 60%. Can you Zip a model and email it to me? MartinRinehart at gmail dot com.
                              • EdsonE Offline
                                Edson
                                very strange, martin. i sent you the skippie on november 26th. could you check the image below to make sure i addressed it correctly? anyway, i am uploading the file to 4shared and will send you the link shortly.
                                  Jim
                                  In gmail, that email probably went to your spam folder.
                                    MartinRinehart
                                    Rinehart
                                    • 5 / 7
