    [Plugin] VisMap - Layer/Scene Visibility Map
    126 Posts 15 Posters 68.9k Views 15 Watching
      MartinRinehart
      @edson said:
      martin,
      i have sent you a model via yousendit.
      Don't know that service. Do I have to contact someone?
      @edson said:
      it is hard to believe all my models have problems.
      Your workflow: do you start every model fresh, or do you grab pieces of existing models to create new?
      Either way, with a problem model in hand, it shouldn't take long to fix the model or VisMap. Look forward to it.
      • EdsonE
        Edson
        @martinrinehart said:
        @edson said:
        martin,
        martin,
        you do not have to do anything. you will receive an email with a link to download the file.
        i start my models from zero but along the way i may import pieces from others.
        http://www.mahfuz.arq.br
          MartinRinehart
          Nothing yet, Edson. Gmail allows messages (including attachments) up to 25MB. Zip with maximum compression reduced a model I tested by 60%. Can you Zip a model and email it to me? MartinRinehart at gmail dot com.
          • EdsonE
            Edson
            very strange, martin. i sent you the skippie on november 26th. could you check the image below to make sure i addressed it correctly? anyway, i am uploading the file to 4shared and will send you the link shortly.
              Jim
              In gmail, that email probably went to your spam folder.
                MartinRinehart
                Rinehart
                • 7 / 7
