    [Plugin] VisMap - Layer/Scene Visibility Map
    126 Posts 15 Posters 63.0k Views 15 Watching
      MartinRinehart
      @edson said:
      it worked every time until all the layers had been copied.
      EDIT: however, the error reported above is happening with every file i open.
      I'm not certain whether this is a size or a Mac issue. This morning I've been making a movie promoting a club I've designed. Could you try it? If your problem reappears, we'll know it's platform-related.
      Try http://www.MartinRinehart.com/download.html
      The last of the four downloads, rf.zip, contains "club.skp". Open it, add a couple scenes and VisMap it. (This was my first SketchUp model, so don't judge it too harshly, please.)
      • EdsonE Offline
        Edson
        martin,
        i created some scenes and tried it with your file. it worked. your file has 3.8 Mb, mine have all more than 30Mb.
        http://www.mahfuz.arq.br
          MartinRinehart
          I am not understanding this. The VisMap Ruby code is getting an error. It collects an array of layer names, an array of scene names and a string with one "V" or "I" for each scene/layer intersection. That is a very small amount of data, even for your 30MB+ models. Hmmmm.
          # /models/rubies/t.rb
          require 'sketchup'
          model = Sketchup.active_model
          layers = model.layers
          scenes = model.pages
          puts
          puts 'This model has ' + (layers.length).to_s + ' layers and ' + (scenes.count).to_s + ' scenes.'
          i = 0
          scenes.each do |s|
          	puts
          	puts
          	puts 'Processing scene ' + (s.name).to_s
          	if s.layers.length > 0
          		puts 'Invisible layers in ' + (s.name).to_s + ' are;'
          		s.layers.each do |l|
          			print l.name + ', '
          	else
          		puts (s.name).to_s + ' has no invisible layers.'
          	puts
          Above is a little reporter that lists each scene in a model and the layers within that scene that are invisible. Try it on my small model to make sure it works. Select All here, copy to clipboard, paste into editor, save to any convenient directory as "t.rb". With small model open in SU, open the Ruby Console window. In the white input line enter:
          load '/where/you/chose/t.rb'
          and press Enter. You should get a report. (Expand the Ruby Console a lot to view it.)
          Assuming that works, load one of your models into SU. In Ruby Console, up arrow, then Enter. That will start the report on your model. (Good time here to get a fresh cup of coffee.) It will run successfully, to completion of your last scene, or it will crash. I want it to crash, and I want to see the error message.
          If runs to completion, please ZIP up and send me a copy of enough of one of your models to reliably refuse to VisMap. MartinRinehart at gmail dot com. And thanks again.
          • EdsonE Offline
            Edson
            martin,
            i followed your instructions but the result was different from what you describe above. there was not a long report nor did sketchup crash. all i got is what you can see below.
              MartinRinehart
              Odd. That error comes when the code says "if foo < bar" but "foo" is nil (doesn't exist). Then it's a traceback showing that the error is in "ldd_remake_labels" which was called by "addObservers" which was called by ... Those numbers are line numbers where the functions are found in the source file.
              All of which is to say that you somehow ran some Ruby entirely other than the wee bit in my post.
              Did I say SketchUp would crash? Didn't mean it. The little report-writing Ruby would crash as per your example, but with a line number in the 0 to 20 area.
              Could you try it again, using some other directory and/or name? Thanks again.
              Edit: Another possibility. My line "require 'sketchup'" loads the "sketchup.rb" library. That crash could be coming from deep in that library. Make sure you have a model loaded that VisMaps successfully before you try again.
                Jim
                Martin,
                the 'true' means your script loaded successfully, twice, but... where did the output go?
                ldd_ is LEDAS Driving Dimensions plugin. I'll pm Dmitry and see if he can take a look here and see what is happening.
                  Dmitry Ushakov
                  Edson,
                  Thank you for reporting this problem. Could you please say what else plugins do you use in SketchUp and how often this problem happens?
                  Sincerely yours,
                  Dmitry Ushakov
                  Director of Product Management
                  LEDAS Ltd.
                  http://www.DrivingDimensions.com - parametric plugins for SketchUp and Rhino
                  • EdsonE Offline
                    Edson
                    @dmitry ushakov said:
                    Edson,
                    dmitry,
                    i use a huge number of plugins. if you want i can make screen shots of my folder. this problem never ocurred before. it only came up when i ran the file martin asked me to.
                      MartinRinehart
                      Dmitry,
                      Edson is unable to run my VisMap Ruby on some large models. I wrote a 20-line reporter that, I hoped, would help find the problem. Edson copied my little bit of code into "t.rb" on his machine and loaded it in the Ruby Console.
                      At least that was the plan. That's what Edson's screenshot shows. Somehow, your LEDAS Driving Dimensions plugin was triggered, instead of the little reporter. Any idea how LDD could have been triggered?
                      Martin
                        Dmitry Ushakov
                        Edson, Martin,
                        Thank you for these explanation. The reason of the bug seems to be clear - our plugin tries to update a model, but fails since the model contains some corrupted piece of data (not surprising, since Edson uses "a huge number of plugins"). We are going to fix this behavior in the forthcoming version of our LDD plugin by checking the correctness of our data before updating a model.
                        However, I have to ask another question: when exactly the problem happens? When you open a model or when you load 't.rb' in the Ruby console?
                        Sincerely yours,
                        Dmitry Ushakov
                        LEDAS Ltd.
                        • EdsonE Offline
                          Edson
                          only when I load 't.rb' in the Ruby console.
                            Dmitry Ushakov
                            Edson, please try the newest version (1.2) of our Driving Dimensions plugin.
                            Your problem should be fixed, since we have resolved several compatibility issues.
                            You can download it here.
                            Sincerely yours,
                            Dmitry Ushakov
                            LEDAS Ltd.
                            • EdsonE Offline
                              Edson
                              thanks, dmitry. i downloaded 1.2 30s ago... i will let you know how it goes.
                              • EdsonE Offline
                                Edson
                                just tried to run vismap after having updated the driving dimensions plugin. there was an error but it does not seem to be related to DD.
                                  MartinRinehart
                                  That is VisMap doing exactly what it is supposed to do: reporting that your model has an error. It is trying to loop through something (the "each" method) that doesn't exist.
                                  Can you send me the model? (Too big? Break into pieces. Send pieces. I'll rebuild.)
                                  • EdsonE Offline
                                    Edson
                                    martin,
                                    i have sent you a model via yousendit. however, it is hard to believe all my models have problems. i tried vismap on more than 10 with the same result. i am inclined to think vismap has difficulties to handle large models.
                                    regards,
                                      MartinRinehart
                                      @edson said:
                                      martin,
                                      Don't know that service. Do I have to contact someone?
                                      Your workflow: do you start every model fresh, or do you grab pieces of existing models to create new?
                                      Either way, with a problem model in hand, it shouldn't take long to fix the model or VisMap. Look forward to it.
                                      • EdsonE Offline
                                        Edson
                                        @martinrinehart said:
                                        @edson said:
                                        martin,
                                        martin,
                                        you do not have to do anything. you will receive an email with a link to download the file.
                                        i start my models from zero but along the way i may import pieces from others.
                                          MartinRinehart
                                          Nothing yet, Edson. Gmail allows messages (including attachments) up to 25MB. Zip with maximum compression reduced a model I tested by 60%. Can you Zip a model and email it to me? MartinRinehart at gmail dot com.
                                          • EdsonE Offline
                                            Edson
                                            very strange, martin. i sent you the skippie on november 26th. could you check the image below to make sure i addressed it correctly? anyway, i am uploading the file to 4shared and will send you the link shortly.
                                            • 6 / 7
