    Fractal Tree Maker for SketchUp - Free add-on
    extensions
    158 Posts 44 Posters 68.2k Views 44 Watching
    • Al HartA
      Al Hart
      @rogerb said:
      Remove the edges around the trees by setting transparency quality to nicer under styles>edit>faces.
      Wow! What a great trick to know.
      Let me know if it works.
      Al
      Al Hart
      IRender nXt from Render Plus
      • EarthMoverE
        EarthMover
        I never knew that either. It works like a charm...thanks for the tip Roger.
        Content Creator at Skapeup
          smokinbakin
          Thanks a lot Al šŸ‘
          "Set your goals low, and hope you don't get lower"
          • ToboboT
            Tobobo
            Thanks Roger!
            Toby
            Philippians 4:13
              RogerB
              Glad you found it useful. I have always believed this was common knowledge. I noticed the same problem way back when this plugin was released but I did not see it mentioned anywhere, so I thought there must be something I am doing wrong. After some googling I found this setting mentioned somewhere on the web.
              • P
                phrimagination
                Hello Everybody, hello Al
                I am new in Sketchucation...
                I am a long time user of sketchup since v2 from france but never tried ruby plug before. But since I red Daniel Tal book Google sketchup for Site Design I am very in trying plug in where I learned about amazing and powerfull Fred tools and more. I went to Sketchucation to download extensions plug in, I would to thank Gaius to help me to register.
                I loaded fractal Tree Maker it is a very nice and useful tools. For me it works on my laptop a Dell Inspirion 1720 with vista, but I did not succeed to make it work on my old desktop a gateway GT 5220 with XP pro. Here the message.
                Error Loading File RpTreeMaker_loader.rb
                126: The specified module could not be found. - H:/Program Files/Google/Google SketchUp 7/Plugins/Win32API.so
                • GaieusG
                  Hi Phan - glad you made it finally.
                  Now as for the error - it doesn't seem to do anything with the plugin but there's some problem with your XP I guess.
                  • Chris FullmerC
                    it looks like it uses a file called win32API.so This is a sort of common script that other plugins use too. You can just copy it from your first computer onto your second computer. It will be located in the Plugins folder inside of SketchUp. Just copy it to the second computer, to the plugins folder, and then try the script again.
                    • Al HartA
                      Al Hart
                      Check to see if the file exists at that location on your machine.
                      Al Hart
                      • W
                        windrockwater
                        This is a very cool tool. Out of curiousity, what is the workflow of using Vray with this? I see the checkbox in options. But what does it do? Do you still have to assign the alpha map manually in Vray?
                        Otherwise, i tried this plugin with sketchup and its pretty cool!
                          With the current versions, yes.
                          • ToboboT
                            Tobobo
                            Al,
                            Could you add in standrad tree shapes as defaults?
                            Toby
                            Philippians 4:13
                            • P
                              phrimagination
                              Thanks to Al, Chris and Gaius, I made a copy of what was installed in my laptop: the 3 files in sketchup/plugin and all folder the Render Plus System in Program Files and now it s working. I think that something was not installed in the render plus system....
                              With your input, this post could be even better šŸ’—
                              • 8 / 8
