    Fractal Tree Maker for SketchUp - Free add-on
    extensions
    158 Posts 44 Posters 63.6k Views 44 Watching
    • Al HartA Offline
      Al Hart
      @6284732 said:
      oh i can not understand
      After creating a tree and placing it in SketchUp, click Window/Materials.
      When the SketchUp Material Window comes up;
      • select the "In Model" icon
      • select the material for the tree, and
      • select the Edit tab
      From the Edit tab:
      Select the "Edit texture in an external editor" icon, which will load a photo or image editor program.
      In the image editor, go to File/Save As.
      In the Save As dialog, use the drop down to the right of the folder name to get the complete path of the folder.
      Al Hart
      IRender nXt from Render Plus
        AcesHigh
        Al, do you think its possible to create Paraná Pines (a type of Araucaria tree that is very common in my area) in RPTreeMaker?
        http://bp3.blogger.com/_O_hPd8k6LR8/SGRNVWLcQwI/AAAAAAAAAUE/Inz_iEW0ynY/s320/300px-Pinheiros2.jpg
        http://farm1.static.flickr.com/120/368871093_b8bb64e677.jpg
        http://image59.webshots.com/159/5/5/59/2467505590073484453RAYfki_fs.jpg
        http://lh5.ggpht.com/_cFWifFMbEJA/Rn7Kk2w7m7I/AAAAAAAACAQ/I_dbhCSox_U/s640/Dsc01430.jpg
        • Chris FullmerC Offline
          (off topic) I spent some time in Itajuba (em Minas Gerais) and Campos do Jordao and there are lots of the parana arucaria there. Absoultely some of the most amazing trees I've ever seen! They are HUGE. Good request Aces,
          • Al HartA Offline
            Al Hart
            I pass this on to Roy, who wrote RpTreeMaker, and see if he has any ideas.
            Can you get something similar by overlapping two trees - one for the top branches, and one for the lower branches?
            Al Hart
            • ToboboT Offline
              Tobobo
              Al,
              If you look at the images below there is something weird happening around the edges of the trees/shrubs. Is this because I chose the medium quality processing?
              Toby
              Philippians 4:13
              • Al HartA Offline
                Al Hart
                @tobobo said:
                Al,
                This is caused by the partial transparency at the edge of the tree image.
                I will take a look at it.
                Higher resolution images will make it less noticeable, but will not eliminate it.
                Al Hart
                • ToboboT Offline
                  Tobobo
                  Thanks Al
                  Toby
                  Philippians 4:13
                  • jujuJ Offline
                    juju
                    @al hart said:
                    @tobobo said:
                    Al,
                    Just following up on this Al, any feedback?
                      RogerB
                      Remove the edges around the trees by setting transparency quality to nicer under styles>edit>faces.
                      • Al HartA Offline
                        Al Hart
                        Wow! What a great trick to know.
                        Let me know if it works.
                        Al
                        Al Hart
                        • EarthMoverE Offline
                          EarthMover
                          I never knew that either. It works like a charm...thanks for the tip Roger.
                          Content Creator at Skapeup
                            smokinbakin
                            Thanks a lot Al 👍
                            "Set your goals low, and hope you don't get lower"
                            • ToboboT Offline
                              Tobobo
                              Thanks Roger!
                              Toby
                              Philippians 4:13
                                RogerB
                                Glad you found it useful. I have always believed this was common knowledge. I noticed the same problem way back when this plugin was released but I did not see it mentioned anywhere, so I thought there must be something I am doing wrong. After some googling I found this setting mentioned somewhere on the web.
                                  phrimagination
                                  Hello Everybody, hello Al
                                  I am new in Sketchucation...
                                  I am a long time user of sketchup since v2 from france but never tried ruby plug before. But since I red Daniel Tal book Google sketchup for Site Design I am very in trying plug in where I learned about amazing and powerfull Fred tools and more. I went to Sketchucation to download extensions plug in, I would to thank Gaius to help me to register.
                                  I loaded fractal Tree Maker it is a very nice and useful tools. For me it works on my laptop a Dell Inspirion 1720 with vista, but I did not succeed to make it work on my old desktop a gateway GT 5220 with XP pro. Here the message.
                                  Error Loading File RpTreeMaker_loader.rb
                                  126: The specified module could not be found. - H:/Program Files/Google/Google SketchUp 7/Plugins/Win32API.so
                                    Hi Phan - glad you made it finally.
                                    Now as for the error - it doesn't seem to do anything with the plugin but there's some problem with your XP I guess.
                                      it looks like it uses a file called win32API.so This is a sort of common script that other plugins use too. You can just copy it from your first computer onto your second computer. It will be located in the Plugins folder inside of SketchUp. Just copy it to the second computer, to the plugins folder, and then try the script again.
                                      • Al HartA Offline
                                        Al Hart
                                        Check to see if the file exists at that location on your machine.
                                        Al Hart
                                        • W Offline
                                          windrockwater
                                          This is a very cool tool. Out of curiousity, what is the workflow of using Vray with this? I see the checkbox in options. But what does it do? Do you still have to assign the alpha map manually in Vray?
                                          Otherwise, i tried this plugin with sketchup and its pretty cool!
                                            With the current versions, yes.
                                            • 8 / 8
