    Render this: L.E.D lighting
    38 Posts 19 Posters 14.6k Views 19 Watching
    • N Offline
      notareal
      There are so meny different materials used so it's safe to use IOR 1.40 to 1.60.
      • soloS Offline
        I'm using 1.45, the problem is the cover as having a plastic cover above an acrylic texture slows things down somewhat.
        Not an easy challenge.
          remon_v
          quick try
          http://i22.photobucket.com/albums/b336/remon_v/LED1.jpg
          • soloS Offline
            First attempt.
              remus
              Excuse the dodgy kerning.
              • E Offline
                Ecuadorian
                Cool reference photo. It would be even cooler to have a LED model like this one (wink, wink).
                http://www.otherthings.com/blog/images/led_throwies_small.jpg
                -Miguel Lescano
                • Al HartA Offline
                  Al Hart
                  You could shorten it a bit...it's a bit awkward to throw around. šŸ˜„
                  I took Solo's LED light strip and made a Dynamic component out of it.
                  If you stretch it the number of lights will change to match the new length.
                  Also, you can right click and change the light spacing or length if you have dynamic components enabled:
                  http://forums.sketchucation.com/download/file.php?id=37377
                  The DC is inside the .SKP file, so you could copy and paste the entire component if you wanted to use it in a different model.
                  LED Light case.skp
                  Al Hart
                  IRender nXt from Render Plus
                  • E Offline
                    Ecuadorian
                    Ok, here's my try with Twilight:
                    I used a very, very darkened HDR as background so the light coming from the LEDs would be the focus of the image. This caused the problem I had already foreseen because I've experienced it many times when taking real photos: If you lower the exposure until you see clearly the shape of the LEDs, the rest of the scene is too dark:
                    Exposure = 1
                    And if you rise the exposure until the rest of the scene looks better, the LEDs themselves become overexposed.
                    Exposure = 2
                    Of course, I could have used a brigther HDR background from the very start (Duh!), but I want to make a point here, so please bear with me.
                    I saved the render as an HDR and opened it in the free program Picturenaut, which is a very handy tonemapper, HDR creator, HDR<->EXR converter, etc. I used a "photoreceptor" type tonemapping with these settings:
                    And here's the result:
                    I could have chosen a higher saturation level but I like how it looks.
                    So, which one do you prefer?
                    -Miguel Lescano
                      Chris_at_Twilight
                      Your second image looks most realistic to me... LEDs are often overexposed in photos.
                      By the way, what kind of material did you use? The LEDs themselves look really good.
                      http://www.TwilightRender.com
                      • E Offline
                        Ecuadorian
                        Well, in the reference picture I linked to I noticed that LED light comes from:
                        • A small disc inside the casing, which seems to be the source.
                        • Total internal reflection.
                        • Sub-Surface Scattering.
                        So I used the SSS Rubber Ball template (which by default has IOR = 1.4, which seemed adequate after reading the first posts here), made it completely clear with no color, and rendered it with simple MLT (aka "Easy 09"). Perhaps I could have gotten better results with Bi-directional MLT (Easy 10).
                        -Miguel Lescano
                          Nice reference photo.
                          I had a bunch of LED's next to me when I was trying this out earlier. Kept hot-wiring them to a battery until they got hot.
                          • E Offline
                            Ecuadorian
                            Closer observation of LEDs reveals that only a part of the plastic is actually lit, so here's an update.
                            In reality, the lit part starts with a conical shape; I'll try that tomorrow.
                            -Miguel Lescano
                            • EarthMoverE Offline
                              EarthMover
                              Miguel...the new one looks better, IMO. I think the "cone of shame" added a lot of realism. Care to post the model?
                              Here's an attempt with a green LED. Not really happy with it. I used a tiny Vray sphere lighting in each of the LED's. I tried an emitter plane, but it looks crappy. Used a soft water SSS material for the bulb casing. Took forever to render the 202 lights!
                              Content Creator at Skapeup
                                rev3rse
                                OMG!! A Point-Light for any led, it's a rendering nightmare... 😮
                                  Not if it's just a handful of LED for close ups.
                                  • olisheaO Offline
                                    olishea
                                    i think majid's and earthmover's LEDS are most convincing. majid captured that falloff that you get with LEDS...they act like mini spotlights (well the one on my keyring does anyway). So I imagine loading an IES will work well.
                                    oli
                                    • E Offline
                                      Ecuadorian
                                      OK, this time I modeled a tiny metalic "cone of shame" (he he he) around an even tinier emitter, to better simulate the light source in a LED.
                                      I'm not sure if I like this image better than the previous one:
                                      Different exposure:
                                      EDIT: Added the model with the cone.
                                      LED Closeup cone.zip
                                      -Miguel Lescano
                                        Aidus
                                        Here is mine:
                                        Test Led
                                        Transparent materials - real glass and that's the only correct material here šŸ˜„
                                        CPU: Intel Core i7 Extreme Edition 965
                                        RAM: OCZ Gold DDR3 1600MHz 12Gb
                                        Video: Asus Radeon HD4870 X2 2Gb
                                        Mobo: Asus P6T Deluxe 1366 Intel X58
                                        • majidM Offline
                                          majid
                                          this is my try.sketchup + KT and also the result is a photoshop combination.
                                          Also you may try it(unzip and load the KT file, attached)
                                          spot light added and lit(MLT, BPT)
                                          no light but sky (MLT, BPT)
                                          combination and adjusted , using photoshop
                                          unzip and then open in KT, šŸ˜‰ cheers
                                          • Al HartA Offline
                                            Al Hart
                                            First try
                                            (I know I am a little slower at getting this done than some of you. Actually we found a bug where we were processing curved light emitters too slowly, so this helped fix up the software as well)
                                            Al Hart
                                            With your input, this post could be even better šŸ’—
