    Render this: L.E.D lighting
    38 Posts 19 Posters 14.6k Views 19 Watching
      Chris_at_Twilight
      Your second image looks most realistic to me... LEDs are often overexposed in photos.
      By the way, what kind of material did you use? The LEDs themselves look really good.
      http://www.TwilightRender.com
      • E Offline
        Ecuadorian
        Well, in the reference picture I linked to I noticed that LED light comes from:
        • A small disc inside the casing, which seems to be the source.
        • Total internal reflection.
        • Sub-Surface Scattering.
        So I used the SSS Rubber Ball template (which by default has IOR = 1.4, which seemed adequate after reading the first posts here), made it completely clear with no color, and rendered it with simple MLT (aka "Easy 09"). Perhaps I could have gotten better results with Bi-directional MLT (Easy 10).
        -Miguel Lescano
          @ecuadorian said:
          Cool reference photo. It would be even cooler to have a LED model like this one (wink, wink).
          http://www.otherthings.com/blog/images/led_throwies_small.jpg
          Nice reference photo.
          I had a bunch of LED's next to me when I was trying this out earlier. Kept hot-wiring them to a battery until they got hot.
          • E Offline
            Ecuadorian
            Closer observation of LEDs reveals that only a part of the plastic is actually lit, so here's an update.
            In reality, the lit part starts with a conical shape; I'll try that tomorrow.
            -Miguel Lescano
            • EarthMoverE Offline
              EarthMover
              Miguel...the new one looks better, IMO. I think the "cone of shame" added a lot of realism. Care to post the model?
              Here's an attempt with a green LED. Not really happy with it. I used a tiny Vray sphere lighting in each of the LED's. I tried an emitter plane, but it looks crappy. Used a soft water SSS material for the bulb casing. Took forever to render the 202 lights!
              Content Creator at Skapeup
                rev3rse
                OMG!! A Point-Light for any led, it's a rendering nightmare... 😮
                  Not if it's just a handful of LED for close ups.
                  • olisheaO Offline
                    olishea
                    i think majid's and earthmover's LEDS are most convincing. majid captured that falloff that you get with LEDS...they act like mini spotlights (well the one on my keyring does anyway). So I imagine loading an IES will work well.
                    oli
                    • E Offline
                      Ecuadorian
                      OK, this time I modeled a tiny metalic "cone of shame" (he he he) around an even tinier emitter, to better simulate the light source in a LED.
                      I'm not sure if I like this image better than the previous one:
                      Different exposure:
                      EDIT: Added the model with the cone.
                      LED Closeup cone.zip
                      -Miguel Lescano
                        Aidus
                        Here is mine:
                        Test Led
                        Transparent materials - real glass and that's the only correct material here 😄
                        CPU: Intel Core i7 Extreme Edition 965
                        RAM: OCZ Gold DDR3 1600MHz 12Gb
                        Video: Asus Radeon HD4870 X2 2Gb
                        Mobo: Asus P6T Deluxe 1366 Intel X58
                        • majidM Offline
                          majid
                          this is my try.sketchup + KT and also the result is a photoshop combination.
                          Also you may try it(unzip and load the KT file, attached)
                          spot light added and lit(MLT, BPT)
                          no light but sky (MLT, BPT)
                          combination and adjusted , using photoshop
                          unzip and then open in KT, 😉 cheers
                          • Al HartA Offline
                            Al Hart
                            First try
                            (I know I am a little slower at getting this done than some of you. Actually we found a bug where we were processing curved light emitters too slowly, so this helped fix up the software as well)
                            Al Hart
                            IRender nXt from Render Plus
                            • EscapeArtistE Offline
                              EscapeArtist
                              Dang. Majid, you beat me to it. I should've checked this thread before building my LED. Oh well, here it is anyway. Feel free to do what you will with it. It's a bit overboard detail-wise, I even threw in a few air inclusions.
                              Error 404 (Not Found)!!1
                              (sketchup.google.com)
                              I based it on this picture:
                              http://scorpiontheater.com/images/LED_Closeup.jpg
                              • F Offline
                                fymoro
                                A quick try (10 minutes) with Vray for SU first version... 😄
                                http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                                  Rico91
                                  Hi all,
                                  my first post on this forum today!
                                  This is my render of the L.E.D. Lighting:
                                  http://lh4.ggpht.com/_rMc47FEl0fA/SwhweInvFLI/AAAAAAAABz4/TOEACiq_BG4/Led_SUcation_2.jpg
                                  [img:y90a5vdg]http://lh5.ggpht.com/_rMc47FEl0fA/Sro-DozMGPI/AAAAAAAABwU/zZsLbdpwWAs/forum_onderschrift_r3d_30pxh.jpg[/img:y90a5vdg] [url:y90a5vdg]http://www.R3Design.nl[/url:y90a5vdg]
                                  • majidM Offline
                                    majid
                                    Ok mate, I tried to keep and respect your level of details, hope you like it 😉 (distort correction and a bit of bluring , by PS )
                                      EscapeArtist
                                      Oh, that is really cool. Nice job. What renderer?
                                        EscapeArtist
                                        Nice job. I used KT as well, gotta work on my materials. Only thing about KT is that it doesn't do volumetric light beams, so I got the same result as you did in your red LEDs; a bright surface light, but nothing "inside" the LED.
                                        • majidM Offline
                                          majid
                                          OK thanx mate , it is KT as usual, nice that u like it
                                          • majidM Offline
                                            majid
                                            it does volometric lighting also, but I didn't used 😉
                                            • 2 / 2
