    Render this: L.E.D lighting
    38 Posts 19 Posters 12.8k Views 19 Watching
    • soloS Offline
      I see what you are referring to, I assumed you meant the casing for the strip.
      If you would like I can remove the inner part of the dome, or you can as they are componented if that will help with the render.
      • soloS Offline
        Here is another version without inner bits to the LED's.
        LED3 strip.skp
        And here is a shorter version with a center core, so there are many options, feel free to modify as you feel necessary as this is not an absolute model but just a guideline to start from.
        LED4 strip.skp
        • soloS Offline
          I did, see LED4 above.
            Chris_at_Twilight
            I have a bunch of LEDs in front of me from a Christmas toy I tore apart. It looks like the curve of the acrylic is positioned just right to focus on the emitter, just like a lens. I suspect that distance is important. (Anyone know the IOR of the acrylic? 1.49 is a common acrylic number)
            http://www.TwilightRender.com
            • N Offline
              notareal
              There are so meny different materials used so it's safe to use IOR 1.40 to 1.60.
              • soloS Offline
                I'm using 1.45, the problem is the cover as having a plastic cover above an acrylic texture slows things down somewhat.
                Not an easy challenge.
                  remon_v
                  quick try
                  http://i22.photobucket.com/albums/b336/remon_v/LED1.jpg
                  • soloS Offline
                    First attempt.
                      remus
                      Excuse the dodgy kerning.
                      • E Offline
                        Ecuadorian
                        Cool reference photo. It would be even cooler to have a LED model like this one (wink, wink).
                        http://www.otherthings.com/blog/images/led_throwies_small.jpg
                        -Miguel Lescano
                        • Al HartA Offline
                          Al Hart
                          You could shorten it a bit...it's a bit awkward to throw around. šŸ˜„
                          I took Solo's LED light strip and made a Dynamic component out of it.
                          If you stretch it the number of lights will change to match the new length.
                          Also, you can right click and change the light spacing or length if you have dynamic components enabled:
                          http://forums.sketchucation.com/download/file.php?id=37377
                          The DC is inside the .SKP file, so you could copy and paste the entire component if you wanted to use it in a different model.
                          LED Light case.skp
                          Al Hart
                          IRender nXt from Render Plus
                          • E Offline
                            Ecuadorian
                            Ok, here's my try with Twilight:
                            I used a very, very darkened HDR as background so the light coming from the LEDs would be the focus of the image. This caused the problem I had already foreseen because I've experienced it many times when taking real photos: If you lower the exposure until you see clearly the shape of the LEDs, the rest of the scene is too dark:
                            Exposure = 1
                            And if you rise the exposure until the rest of the scene looks better, the LEDs themselves become overexposed.
                            Exposure = 2
                            Of course, I could have used a brigther HDR background from the very start (Duh!), but I want to make a point here, so please bear with me.
                            I saved the render as an HDR and opened it in the free program Picturenaut, which is a very handy tonemapper, HDR creator, HDR<->EXR converter, etc. I used a "photoreceptor" type tonemapping with these settings:
                            And here's the result:
                            I could have chosen a higher saturation level but I like how it looks.
                            So, which one do you prefer?
                            -Miguel Lescano
                              Chris_at_Twilight
                              Your second image looks most realistic to me... LEDs are often overexposed in photos.
                              By the way, what kind of material did you use? The LEDs themselves look really good.
                              • E Offline
                                Ecuadorian
                                Well, in the reference picture I linked to I noticed that LED light comes from:
                                • A small disc inside the casing, which seems to be the source.
                                • Total internal reflection.
                                • Sub-Surface Scattering.
                                So I used the SSS Rubber Ball template (which by default has IOR = 1.4, which seemed adequate after reading the first posts here), made it completely clear with no color, and rendered it with simple MLT (aka "Easy 09"). Perhaps I could have gotten better results with Bi-directional MLT (Easy 10).
                                -Miguel Lescano
                                  Nice reference photo.
                                  I had a bunch of LED's next to me when I was trying this out earlier. Kept hot-wiring them to a battery until they got hot.
                                  • E Offline
                                    Ecuadorian
                                    Closer observation of LEDs reveals that only a part of the plastic is actually lit, so here's an update.
                                    In reality, the lit part starts with a conical shape; I'll try that tomorrow.
                                    -Miguel Lescano
                                    • EarthMoverE Offline
                                      EarthMover
                                      Miguel...the new one looks better, IMO. I think the "cone of shame" added a lot of realism. Care to post the model?
                                      Here's an attempt with a green LED. Not really happy with it. I used a tiny Vray sphere lighting in each of the LED's. I tried an emitter plane, but it looks crappy. Used a soft water SSS material for the bulb casing. Took forever to render the 202 lights!
                                      Content Creator at Skapeup
                                        rev3rse
                                        OMG!! A Point-Light for any led, it's a rendering nightmare... 😮
                                          Not if it's just a handful of LED for close ups.
                                          • olisheaO Offline
                                            olishea
                                            i think majid's and earthmover's LEDS are most convincing. majid captured that falloff that you get with LEDS...they act like mini spotlights (well the one on my keyring does anyway). So I imagine loading an IES will work well.
                                            oli
                                            With your input, this post could be even better šŸ’—
