    Reading the SU API
    17 Posts 5 Posters 1.4k Views 5 Watching
    • honoluludesktopH
      honoluludesktop
      OK, is this the correct way to find all components (including nested ones) in the model?
      model = Sketchup.active_model
      model.definitions.each do |c|
        puts "Component; #{c.name}"
      • Chris FullmerC
        That is showing all the component definitions, in the model. Including nested definitions.
        Is that what you are trying to do? Or do you want a list that includes every isntance of each definition too? For that do:
          c.instances.each do |ins|
            puts "Component; #{ins}"
        • honoluludesktopH
          honoluludesktop
          OK, is this right?
            c.instances.each do |s|
              puts "Component; #{c.name} #{s.transformation.origin.to_s}"
          My output (Box03 inside Box01):
          %(#BF0000)[Component: Box02 (106.466771", -5.289104", 0")
          Component: Box03 (11.477469", 39.803972", 6.9375")
          Component: Box01 (0", 0", 0")]
          • honoluludesktopH
            honoluludesktop
            Understood:-)
            %(#BF0000)[106.466771389033
            -5.28910358007033
            6.57113252700015e-015
            11.4774687529651
            39.8039723918033
            6.93750000000001
            0.0
            0.0
            0.0]
              Jim
              The [to_s](http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#to_s) method is appropriate for printing a Point3d. You can't just print an Array and have it come out reasonably.
                ....s.transformation.origin.to_a....
                origin is a 3D-point - alternatively would return an array like [0,0,0] which you can use as a point or take xyz values
                • honoluludesktopH
                  honoluludesktop
                  Understood:-) Can you mix strings, and numbers in a array without having to change them (to_s or to_f) later? If so is it efficient?
                    Things like a 3d-point can be made into an array using to_a - these are then all floats [0.0,1.2,3.4]
                    An array can be made thus
                    array=[]
                    array[0]=1
                    array[1]=2.3
                    array[2]="Cat"
                    array[3]=nil
                    array.push([1,2,3,4])
                    array<<true
                    my_variable=123456789
                    array=array+[my_variable]
                    so array >>> [1,2.3,"Cat",nil,[1,2,3,4],true,myvaraible]
                    i.e. an integer, a float, a string, nil, an array, a boolean and a variable's value.
                    Individual items can be changed thus array[5]=false changes the boolean value
                    arrays can be sorted, added, subtracted, reversed, compacted, flattened, made_unique etc etc - they are very useful!
                    • honoluludesktopH
                      honoluludesktop
                      Thanks!-) Think, I learned a lot of "stuff" in the past few days. Think I'll go back a couple of weeks, and see if I can better comprehend those posts:-)
                        MartinRinehart
                        @honoluludesktop said:
                        ... If so is it efficient?
                        Twentieth century issue.
