    Reading the SU API
    17 Posts 5 Posters 1.1k Views 5 Watching
    • honoluludesktopH Offline
      honoluludesktop
      I have 2 boxes in my test model, originally inserted at different locations. definitions[0.insertion_point], and definitions[1.insertion_point], both report (0", 0", 0"). Am I doing something wrong, or do I misunderstand what an insertion_point is?
        honoluludesktop
        Or, is the insertion_point for components always (0", 0", 0") because the face coordinates work off the drawing origin? Are there any exceptions?
        • Chris FullmerC Offline
          The insertion point is the point of the component that sticks to your cursor when you are inserting it into the model. It can often be the component origin, but it is not always the origin. It is normally the last position on the component gripped by a user when they moved the component. If that makes sense....
            honoluludesktop
            Chris, Thanks, I am finally begining to understand how to use the SU API, and a little of Ruby in general:-)
              I had sent another reply, but it got timed out and lost. But what I think you are looking for is called the transformation origin. That is the axis of the component. So try this:
              component_instance.transformation.origin
              That might get you what you want,
                MartinRinehart
                Once you create a variable in the Ruby Console, it stays until you shut down.
                model=Sketchup.active_model on a PC is needed once. It creates a reference. Even loading another model doesn't bother it. Ditto for model.this and model.that.
                Are you wondering where your component is? Assuming compInst is a ComponentInstance, it's at: compInst.transformation.origin
                I am working as hard as I can on the second half of my tutorial. Nobody should be forced to figure out the API from the docs. "Cruel and unusual punishment" is forbidden by our constitution.
                  honoluludesktop
                  Thanks Chris, and Martin, I put aside my ruby project, and have been spending my time with SU's Ruby Console, a Web Console, and the SU API, slowly working my way through each classes, and their methods. Did I say that right?-) Yes, a drop dead beginners API guide would be a great help. Assume nothing, and go from Sketchup.active_model.entities...... and all the other "take it for granted" basics. Thanks for pointing me in the direction of component_instance.transformation.origin
                  Got sidetracked into figuring out how to get to a component inside another. The attached finds all of the ones at the first level, but fails to find the nested ones.
                  model = Sketchup.active_model
                  entities = model.entities
                  definitions=model.definitions
                  entities.each do |e|
                    if e.is_a? Sketchup;;ComponentInstance
                      definitions.each do |d|
                      if e.definition.name == d.name
                        puts "found definitions match for "+e.definition.name+", origin;"+e.transformation.origin.to_s
                  Nice, now access to nested components.
                    honoluludesktop
                    OK, is this the correct way to find all components (including nested ones) in the model?
                    model.definitions.each do |c|
                      puts "Component; #{c.name}"
                      That is showing all the component definitions, in the model. Including nested definitions.
                      Is that what you are trying to do? Or do you want a list that includes every isntance of each definition too? For that do:
                        c.instances.each do |ins|
                          puts "Component; #{ins}"
                        honoluludesktop
                        OK, is this right?
                          c.instances.each do |s|
                            puts "Component; #{c.name} #{s.transformation.origin.to_s}"
                        My output (Box03 inside Box01):
                        %(#BF0000)[Component: Box02 (106.466771", -5.289104", 0")
                        Component: Box03 (11.477469", 39.803972", 6.9375")
                        Component: Box01 (0", 0", 0")]
                          honoluludesktop
                          Understood:-)
                          %(#BF0000)[106.466771389033
                          -5.28910358007033
                          6.57113252700015e-015
                          11.4774687529651
                          39.8039723918033
                          6.93750000000001
                          0.0
                          0.0
                          0.0]
                            Jim
                            The [to_s](http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#to_s) method is appropriate for printing a Point3d. You can't just print an Array and have it come out reasonably.
                            • TIGT Online
                              ....s.transformation.origin.to_a....
                              origin is a 3D-point - alternatively would return an array like [0,0,0] which you can use as a point or take xyz values
                                honoluludesktop
                                Understood:-) Can you mix strings, and numbers in a array without having to change them (to_s or to_f) later? If so is it efficient?
                                • TIGT Online
                                  Things like a 3d-point can be made into an array using to_a - these are then all floats [0.0,1.2,3.4]
                                  An array can be made thus
                                  array=[]
                                  array[0]=1
                                  array[1]=2.3
                                  array[2]="Cat"
                                  array[3]=nil
                                  array.push([1,2,3,4])
                                  array<<true
                                  my_variable=123456789
                                  array=array+[my_variable]
                                  so array >>> [1,2.3,"Cat",nil,[1,2,3,4],true,myvaraible]
                                  i.e. an integer, a float, a string, nil, an array, a boolean and a variable's value.
                                  Individual items can be changed thus array[5]=false changes the boolean value
                                  arrays can be sorted, added, subtracted, reversed, compacted, flattened, made_unique etc etc - they are very useful!
                                    honoluludesktop
                                    Thanks!-) Think, I learned a lot of "stuff" in the past few days. Think I'll go back a couple of weeks, and see if I can better comprehend those posts:-)
                                      MartinRinehart
                                      @honoluludesktop said:
                                      ... If so is it efficient?
                                      Twentieth century issue.
