    [Preview] UVTools 0.2
    74 Posts 23 Posters 14.8k Views 23 Watching
      Jackson
      Whaat,
      Thanks for the quick answer. I meddled with a few UV unwrapping prog demos a few months ago, but got nowhere- most SU meshes just seem to unwrap 3-dimensionally (i.e. polys are exploded above and below each other when viewed in the UV editing view) making them impossible to export an editable UV map from. I did have some success exporting an apple mesh from SU, but haven't been able to work out what it was that made that mesh import properly into UV unwrapping software properly while most don't. I've specifically made closed convex hull meshes (which the apple obviously was) in SU to see if they would import properly in UV unwrapping programs, but it makes no difference.
      I just did a quick trial with the demo of Ultimate Unwrap 3D and yet again, the apple mesh imports and unwraps correctly, but anything else (even single sided very low poly meshes) unwraps as a bunch of exploded overlapping triangles.
      As a note for your anyone using UU3D you must always export obj meshes and texture bitmaps FROM UU3D using names WITHOUT SPACES. SU doesn't import the UV map otherwise.
      Jackson
        richcat
        Another application to consider and just out of interest to do with uv mapping - has any one come across this Headus UV layout-UV flattening software.I tried it, a while back and it seemed very simple, but have not stumped up $200 for hobbyist version yet, and there is Mac version.
        • W Offline
          Whaat
          Does this tip apply for importing any 3DS mesh into SketchUp? Or are you using another format?
            Jackson
            Whaat,
            I must admit I got pretty confused while I was testing UU3D as I was juggling obj and 3ds exports from SU with obj and 3ds exports from UU3D as well as running them all through Meshlab, 3DMax and Vue 6 and saving further obj and 3ds copies to see if it helped with SU's and UU3D's importing, but I think the "no spaces" rule applied both to 3ds and obj.
            Then again, I'm pretty sure most progs capable of exporting in 3ds format automatically insert understrikes/underscores in place of spaces. As such, I've never had problems importing 3ds into SU before, from any source.
            Jackson
            • W Offline
              Whaat
              I can confirm compatibility with Roadkill, UVMapper classic (free), and Argile.
              I had a hard time testing Argile, though. I couldn't get the UV manipulators to show up and the UI seemed to behave very weird.
              I can't test with UVMapper Pro or UVLayout yet because their demo versions do not allow OBJ export.
              • jeff hammondJ Offline
                yeah, i tried the argile demo and it seemed very weird to me.. that's just messin around without reading anything but still...
                roadkill looks to be another mac option so i'll check that one out too.
                question for whaat-
                what happens further down the line in terms of rendering? (more specifically, with indigo).. does the mapping stay put or does the mesh need to be built a certain way prior to mapping? (spheres need to be triangulated first for them to work in indigo etc..)
                  Jackson
                  If Whaat's plugin does the obj conversion correctly, rendering in other plugins/progs shouldn't be a problem. I did a test (the apple again), exported from SU to UU3D and back into SU via TIG's obj importer and it rendered fine in V-Ray for SU. This is actually surprising as V-Ray for SU usually doesn't recognise textures which have been skewed or distorted in SU.
                  Jackson
                    remus
                    Jeff and jackson, after using whaats current UV tools your mesh needs to be triangulated for the UVs to make it in to indigo intact, id guess this is a skindigo/indigo thing and so likely to be the same with this plugin.
                      dedmin
                      I can confirm - V-Ray doesn't recognize textures which have been painted in Photoshop via .kmz import-export.
                      • W Offline
                        Whaat
                        question for whaat-
                        Jeff,
                        Currently, the meshes would have to be triangulated prior to rendering in Indigo. I am not sure about other rendering apps. Most do not support rendering distorted textures. I suspect that the apple rendered properly in Vray because it was triangulated.
                          You can distort the mapping of a triangle as well - don't think the triangulation should matter.
                          • E Offline
                            Ecuadorian
                            It was hard to believe at first, but a small test with triangles reveals Thomas is right. 😕
                            triangles.skp
                            -Miguel Lescano
                              When you map in SU you either get four points to drag about or the Move,ScaleUniform,ScaleNonUniform,Distort pins. You can always use the distort pin on any face, even triangles. It's basically a texture applied to an invisible plane - clipped by the shape of the face.
                              If there are non-parallels sides to the UV mapping gizmo - V-Ray will fail to render. But it will render a texture mapped as a parallelogram.
                              • E Offline
                                Ecuadorian
                                For render programs that can't handle distorted mapping, I've read the workaround is to export as 3ds and re-import, but I can't test this as I don't have SketchUp Pro. If the object only has a few faces, you can click on each one and right click > Make Unique Texture.
                                -Miguel Lescano
                                  Khai
                                  works fine with Uvmapper Pro
                                  • majidM Offline
                                    majid
                                    dear tom, I was on wrong topic when I requested this, but here I am gonna ask you to add some more features, to working with textures , directly is su (foe those like me that are not familliar with othe rapps .. 😉 ), maybe as, add a "ghost preview" of how plugin is going to UVmap (i.e. showing a sphere when choosing spherical...etc) could improve the ui!!
                                      jimahiggins
                                      So are you saying that there is not a way in the API to automate the "Make Unique Texture" function from the popup menu. I looked at ThomThom's "uv_make_unique.rb" which does a great job of duplicating a texture/image. But I need to dice up the image and spread over multiple smaller faces. Basically, I am dicing up terrain into smaller faces, with each face needing it's own texture/image.
                                      Thanks,
                                      Jim
                                      • 4 / 4
