    Copy Array Along Path tool...have a look.
    46 Posts 15 Posters 123.7k Views 15 Watching
    • Chris FullmerC
      And drawing inspiration from this thread, I just wrote a quick little script called component stringer. You can download it here:
      404 Not Found
      (forums.sketchucation.com)
      It does essentially what Simon is showing.
      • simon le bonS
        simon le bon
        Hi Jeff (big work had taken me out of reply)
        Thank you for trying. It is interesting because it shows me what I have to explain further (but it's a "WorkInProgress" also to me! 😆 ).
        The very basic theory to understand is that our components are not aligned to segments of the curve but are drop on faces (perpendicularly ).
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray021th.jpg
        You have focused an important point: the first and last faces are perpendicular to first and last segment of the curve. So they represent a particular case. If we want a very precise result, we have to realign them with the same angle of the others 😉
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray022th.jpg
        Second thing important to understand in doing this way: The process remain aproximativ . Not depending of the variations of the curve, the welding is "à peu près"!!
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray023th.jpg
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray024th.jpg
        Your component was empty from axes and significant Construction Points. I have added them.
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray025th.jpg
        Your are right. The position of component's axes is absolutely fundamental. the good origin is pointed to be positioned on the apex of the triangles(?english~~)
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray026th.jpg
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray027th-1.jpg
        Your curve, your component, your chain!
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray028th.jpg
        😉 simon.
        • E
          Ecuadorian
          Thank you, Chris! 👍
          -Miguel Lescano
          • simon le bonS
            simon le bon
            Hi Chris,
            It's a great pleasure to discover that you were looking apart silently and suddenly come to drop a top cool tool! Component Stringer
            You have decided to make the components follows the lines rather than faces.
            @chris fullmer said:
            Was TIG working on something that would replace a single line with a component and use the line scale and orientation to determine the scale and orientation of the component? Something about that sounds familiar...
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer001th.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer002th.jpg
            The result is that this tool is wonderful for necklaces
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer008th.jpg
            And we have not to use it for imbricated components
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer006th.jpg
            One more time, many thanks to you dear Chris,
            *simon
            • E
              Ecuadorian
              So, Jeff, how is that SketchUp model of Doc Ock coming along? 😄
              -Miguel Lescano
              • C
                Click Draw
                Hey Miguel,
                I might be able to do the arms now but I'll still suck at modeling Doc Oc. I need to put way more hours in to organic shape modeling!!! 😞
                Hope everyones weekend is going well....
                Cheers,
                Jeff
                Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                • E
                  Ecuadorian
                  Have you tried importing a Make Human model into Wings 3D or Silo and tweaking there? Then you can import the Wings 3D model to SU and add the robotic arms.
                  -Miguel Lescano
                  • C
                    Click Draw
                    I'll for sure check those out, thank you. I would still like to get decent at organic in Sketchup though. Here is a quick try at Chris's new ruby. I love it! Nice to be able to edit the component and see it update instantly. Thanks again Chris!
                    Jeff
                    • simon le bonS
                      simon le bon
                      I pursue the study of my proceeding despite Chris's "Component Stringer" because for the moment(But Chris is working to the speed of the iron horse!!), I think I can master better -the welding of components imbricated, -the mix of various components along the path, _the mix of components following the path with components invariant in orientation.
                      @bob james said:
                      However, you and I have a different definition of "fast and easy". 😆
                      Here is a realtime video (no editing) to show how fast is the process.
                      We start with a curve and a component.
                      http://i274.photobucket.com/albums/jj245/Spendauballet/videos/copyarrayalongpath04.gif
                      *simon
                      • simon le bonS
                        simon le bon
                        Some help to produce the component to copy along a path.
                        I)Put the good axes:
                        If it is for you like for me 😳 , positionning axes of the component I want to copy along a path is not so evident.
                        So, make a cube, make it as a component, and......
                        [flash=500,405:284ps2pd]http://www.youtube.com/v/z81CNzCE4V0[/flash:284ps2pd]
                        II)How to conceive a chain link:
                        Using one or other method to produce a chain, necklace and many others fences and so on, you will need to think about the shape of the links.
                        Here is my tip. Just think to draw a portion of curve with the smallest radius you think you are going to use for your path...
                        [flash=500,405:284ps2pd]http://www.youtube.com/v/PG8aK7fC2LA[/flash:284ps2pd]
                         :wink: simon
                        • Y
                          yiannosh
                          Can anyone help me how to download the ruby. It's my first visit to the forum ...
                          Thanks,
                          YiannosH
                          • simon le bonS
                            simon le bon
                            Hi YiannosH
                            A Fresh Welcome to you in our SketchUp Community.
                            Chris Fullmer's "Component Stringer"
                            And here all Chris's Plugins:
                            ++simon
                            • simon le bonS
                              simon le bon
                              The "How To" of my suspension bridge.
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_CopyArray019.jpg
                              Three Components and One curve.
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray031th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray032th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray033th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray034th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray035th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray036th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray037th.jpg
                              Et Voila! 😆
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray038th.jpg
                              Remus_Simple Catenary Curve
                              ChrisFullmer Plugins
                              Weld.rb v:3.0
                              Jim_Construction Line Tool
                              DBur_Lines to tubes
                              Kirill _ 2 Faces + Path ver. 1.4
                              Fredo_BezierSpline v1.21
                              [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=19457:2hagrkqi]TIG_TrueTangents v1.9[/url:2hagrkqi]
                              • N
                                notareal
                                Great tutorial. Worth to copy for safe keeping!
                                • simon le bonS
                                  simon le bon
                                  Hi NotaReal!
                                  You are greatly helping me for my first feet steps with Kerkythea.
                                  Here are some renders dedicated to you 😉 😉
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/clay_tstD003_th.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/clay_tstD004_th.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/clay_tstD005_th.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/clay_tstD006_th.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/clay_tstD007_th.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/SuspBridge003_th.jpg
                                  ++simon
                                  • 3 / 3
