    Render this: Fountain
    56 Posts 24 Posters 16.1k Views 24 Watching
    • michaliszissiouM Offline
      michaliszissiou
      The most of it is just PP (the background). But Madhav, this is a great scene, almost like painting. This is the most important thing IMO
      • E Offline
        Ecuadorian
        Michalis, it's a spherical background from KT's collection; no PP is needed to add it. Here's the link to download it:
        http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=startdown&id=44
        -Miguel Lescano
          madhav
          Thanks for your comment. yes, Its global downloaded from KT website. I have just exported model to KT, inserted global, disabled sun and applied materials. There are some other global libraries too. You just need to import the file and choose it from the drop down menu in KT.
            richcat
            Here my attempt with IRender.
            Water borrowed from 3DWH by Jam
            • EarthMoverE Offline
              EarthMover
              Nice Rich! Thanks for sharing the fountain spray you found. Ivy looks nice on the wall...I would add a concrete texture to the fountain itself with a little dirt on it.
              Content Creator at Skapeup
                EarthMover
                Here's something I was playing with yesterday using 3dsMax particle flow. Still needs work, but it's a start. (.gif conversion killed the quality!)
                • soloS Offline
                  Very cool Adam.
                  Now if you had Realflow, you could get it to spill over and do some crazy stuff.
                    EarthMover
                    Who can afford Realflow?! I contemplated Glu3D a while back for doing waterfalls and flame particles, but couldn't get the hang of it. Seems like a good alternative to Realflow for a lot less money.
                    • V Offline
                      Vicspa
                      Recently returned from a trip to Greece, and this was found among the ruins. 😄
                      Rendered with Podium, composited in Photoshop
                      • olisheaO Offline
                        olishea
                        haha good one 👍 🤣
                        oli
                        • soloS Offline
                          Vue.
                          I created the splash and spray with SDS, more a bubbling fountain than a spray.
                          • Al HartA Offline
                            Al Hart
                            I took your model with water and ran it through Render nXt.
                            Changes:
                            • turned on the ground plane for shadows (and changed it from green to grey)
                            • used default High Dynamic Studio lighting
                            • Set "rubble" procedural effect on the water. Scale set to 16 for enhanced ripples. (a bird bath usually has smaller waves than an ocean)
                            • Set 50% reflection on the water for enhanced highlighting from the sky.
                            • Added 20% reflection to the concrete so it could have some highlighting from the sky.
                            I let it "cook" for about 15 minutes while I took a shower.
                            (The shadows get softer and softer the longer you let it cook)
                            Here is the result:
                            Al Hart
                            IRender nXt from Render Plus
                            • boofredlayB Offline
                              boofredlay
                              Nice one Pete.
                                toxicvoxel
                                Am I understanding this right : With nXt you can actually shower in the fountain while it is rendering?? 😄
                                • soloS Offline
                                  • soloS Offline
                                    Another one, calm water (pump bust)
                                    I used some (excuse the shameless promotion) Solopack plants.
                                    • jeff hammondJ Offline
                                      1, so do you have a sample available for download anywhere and 2, do you have a tree pack available?
                                      • Al HartA Offline
                                        Al Hart
                                        Yes. But I was careful not to save the image until I was done. 😉
                                        Al Hart
                                          toxicvoxel
                                          OH. - and I thought that was what ambient occlusion was meant for...
                                          • E Offline
                                            Ecuadorian
                                            http://forums.sketchucation.com/download/file.php?id=37006&t=1
                                            Richard, that's some of the best non post production grass I've seen in this forum. 👍
                                            Is it a component composed of several clipmaps spread around with component spray? Or a full 3D component? Is that ivy from the ivy generator? I know, too many questions... 💚 Hey, that grass and ivy would make a nice tutorial. 😛
                                            -Miguel Lescano
                                            • 1 / 3
