    Render this: Fountain
    56 Posts 24 Posters 14.3k Views 24 Watching
    • E Offline
      Ecuadorian
      I'll try to model the water with SketchyPhysics emitters.
      -Miguel Lescano
      • soloS Offline
        For those that want a basic water included I have attached a model with a flat water plane.
        Fountain with water.skp
          d12dozr
          Twilight Render - Spherical Sky, HDR background, Sunlight Enabled, Low+ preset.
          15 min material setup, water spray is from SU 6 Bonus pack.
          http://goo.gl/f7ooYh
            madhav
            Kerkythea
            HDRI Background
            Water Spray - Tweaked Translucent Glass
            Fountain - Marble
            MLT
            My First experiment with water mat
            • michaliszissiouM Offline
              michaliszissiou
              The most of it is just PP (the background). But Madhav, this is a great scene, almost like painting. This is the most important thing IMO
              • E Offline
                Ecuadorian
                Michalis, it's a spherical background from KT's collection; no PP is needed to add it. Here's the link to download it:
                http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=startdown&id=44
                -Miguel Lescano
                  madhav
                  Thanks for your comment. yes, Its global downloaded from KT website. I have just exported model to KT, inserted global, disabled sun and applied materials. There are some other global libraries too. You just need to import the file and choose it from the drop down menu in KT.
                    richcat
                    Here my attempt with IRender.
                    Water borrowed from 3DWH by Jam
                    • EarthMoverE Offline
                      EarthMover
                      Nice Rich! Thanks for sharing the fountain spray you found. Ivy looks nice on the wall...I would add a concrete texture to the fountain itself with a little dirt on it.
                      Content Creator at Skapeup
                        EarthMover
                        Here's something I was playing with yesterday using 3dsMax particle flow. Still needs work, but it's a start. (.gif conversion killed the quality!)
                        • soloS Offline
                          Very cool Adam.
                          Now if you had Realflow, you could get it to spill over and do some crazy stuff.
                            EarthMover
                            Who can afford Realflow?! I contemplated Glu3D a while back for doing waterfalls and flame particles, but couldn't get the hang of it. Seems like a good alternative to Realflow for a lot less money.
                            • V Offline
                              Vicspa
                              Recently returned from a trip to Greece, and this was found among the ruins. 😄
                              Rendered with Podium, composited in Photoshop
                              • olisheaO Offline
                                olishea
                                haha good one 👍 🤣
                                oli
                                • soloS Offline
                                  Vue.
                                  I created the splash and spray with SDS, more a bubbling fountain than a spray.
                                  • Al HartA Offline
                                    Al Hart
                                    I took your model with water and ran it through Render nXt.
                                    Changes:
                                    • turned on the ground plane for shadows (and changed it from green to grey)
                                    • used default High Dynamic Studio lighting
                                    • Set "rubble" procedural effect on the water. Scale set to 16 for enhanced ripples. (a bird bath usually has smaller waves than an ocean)
                                    • Set 50% reflection on the water for enhanced highlighting from the sky.
                                    • Added 20% reflection to the concrete so it could have some highlighting from the sky.
                                    I let it "cook" for about 15 minutes while I took a shower.
                                    (The shadows get softer and softer the longer you let it cook)
                                    Here is the result:
                                    Al Hart
                                    IRender nXt from Render Plus
                                    • boofredlayB Offline
                                      boofredlay
                                      Nice one Pete.
                                        toxicvoxel
                                        Am I understanding this right : With nXt you can actually shower in the fountain while it is rendering?? 😄
                                        • soloS Offline
                                          • soloS Offline
                                            Another one, calm water (pump bust)
                                            I used some (excuse the shameless promotion) Solopack plants.
                                            • 1 / 3
