    Render this: Fountain
    56 Posts 24 Posters 16.8k Views 24 Watching
    • soloS
      For those that want a basic water included I have attached a model with a flat water plane.
      Fountain with water.skp
        d12dozr
        Twilight Render - Spherical Sky, HDR background, Sunlight Enabled, Low+ preset.
        15 min material setup, water spray is from SU 6 Bonus pack.
        http://goo.gl/f7ooYh
          madhav
          Kerkythea
          HDRI Background
          Water Spray - Tweaked Translucent Glass
          Fountain - Marble
          MLT
          My First experiment with water mat
          • michaliszissiouM
            michaliszissiou
            The most of it is just PP (the background). But Madhav, this is a great scene, almost like painting. This is the most important thing IMO
            • E
              Ecuadorian
              Michalis, it's a spherical background from KT's collection; no PP is needed to add it. Here's the link to download it:
              http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=startdown&id=44
              -Miguel Lescano
                madhav
                Thanks for your comment. yes, Its global downloaded from KT website. I have just exported model to KT, inserted global, disabled sun and applied materials. There are some other global libraries too. You just need to import the file and choose it from the drop down menu in KT.
                  richcat
                  Here my attempt with IRender.
                  Water borrowed from 3DWH by Jam
                  • EarthMoverE
                    EarthMover
                    Nice Rich! Thanks for sharing the fountain spray you found. Ivy looks nice on the wall...I would add a concrete texture to the fountain itself with a little dirt on it.
                    Content Creator at Skapeup
                    • EarthMoverE
                      EarthMover
                      Here's something I was playing with yesterday using 3dsMax particle flow. Still needs work, but it's a start. (.gif conversion killed the quality!)
                      • soloS
                        Very cool Adam.
                        Now if you had Realflow, you could get it to spill over and do some crazy stuff.
                        • EarthMoverE
                          EarthMover
                          Who can afford Realflow?! I contemplated Glu3D a while back for doing waterfalls and flame particles, but couldn't get the hang of it. Seems like a good alternative to Realflow for a lot less money.
                          • V
                            Vicspa
                            Recently returned from a trip to Greece, and this was found among the ruins. šŸ˜„
                            Rendered with Podium, composited in Photoshop
                            • olisheaO
                              olishea
                              haha good one šŸ‘ 🤣
                              oli
                              • soloS
                                Vue.
                                I created the splash and spray with SDS, more a bubbling fountain than a spray.
                                • Al HartA
                                  Al Hart
                                  I took your model with water and ran it through Render nXt.
                                  Changes:
                                  • turned on the ground plane for shadows (and changed it from green to grey)
                                  • used default High Dynamic Studio lighting
                                  • Set "rubble" procedural effect on the water. Scale set to 16 for enhanced ripples. (a bird bath usually has smaller waves than an ocean)
                                  • Set 50% reflection on the water for enhanced highlighting from the sky.
                                  • Added 20% reflection to the concrete so it could have some highlighting from the sky.
                                  I let it "cook" for about 15 minutes while I took a shower.
                                  (The shadows get softer and softer the longer you let it cook)
                                  Here is the result:
                                  Al Hart
                                  IRender nXt from Render Plus
                                  • boofredlayB
                                    boofredlay
                                    Nice one Pete.
                                    • T
                                      toxicvoxel
                                      Am I understanding this right : With nXt you can actually shower in the fountain while it is rendering?? šŸ˜„
                                      • soloS
                                        • soloS
                                          Another one, calm water (pump bust)
                                          I used some (excuse the shameless promotion) Solopack plants.
                                          • jeff hammondJ
                                            1, so do you have a sample available for download anywhere and 2, do you have a tree pack available?
                                            With your input, this post could be even better šŸ’—
                                            • 1 / 3
