    Internal Kitchen Render - Twilight Easy Low+
    41 Posts 12 Posters 5.6k Views 12 Watching
    • E Offline
      EarthMover
      Beautiful modeling my friend. Cabinetry looks great. Not digging the floor though. Looks old and worn out.
      One thing you may want to consider is switching the Camera to Two Point Perspective before you render and this will straighten out your vertical lines.
      Content Creator at Skapeup
        dermotcoll
        Thanks for the comments guys
        I tried a few changes as per your suggestions - can't get IES to load - when I go into it to load the ones leminilab suggested it still greys out and I cant load any to try them.
        System crashed a couple of times on me as well as I dont have a great processor for the bigger models and it is struggling big time with it. I have another in the oven as we speak and I will post the results when its finished. Anyone any tips on this IES problem?
        When you burn your arse - you gotta sit on the blisters!!
        • E Offline
          EarthMover
          Did you try the collection Frymoro posted on the Twilight forum? Should be able to copy and past lights right from the attached .skp file.
          spotlight IES.skp
            dermotcoll
            Thanks earthmover -
            I had just about given up when I noticed a tab (From scene) which I hadnt touched before. I was able to upload an Ies file and am looking forward to seeing what comes out - I have set it for Easy Low + just to see what effects have been generated by the changes made then I will cook it over night on Interiors 09.
              dermotcoll
              Hey Guys
              This is taking for ages in the low+ setting - ray tracing is only at 24% after and hour - should this take this long at such a low setting?
                Wanna upload the model, so that I can test on my side?
                  bytor
                  Hi Dermot,
                  Sometimes ies files do take a long time. While they can be the most accurate - it is often unnecessary. Here are a couple of very helpfull links from the Twilight site regarding lighting;
                  http://twilightrender.com/phpBB3/viewtopic.php?f=12&t=732
                  http://twilightrender.com/phpBB3/viewtopic.php?f=12&t=665
                  It took me a couple of read throughs to fully understand what they are saying - but these are great reference points.
                  With regards to the materials - remember you can use all of the Kerkythea materials in Twilight as well!
                  Bytor
                  Find the Cost of Freedom.....
                    leminilab
                    Hi Dermot,
                    Have you tried just lowering your omni lights a little ? IES lights are very demanding which may explain your rendering time I think.
                    Maybe by just lowering your omni and removing the IES...
                    • "Live every day as if it were your last and then some day you'll be right."
                    • "ThomThom rules!!!"
                      dermotcoll
                      Thanks for the comments and guidance guys. Here is the model (compressed) for you to look at and critique.
                      Catherine Harneys.rar
                        bytor
                        Dermot,
                        Wonderfull model! I deleted the lights you had and added som recessed downlights and a fixture I found on the warehouse. I also adjusted some of the material settings and replaced the floor / counter materials. Hope you don't mind - but it was fun to work with someone else's model for an hour or so. Here is a quick npr style to show what I did. I already made some lighting adjustments and have one in the cooker for processing overnight.
                        Bytor
                          dermotcoll
                          Bytor
                          Thanks so much for the comments. Really love the NPR render finish- have tried to do that myself but didnt work so I didnt post. Can you re upload your finished model so I can see what you did and how you did it?
                            dedmin
                            @dermotcoll said:
                            Bytor
                            I see You don't make full detailed models of the furniture. Don't You use SketchUp to make cutlist?
                              dermotcoll
                              Hi Dedmin
                              I design and install but I buy in all the carcases. There are carcase companies who are much bigger machinery and I make money designing and installing - it would take me too long to cut, edge and assemble the carcases myself so I leave it to the big guys. All non standard items, I draw detailed working drawings for and either make them myself or again farm out to the big guys. Works well for me.
                                dedmin
                                I see - thanks. Here we are using melamine faced boards and also send cutlists to the big guys to cut the panels for us. But we need detailed models of the furniture to have exact dimensions of all the parts.
                                  Dermot, I did a very fast and dirty test, I added lights to the cabinets and kept the dark exterior. I think the cabinet lighting creates interest,
                                  I did a few texture changes, I hope this helps.
                                  Oh, I have a very feint line overlay.
                                    bytor
                                    Hi Dermot,
                                    Just want to say again what wondefully detailed models the cabinets are. Here is both the unaltered render I left in the cooker overnight and while at work today (17.5 hrs total). Also - a second with a slight line overlay - I think it really punches out the details in the cabinetry. Finished model is on it's way via email - too big to post here. Let me know if you have any questions with what I did.
                                    Thanks,
                                    Bytor
                                      Dean, that looks great.
                                        bytor
                                        Thanks Pete! I really love Twilight and how easy it has made using the Kerky engine right inside SU. โ˜€
                                          dermotcoll
                                          Dean
                                          That is fantastic. Really love the line overlay - Pete did something similar on his. How do you go about applying this overlay. Is it done in Photoshop or within the rendering package?
                                            Dermot
                                            Just export a line style of the model (turn shadows off) and in your image editor overlap the line export with the rendered image. I normally put the lines on top with a transparency (play around 'till you happy)
                                            Make sure to export the line at same aspect ratio as render (I normally render to my screen ratio then export the lines 2x that amount and reduce in PS to the same size as render as that will give sharper lines)
                                            • 1 / 3
