    Internal Kitchen Render - Twilight Easy Low+
    41 Posts 12 Posters 6.2k Views 12 Watching
    • L
      leminilab
      I think there's gotta be some absolute rule on how remote should a light source be from an object but unfortunately I've relied on experience so far... Try and place them slightly further from the ceiling in order not to get this halo.
      I've never used IES lights yet. I think they are physically accurate light presets from light manufacturers ๐Ÿ˜•
      You can download some presets here : http://www.mrcad.com/download-free-ies-lights/
      • "Live every day as if it were your last and then some day you'll be right."
      • "ThomThom rules!!!"
      • X
        xrok1
        nice one, about the lights, try to imagine a real fixture and where the bulb would be. usually about 6" below the ceiling. if you still get harsh lighting then dim the lights a bit, try again, repeat...
        as far as textures try this http://www.cgtextures.com/.
        if you remember my kitchen i beleive all the materials are SU except 1 or 2. but i do have the SU material bonus pack from here: http://sketchup.google.com/download/bonuspacks6.html i'd suggest to DL it. the component packs are good too.
        as far as your windows go i suspect you may have two layers, try only one. do you know about back faces? this could also be the culprit.
        PS you'll never get a great result until you start using the higher (unbiased) presets, i always use easy 09.
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
          Hi Dermot,
          Your burning the candle both ends. But definitely paying off, this looks great and i like the dark exterior.
          Thanks for sharing
          • EarthMoverE
            EarthMover
            Beautiful modeling my friend. Cabinetry looks great. Not digging the floor though. Looks old and worn out.
            One thing you may want to consider is switching the Camera to Two Point Perspective before you render and this will straighten out your vertical lines.
            Content Creator at Skapeup
            • dermotcollD
              dermotcoll
              Thanks for the comments guys
              I tried a few changes as per your suggestions - can't get IES to load - when I go into it to load the ones leminilab suggested it still greys out and I cant load any to try them.
              System crashed a couple of times on me as well as I dont have a great processor for the bigger models and it is struggling big time with it. I have another in the oven as we speak and I will post the results when its finished. Anyone any tips on this IES problem?
              When you burn your arse - you gotta sit on the blisters!!
              • EarthMoverE
                EarthMover
                Did you try the collection Frymoro posted on the Twilight forum? Should be able to copy and past lights right from the attached .skp file.
                spotlight IES.skp
                • dermotcollD
                  dermotcoll
                  Thanks earthmover -
                  I had just about given up when I noticed a tab (From scene) which I hadnt touched before. I was able to upload an Ies file and am looking forward to seeing what comes out - I have set it for Easy Low + just to see what effects have been generated by the changes made then I will cook it over night on Interiors 09.
                  • dermotcollD
                    dermotcoll
                    Hey Guys
                    This is taking for ages in the low+ setting - ray tracing is only at 24% after and hour - should this take this long at such a low setting?
                    • soloS
                      Wanna upload the model, so that I can test on my side?
                      • B
                        bytor
                        Hi Dermot,
                        Sometimes ies files do take a long time. While they can be the most accurate - it is often unnecessary. Here are a couple of very helpfull links from the Twilight site regarding lighting;
                        http://twilightrender.com/phpBB3/viewtopic.php?f=12&t=732
                        http://twilightrender.com/phpBB3/viewtopic.php?f=12&t=665
                        It took me a couple of read throughs to fully understand what they are saying - but these are great reference points.
                        With regards to the materials - remember you can use all of the Kerkythea materials in Twilight as well!
                        Bytor
                        Find the Cost of Freedom.....
                        • L
                          leminilab
                          Hi Dermot,
                          Have you tried just lowering your omni lights a little ? IES lights are very demanding which may explain your rendering time I think.
                          Maybe by just lowering your omni and removing the IES...
                          • dermotcollD
                            dermotcoll
                            Thanks for the comments and guidance guys. Here is the model (compressed) for you to look at and critique.
                            Catherine Harneys.rar
                            • B
                              bytor
                              Dermot,
                              Wonderfull model! I deleted the lights you had and added som recessed downlights and a fixture I found on the warehouse. I also adjusted some of the material settings and replaced the floor / counter materials. Hope you don't mind - but it was fun to work with someone else's model for an hour or so. Here is a quick npr style to show what I did. I already made some lighting adjustments and have one in the cooker for processing overnight.
                              Bytor
                              • dermotcollD
                                dermotcoll
                                Bytor
                                Thanks so much for the comments. Really love the NPR render finish- have tried to do that myself but didnt work so I didnt post. Can you re upload your finished model so I can see what you did and how you did it?
                                  dedmin
                                  @dermotcoll said:
                                  Bytor
                                  I see You don't make full detailed models of the furniture. Don't You use SketchUp to make cutlist?
                                  • dermotcollD
                                    dermotcoll
                                    Hi Dedmin
                                    I design and install but I buy in all the carcases. There are carcase companies who are much bigger machinery and I make money designing and installing - it would take me too long to cut, edge and assemble the carcases myself so I leave it to the big guys. All non standard items, I draw detailed working drawings for and either make them myself or again farm out to the big guys. Works well for me.
                                      dedmin
                                      I see - thanks. Here we are using melamine faced boards and also send cutlists to the big guys to cut the panels for us. But we need detailed models of the furniture to have exact dimensions of all the parts.
                                      • soloS
                                        Dermot, I did a very fast and dirty test, I added lights to the cabinets and kept the dark exterior. I think the cabinet lighting creates interest,
                                        I did a few texture changes, I hope this helps.
                                        Oh, I have a very feint line overlay.
                                        • B
                                          bytor
                                          Hi Dermot,
                                          Just want to say again what wondefully detailed models the cabinets are. Here is both the unaltered render I left in the cooker overnight and while at work today (17.5 hrs total). Also - a second with a slight line overlay - I think it really punches out the details in the cabinetry. Finished model is on it's way via email - too big to post here. Let me know if you have any questions with what I did.
                                          Thanks,
                                          Bytor
                                          • soloS
                                            Dean, that looks great.
                                            • 1 / 3
