    Looking to make a script, but dunno how.
    34 Posts 7 Posters 3.4k Views 7 Watching
      MartinRinehart
      Agamemnus,
      Having Chris Fullmer help you with Ruby programming is like having Roger Federer help you with your tennis. Beyond what money could buy.
      Sorry about the off topic stuff, but here's some more:
      @chris fullmer said:
      oh Gaieus, you can do it! Its not too late to build some way cool Gaieus Toolset for SU πŸ˜„
      Gaieus, Chris is so right! I'm working on my tutorial's Ruby half (yes, half!). See if you can read this script:
      # /t/stairs1.rb - a stairway in SketchUp Ruby Talk (aka SketchTalk)
      =begin
      The following bit of SketchTalk builds a 36"-wide stairway. Rise is 7 inches; run is 9. Built from 1.5" thick lumber. It has 15 steps. It has a 1.5 inch square banister on the left. The banister is supported by 1x1 balusters.
      =end
      require '/t/sketch_talk'
      n # my keyboard shortcut for File/New
      box [0,0,0], [36,1.5,0], 5.5 # riser
      box [0,0,5.5], [36,10.5,5.5], 1.5 # tread
      box [1.25,1,7], [2.25,2,7], 38 # ballusters
      box [1.25,5.5,7], [2.25,6.5,7], 38+(7.0/2)
      all # select all
      step = g 'step' # turn selection into a component named 'step'
      mc step, [0,9,7], 14 # Move/Copy, 14x
      box [1,0,36+7], [2.5,15*9,36+7+15*7], 1.5 # bannister
      I'll bet you can read that script. I'll bet you can't build the model half that fast any other way!
        agamemnus
        The first script is almost done. I have a few problems --
        1. I could not find a way to convert groups to components so I changed them to unique components and then changed the definition of THOSE to the randomly selected base component. Isn't there a more efficient way?
        2. I can't seem to convert the target groups to components fast enough -- I used 'if (current_entity.typename == "Group") // current_entity.to_component // end', but that only applies at the end of the script so I have to run it twice.. dunno how to make it convert instantly. Tried shoving "Sketchup.active_model.commit_operation" after and then converting the unique components to base components but it won't budge.
        3. When I do "@target_entities = target_entities", and I already had a non-empty @target_entities, am I leaking?
        4. (mini-gripe) The rand function is glitchy. Sometimes it gives several (3-4) repeats in a 90-size or so list, which has an incredibly low chance of occurring.
        require 'sketchup.rb'
        module Convert_objects_randomly
         @base_entities = []
         @target_entities = []
         def Convert_objects_randomly.choosebase
          @base_entities = Sketchup.active_model.selection.to_a
          if @base_entities.empty?
           results = UI.messagebox "Please select base groups and/or components first."
           Sketchup.send_action "selectSelectionTool;"
           return
         def Convert_objects_randomly.choosetarget
          target_entities = Sketchup.active_model.selection.to_a
           return
          if target_entities.empty?
           if @target_entities.empty?
           results = UI.messagebox "Please select target groups and/or components first."
           return
           target_entities = @target_entities
          target_entities.each do |current_entity|
           if (current_entity.typename == "Group") or (current_entity.typename == "ComponentInstance")
            current_entity.make_unique
            current_entity.definition = @base_entities[rand(@base_entities.length)].definition
        end #Convert_objects_randomly module
        Convert_objects_randomly_menu = UI.menu("Plugins").add_submenu("Convert Objects Randomly")
        Convert_objects_randomly_menu.add_item("Select base objects") {Convert_objects_randomly.choosebase}
        Convert_objects_randomly_menu.add_item("Convert selected to random base objects") {Convert_objects_randomly.choosetarget}
        file_loaded(__FILE__)
          agamemnus
          Thanks. I couldn't do it with "@module base_entities = '' "-- that gave me an error. I used " @base_entities = '' ". And looks like I need that " @base_entities ='' " or else something weird happens (maybe undefineds everywhere?) and the if statement for base_entities did not work. (it does now, of course)
          So now I have to figure out how to iterate through target_entities and convert each to a random base_entities ..
          There isn't a native function I could use?
          Edit: Figured it out mostly... See post 1 below.
          • Chris FullmerC
            #1 groups have the .to_component method that will turn them into a component. But it makes each group a unique component, because there is no built in way to determine if a group is an identical copy of another group. There is some work arounds that can be done on certain groups that are exact copies of another group, but generally speaking, groups can't be turned easily into a single component and instances.
            #2 - I'll have to look at later
            #3 - The @target_entities will hold its value until SketchUp is closed, after it is given a value once. So you should clear it after your script is run each time. Add a @taget_entities = [] to the end of your script. That is my gess as to what is happening.
            #4 - Yeah, that happens. Adam Billyard once took some time to explain about how random functions work in programming. It was eye opening....or rather, my eyes popped out from all the terms he used that didn't make any sense to me. But essentially random is a tricky thing to nail perfectly I guess.
            Sounds like its coming along well!
              agamemnus
              Well, I know that it holds its value -- that was a way to re-randomize if the user wanted to without selecting those same groups again. But, if I set @target_entities to something else and it (@target_entities) is already set to something, that won't cause a leak, right? (the array it was previously set to will be cleared from memory?)
              • Chris FullmerC
                Ahh, correct. If you set it to seomthing new, then it clears its old value.
                  Ruby uses garbage collection - so it keeps track of all the junk we throw about and sweeps it all away! πŸ˜„
                  • C
                    cjthompson
                    @agamemnus said:
                    1. I can't seem to convert the target groups to components fast enough -- I used 'if (current_entity.typename == "Group") // current_entity.to_component // end', but that only applies at the end of the script so I have to run it twice.. dunno how to make it convert instantly. Tried shoving "Sketchup.active_model.commit_operation" after and then converting the unique components to base components but it won't budge.
                    the reason why is because .to_component creates a new entity.
                    Try current_entity = current_entity.to_component.
                      Also .typename is very slow.
                      Instead of current_entity.typename == "Group" use current_entity.is_a?(Sketchup::Group).
                      http://forums.sketchucation.com/viewtopic.php?f=180&t=19576&start=0#p162235
                        agamemnus
                        Thanks guys. Got myself two more issues now, though. 😞
                        1. The code refuses to convert lines to groups!! (I have "current_entity = current_entity.add_group")
                        2. Is there any way to make a yes/no dropdown, and if not how do I change the size (width) of the inputbox text?
                         @base_entities = []
                         @convert_only_groupsinstances = true
                           return
                           return
                           return
                           if current_entity.is_a?(Sketchup;;Group)
                           elsif current_entity.is_a?(Sketchup;;ComponentInstance)
                            current_entity = current_entity.make_unique
                           else
                         def Convert_objects_randomly.settings
                          if (@convert_only_groupsinstances == true)
                           default = "yes"
                          else
                           default = "no"
                          settings_query1 = inputbox(["Convert only groups/components to base objects?"],[default],"Convert Objects Randomly Settings")
                          if (settings_query1[0] == "yes")
                          else
                           @convert_only_groupsinstances = false
                        Convert_objects_randomly_menu.add_item("Settings") {Convert_objects_randomly.settings}
                          Check the API on that method. It only belongs to Entities collections. Not single Entity
                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entities.html
                          @agamemnus said:
                          1. Is there any way to make a yes/no dropdown
                          Check the second example in the manual:
                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/ui.html#inputbox
                            MartinRinehart
                            @agamemnus said:
                            Ok, thanks. How do I convert an entity to an entities collection?
                            You don't. Use an entities collection returned by the entities method:
                            Sketchup.active_model.entities
                            myGroup.entities
                            someComponent.entities
                              agamemnus
                              Edit: The textbox width is still really long, even with the dropdown now...
                                agamemnus
                                > myGroup.entities
                                But I can't... it's not a group or component. It's a line.... tried "current_entity = current_entity.entities", no go.
                                  You can't convert any raw geometry to a Group.
                                  But...
                                  my_group=model.active_entities.add_group(my_line)
                                  might work if the line has no face etc, then
                                  my_instance=my_group.to_component
                                  my_definition=my_instance.definition
                                  Otherwise clone the line into a group and leave the original alone with
                                  my_group=model.active_entities.add_group()
                                  my_group.entities.add_line(my_line.start.position,my_line.end.position)
                                  which recreates the line inside the new group...
                                    agamemnus
                                    Ugh. Maybe it's just better to use Chris's unsorted geometry->groups script first. πŸ˜„
                                      agamemnus
                                      Okay, script 1 is finished. It could use some expansion though, possibly. (eg: (1) convert areas instead of just lines, groups, and components [hard] and (2) don't make identical unique components as options [very doable, but might not be worth it]) The only real problems now are cosmetic:
                                      1. I am not sure that "Convert objects randomly" is a very good name for the script. I can't think of anything else that is both short and also semi-self-explanatory, though.
                                      2. The dropdown in the "options" is too big! I don't know how to set its width.
                                      Code:
                                      # "Convert objects randomly" script
                                      # Released into the public domain by Agamemnus.
                                      # Version 1; November 10, 2009
                                      # Contact the author; sketchup at flyingsoft dot phatcode dot net
                                      # Purpose;
                                      #     Easily converts a set of objects (target) into another set (base) randomly,
                                      # distributed amongst members of the base set.
                                      # Use;
                                      # 1)  Select a set of objects -- currently only components and/or groups work.
                                      # 1b) Pick "Select base objects" in "Plugins">"Convert Objects Randomly".
                                      # 2)  Select a target set of objects -- currently only components, groups, or lines.
                                      # 2b) Pick "Convert selected to random base objects" in "Plugins">"Convert Objects Randomly".
                                      # 2c) Done! You may pick "Convert selected to random base objects" again if you wish --
                                      #     your previous base and target object sets apply if you did not fundamentally change
                                      #     (explode, convert to group, etc-- geometry editing is fine) the target components.
                                      # 3) Set "Plugins">"Convert Objects Randomly">"Settings">"Convert lines to base objects?" to "YES"
                                      #    if you want ungrouped lines in the target set to be affected. Set "NO" otherwise.
                                      #    The default is "YES".
                                      # Behavior of result objects in version 1;
                                      # If the picked "base" object is a group, the target object is converted into a unique component.
                                      # If the picked "base" object is a component, the target object is converted into a component
                                      # instance of that component type.
                                      # ==Miscellaneous Notes;==
                                      # 1.) Much thanks to the Sketchup forum regulars in helping with problems in this script.
                                      # 2.) Looking for Work ;(
                                      # ...in the fields of;
                                      # economic analysis
                                      # business strategy
                                      # marketing
                                      # UI design
                                      # web based programming
                                      # 2D visual art
                                      # 3D visual art.
                                      # general programming.
                                      # M.A. in International Economics and Finance at Brandeis IBS, BA in economics at Brandeis IBS and Brandeis University.
                                      # 16 years of experience in amateur programming in BASIC-based languages (Basic, Freebasic, VB, etc.)
                                      # Several years of experience in PHP and Javascript. Experience in C-LISP, Matlab, and "some"
                                      # experience in Ruby (eh!) and C.
                                      # Work environment must at a _minimum_ contain penguins performing tricks, live.
                                       @base_entities = []
                                       @convert_lines = true
                                         return
                                         return
                                         return
                                         elsif (@convert_lines == true)
                                          current_entity = Sketchup.active_model.active_entities.add_group(current_entity)
                                         default = "yes"
                                        else
                                         default = "no"
                                        settings_query1 = inputbox(["Convert lines to base objects? "],[default], ["yes|no"], "Convert Objects Randomly Settings")
                                        else
                                         @convert_lines = false
                                        agamemnus
                                        Here is a file with both scripts (random color and object), and another file that shows the result of using SketchyPhysics 3, these two scripts, and Chris Fullmer's "Scale and Rotate Multiple" and "Loose Geometry to Groups" scripts. (Gems are from the 3D Warehouse)
                                        So now ... what if I wanted to make the result groups instead of component instances? So far the script is only converting everything to unique component instances and changing the definition. Ideally I want to just change the geometry of the groups without making unique component instances. So, assuming I could do one of these, which one is more efficient (faster), and can I even do any of these (and how) --?
                                        1. Convert "target" objects to component instances based on "base" objects, then convert "target" objects back to groups and delete the components.
                                        2. Convert "target" objects straight to groups based on "base" objects.
                                        (If anyone thinks my question is unclear I would rephrase it.. I needs answers! πŸ˜„ )
                                        convert_objects_randomly.rb
                                        rock test.skp
                                        • Chris FullmerC
                                          A few things. I'm getting errors when I try to run the script. I have not looked at all the code, so I'm not sure what I'm doing wrong yet. But, I'll try to look it over tonight.
                                          I'm also not entirely sure what your questions are about groups and components and component instances. Maybe it will make more sense when I get the script to run all the way through. I'll try to get back to this in a few hours,
                                            agamemnus
                                            I don't know why you are getting errors. I am not getting any errors. I did not use any globals AFAIK, so that can't be it. No idea.
                                            I'll try to rehash the question. I'm trying to convert the "target" objects into "base" objects but so far the only way to do that is to convert the "targets", if they are groups or lines, to new/unique component instances and then change the definition of that instance. Instead, I would like to either change the unique component instances back into groups (and delete the component definition), or to simply change the objects right away into groups, depending on whether any of these methods are possible and which one is faster. (see "Convert_objects_randomly.choosetarget_changeobjects")
                                            • 2 / 2
