    Tangent lines
    4 Posts 4 Posters 524 Views 4 Watching
    • N Offline
      nuclearmoose
      Given that SU doesn't draw a true "circle", I'm confused as to how to draw tangent lines between two circles or two arcs. I'm doing some design work on wood toys, and I have to admit I'm flustered about drawing simple arcs to illustrate rounded corners. All of my planning and design work is done in 2D at the moment.
      • massimoM Offline
        massimo Moderator
        Take a look at this thread nuclearmoose.
        • Jean LemireJ Offline
          Jean Lemire
          Hi folks.
          Alternatively, you can use pure SU without any plugin.
          I already answered a question similar to this one in the past with the following procedure:
          1 - Use a geometry book. If not available or do not contains this information, search the web with the string "line tangent to two circles".
          2 - When you find a page with an explanation like the first one returned by Google at
          Common Tangents to Two Circles: First Construction
          Common Tangents to Two Circles: simultaneously inflating and deflating the circles
          (www.cut-the-knot.org)
          Reproduce the steps using SU.
          Just ideas.
            My TrueTangent Tools do indeed repeat the manual steps set out as Jean describes... They just do it easier for you... πŸ˜‰
