    How to read the windows registry?
    18 Posts 7 Posters 15.5k Views 7 Watching
      Seems that the Win32 module already got some wrappers for the registry: http://ruby-doc.org/stdlib/libdoc/Win32API/rdoc/classes/Win32/Registry.html
      • W Offline
        Whaat
        Aha...I recently came across that too, Thomthom! I think that 'registry.rb' is the ticket. While it is part of the Win32 API, it looks quite simple to use. Thanks!
        • Chris FullmerC Offline
          Dale I recently tried to include the registry.rb and ran into problems. Probably not due to Ruby or SU, but just because I didn't know what I was doing. So I would be interested in what you do to make the registry.rb file work. I felt like there was some circular "require"ing going on, and I never quite figured it out. So if you do, I'd like to know how to do it please. I am looking at writing a script that needs to access the registry. Thanks!
          • W Offline
            Whaat
            Ok, I am successfully reading the windows registry. However, I have run into a roadblock on Windows Vista systems. It seems as though Vista prevents access to reading the registry unless you are logged in as an administrator. ๐Ÿ˜ก
            If anyone knows how to get around this issue, please let me know!
            This is the code I am using:
            require 'Win32API'
            require 'registry'
            Win32;;Registry;;HKEY_CURRENT_USER.open('Software\Glare Technologies\Indigo Renderer') do |reg|  #this line works fine...
            	reg_typ, reg_val = reg.read('InstalledVersion')  #...but this line fails on Vista only.
            	return reg_val
              Are you an 'Administrator' ? See Vista Users C'Panel...
                remus
                Not going to work for a lot of users, though.
                  Unfortunately, if you are not 'the' [or 'an'] Administrator then Vista is a pig ! SUp Ruby has built-in read/write registry methods, BUT often you can't write stuff that gets kept as SUp reverts on close...
                  Sketchup.read_default("section","variable","default") Sketchup.write_default("section","variable","my_value")
                  Have limited uses...
                  You can also use external .bat or .cmd files to do stuff to the registry but again you could be prompted as user...
                    > require 'Win32API'
                    > require 'registry'
                    > 	return reg_val
                    > end
                    Did you ever find a solution for that?
                    Is it for any value you try to read? Any part of the registry? Or the specific part you tried to read? Maybe it was due to the permission set by the application that wrote the keys.
                      Where did you get the registry.rb?
                        If this is a PC based tool then why not write a separate short batch file that examines the registry and then writes its findings to a temp file. You can run the xxx.bat file using UI.openURL("pathtoBATfile") and then read its temp file, then delete it to tidy up...
                          So if you wanted to use the registry, did you copy the file from a standard Ruby installation? I extracted one from an 1.8.0 Build 10 package.
                          I then managed to access the registry - but how would you package your plugin? What if other plugins also need registry access? Should I modify the registry.rb and wrap the code into my own namespace?
                          Or would it be fine to load only if Win32::Registry isn't defined?
                          require 'C:\ruby\lib\ruby\1.8\win32\registry.rb' if defined?(Win32::Registry).nil?
                          • RunnerPackR Offline
                            RunnerPack
                            Why not just use a plain-text configuration file located in your plug-in's ".../Plugins/pluginname" folder. You could use INI, XML, JSON, RON, etc.
                            This would have the advantages of working on both Vista and OSX transparently, and it would probably be more powerful and easier to implement, to boot.
                            As a long-time Windows user, I think the registry was a terrible idea that was also quite poorly implemented. I understand that it was designed to make the job of administrators of large corporate networks easier, but as an individual computer user, I tend to prefer programs (and plug-ins ๐Ÿ˜‰ ) that use a human-readable ini file of some kind.
                            You might have noticed... I'm a bit of a ferpectionist.
                              In my case I'm reading registry info of an application - not trying to store my settings.
                              • Al HartA Offline
                                Al Hart
                                This ruby uses Win32API to read the registry, and works on Vista.
                                But it may not work if you are not an Administrator (who knows).
                                It is looking for the entry:
                                HKEY_LOCAL_MACHINE\SOFTWARE\Render Plus Systems\IRender_nxt_location
                                So you will have to change it to the registry key you are looking for.
                                class Your_class
                                	def self;;get_reg_functions
                                		@@RegCloseKey = Win32API.new('advapi32', 'RegCloseKey', 'L', 'L') if @RegCloseKey == nil
                                		@@RegOpenKeyEx = Win32API.new('advapi32', 'RegOpenKeyEx', 'LPLLP', 'L')  if @RegOpenKeyEx == nil
                                		@@RegQueryValueEx = Win32API.new('advapi32', 'RegQueryValueEx', 'LPLPPP',	'L') if @RegQueryValueEx == nil
                                		#@@RegCreateKeyEx = Win32API.new('advapi32'', 'RegCreateKeyEx', 'LPLLLLPPP'   'L')
                                	end#def
                                	def self;;get_registry_entry(key, sdefault = "")
                                		#trace("key; %s",key)
                                		get_reg_functions
                                		key.tr!('/','\\')
                                		sret = sdefault
                                		# strip of section
                                		spos = key.Find('\\')
                                		if (spos < 1)
                                			do_error("Cannot parse registry key %s - Key must contain a backslash\n",key)
                                			return(sdefault)
                                		end#if
                                		firstpiece = key.Left(spos)
                                		mainkey = key.Mid(spos+1)
                                		if (firstpiece == "HKEY_LOCAL_MACHINE")
                                			root = HKEY_LOCAL_MACHINE
                                		elsif (firstpiece == "HKEY_CURRENT_USER")
                                			root = HKEY_CURRENT_USER
                                		else
                                			printf("Registry key must start with HKEY; %s",key)
                                			return(sdefault)
                                		end#if
                                		# strip off final key
                                		spos = mainkey.ReverseFind('\\')
                                		if (spos < 1)
                                			printf("Cannot parse registry key %s - Key must contain a backslash\n",key)
                                			return(sdefault)
                                		end#if
                                		lastpiece = mainkey.Mid(spos+1)
                                		mainkey = mainkey.Left(spos)
                                		phkey = [0].pack('L') # a 4 byte string of 0's go get handle
                                		ret =  @@RegOpenKeyEx.call(root, mainkey, 0, KEY_READ, phkey)
                                		printf("ret; %s mainkey; %s\n",ret,mainkey)
                                		if (ret != 0)
                                			printf("key not found; %s\n",key);
                                			return(sdefault)
                                		end#if
                                		hkey = phkey.unpack('L').first # convert stron pointer to integer
                                		# create a buffer for the result
                                		buf  = 0.chr * 1024
                                		size = [buf.length].pack('L') # store size of buffer
                                		ret =  @@RegQueryValueEx.call(hkey, lastpiece, 0, 0, buf, size)
                                		if (ret != 0)
                                			printf("location not found; %s\n",key);
                                			return(sdefault)
                                		end#if
                                		# if ret == ERROR_MORE_DATA, then we should call again with a larger buffer
                                		@@RegCloseKey.call(hkey)
                                		sret = buf.nstrip	# stop at 0 byte
                                		printf("sret; %s length; %d key; %s\n",sret,sret.length,key)
                                		return sret
                                	end#def
                                	# this returns the location without a slash
                                	def self;;find_application_folder(smodule)
                                		#skey = sprintf("HKEY_LOCAL_MACHINE\\SOFTWARE\\Render Plus Systems\\%s_location", smodule)
                                		skey = sprintf("HKEY_LOCAL_MACHINE/SOFTWARE/Render Plus Systems/%s_location", smodule)
                                		sloc = get_registry_entry(skey)
                                		printf("sloc; %s from skey; %s\n",sloc,skey)
                                		if (sloc && FileTest.exists?(sloc))
                                			sloc.tr!('/','\\')
                                			#printf("RETURNING 1 sloc; %s\n",sloc)
                                			return(sloc) if sloc != nil
                                		end#if
                                		printf("Registry entry not found; %s\n", skey)
                                		return nil
                                	end#def
                                end#class Your_class
                                Your_class;;find_application_folder("IRender_nxt")
                                read_registry.rb
                                Al Hart
                                IRender nXt from Render Plus
