    1.5k Posts 478 Posters 4.3m Views 478 Watching
    • B
      Blackpercula
      Thank
      • H
        hamster3
        Fredo, you make sketchup to become perfect!
        Thank you! 😍
        • fredo6F
          [Upgrade 08 Oct 09] RoundCorner 2.1c
          Documentation translated to French by Christophe Plassais(the plugin itself was already available in French) and plugin translation to Spanish by Gaonirico.
          See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&st=0&sk=t&sd=a#p171721
          • jeff hammondJ
            can't believe i missed this update..
            great work once again fredo!
            thank you
            • EarthMoverE
              EarthMover
              Fredo...small request for a perfect plugin. In the next release, might you consider and option to drag out a visual offset? i.e. if I have a cube and want to round the corners, I could click on a corner and drag down the offset visually as you would the standard offset tool. With irregular shaped objects, I find myself entering 3 or 4 dimensions manually until I find one that doesn't overlap in tight corners and create a hole. If I could dynamically pull out the offset, I could see how far the offset could be before running into issues. Just a suggestions. Like I said...really just the perfect tool all the way around.
              Content Creator at Skapeup
              • jeff hammondJ
                you fixed sketchup! πŸ˜„
                prior to this script, if i needed a corner to look like the one on the left (and i need them often), i had to draw it manually and while not incredibly difficult, it's certainly a waste of time.. SU+ follow me can't do it right..
                RoundCorner on the left -- SU on the right
                when doing a corner which has a top radius looser than the profile radius... SU/follow me & RoundCorner produce the exact same results which are incorrect but i can deal with it a little easier..
                the transparent planes show where the hidden lines should be.. the attached skp shows another problem as well.
                RoundCorner & SU/follow me
                of course, i'm using this plugin for an application far from its intent and i'm not asking you to try to fix this or anything... just pointing out a sketchup error that you happened to halfway fix..
                thanks man -- great plugin here.
                roundedge.skp
                • fredo6F
                  Visual dragging was in my plan but is stuck with many other things I need to do on this plugin (non-uniform offset, custom profiles) and other plugins. I should also add a detector of holes and overlaps.
                  So point noted.
                  • plot-parisP
                    plot-paris
                    cool! are we going to get christmas presents? πŸŽ‰ ... πŸ˜„
                    • FletchF
                      Fletch
                      I just have to say that the more I use this plugin, the more amazing it becomes, it's simply one of my favorite plugins ever written for SketchUp.
                      http://twilightrender.com/phpBB3/images/smilies/Respect.gif
                      My favorite part is the little toolbar that pops up with buttons and options on it, and that I can save 2 presets that I commonly use.
                      http://twilightrender.com/phpBB3/download/file.php?id=1547
                      Fletch
                      • boofredlayB
                        boofredlay
                        I agree. It is one of my most used scripts as well.
                        • plot-parisP
                          plot-paris
                          one of the most useful plugins indeed. especially when it comes to rendering, its so easy to add detail...
                          cool, didn't notice that one. must have been blind! "doh"-moment
                            Jackson
                            Just stumbled upon this amazing script- in common with Fredoscale, I'm stunned by its usefulness and intuitiveness- what an excellent UI. These two scripts (and Subsmooth & Divide) have completely transformed SU from orthogonal GE plaything into an organic surface modeller sufficient for most architects' needs. This is a simply stunning ruby, thank you, thank you, THANK YOU! Second donation on it's way as soon as pay day arrives! πŸ˜„
                            Where did that "We're not worthy" smiley go to?
                            Jackson
                            • fredo6F
                              Jackson,
                              Thanks to you (and others) for your warm appreciation of the plugin. I am glad to see that it is useful in production work.
                              If you see things missing or inacurate, do not hesitate. RoundCorner is a recent script, where I am able to make evolutions.
                              • G
                                Gruff
                                Thank you Fredo. Sweet and complete. β˜€ (I won't beg for variable radius fillets... Yet. πŸ˜„ )
                                It hanndles most of what I can throw at it cleanly.
                                Huge boost for SU.
                                ~Gruff
                                Resistance is .... Character Forming. Grin
                                  Ruturaj
                                  Hi, πŸ˜‰
                                  I'm very happy..........
                                  Thanks you very much πŸ˜„
                                  Good job πŸ‘
                                  Thanks,
                                  RuturaJ
                                    arturmercurio
                                    Hi guys it my first time posting in this forum. I am having issues with RoundCorner 2.1. To start, i have added the plugin that is necessary for RoundCorner to work (LibFredo6). And until now i have not been able to find a link to download RoundCorner 2.1a. I am a mac user working with Sketchup 7.1. If someone can give me some direction i'd much appreciate it. The RoundCorner plugin looks good.
                                    Artur C
                                      At the bottom at the very first post in this thread. Make sure you go to the first page of this long thread.
                                      • fredo6F
                                        [Chinese version - 11 Nov 09 - 21:50 CET
                                        Diweiman and the SuBAR_CLT team at SketchupBar have translated the script into Chinese.
                                        See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&p=171721#p171721).
                                        • utilerU
                                          utiler
                                          Fredo, is there a need for English users to update to this version?
                                          Thanks for your tireless and generous work....!
                                          Just Curious...
                                          • fredo6F
                                            Good question.
                                            The answer is NO. The script is the same. The Chinese translation is contained in the separate .lang file (as for all other languages).
                                            • 74
                                            • 75
                                            • 7 / 75
