    [Plugin] FreeDXF Importer
    148 Posts 41 Posters 209.3k Views 41 Watching
      remus
      Good idea im. I can see a lot of demand for this when 8 comes out.
        Is not an hard work for an aging format?
          Ageing format, but still in use. Just look at the .3ds format - blasted thing is still around.
          Nice list of specs you found there Jim. Are you writing against the 2010 version?
          • G
            Gruff
            I'd recommend writing it to the earliest version of DXF that is still supported under 2010.
            One heck of a lot of users are still using 2006 and earlier.
            ~Gruff
            Resistance is .... Character Forming. Grin
            • T
              toxicvoxel
              Jim,
              Which DXF entity types do you aim to support eventually?
                ~Gruff
                hm... I could see the logic of that if you where writing DXF format. But we're talking about reading DXF format. I'd think that you'd want to be able to read recent formats.
                Is the DXF format constructed in such a way that parsing a DXF file with the newest spec will allow it to read older versions?
                • T
                  toxicvoxel
                  I haven't used a new version of AutoCAD for some time but historically solid objects where defined as encoded strings within the DXF export file, rendering it only partially 'open'. Not sure if this situation has changed but it may be a challenge to support all current AutoCAD entity types.
                  Has anybody explored the cost of using the libraries from the Open Design Alliance?
                  (http://www.opendesign.com/)
                    Jim
                    @toxicvoxel said:
                    Jim,
                    Right now, it has calls to handle: LINE ARC CIRCLE VERTEX SEQEND ELLIPSE BLOCK ENDBLK INSERT POLYLINE 3DFACE
                    Although some do not work properly. You may have noticed it creates an output file named freedxf_types.txt in your plugins folder. It is a breakdown of found and supported command blocks for the imported file for inspection, one per line.
                    I didn't look at all the version - I don't know what the difference is between them. I arbitrarily opened the 2000 version because it had online html and started coding. I don't think the format will have changed - i.e. the parser should be forward compatible. What may change is how each entity type is handled, or new types introduced. I'm probably wrong.
                    I'm not sure how useful it will be in the end. I hosted in on bitbucket to encourage hacking on it. If mercurial/bitbucket isn't your thing, I can do a git/github repo also.
                      In passing... I am working on a parallel DXF TEXT importer that imports any text/mtext/attributes in the DXF - as flat 3D text using the size, font, formating etc...
                      • T
                        toxicvoxel
                        Jim,
                        I think it would be imperative to support polyface meshes as minimal functionality for this plugin as so many formats export faces using this structure.
                        This would also potentially provide a logical optional construct to map against sketchup groups, which maps to blocks in the current importer/exporter.
                        Your efforts are appreciated.
                        • G
                          Gruff
                          No. Quite the reverse.
                          If we are only talking 2D/3D wireframe standard elements then I do not think it would be a problem. Getting into 3D Surfaces and Solids could very well be a version issue.
                          AutoCad typically allows you to save a DXF (or DWG) to 3 or 4 earlier versions of the file format.
                          If Jim's importer can only read 2010 DXF and I only have ACAD version 2004 then Jim's importer may be expecting data structures that simply do not exist in the 2004 version. I would not be able to use his utility.
                          If Jim writes his importer to read 2004 DXF files then someone with version 2010 of ACAD can always save his file to the older version for Jim's program.
                          Of course the smartest move would be to have his program read the version and use the appropriate version translator. But that is a tall order I think.
                            You say "may"... Have you studied the format? Or is it a guess?
                            I was thinking that it'd build upon the previous versions. That a 2010 reader would be able to read previous versions. Why would you extend a format such that it changes an existing implementation? That just seem to create more problems.
                            • G
                              Gruff
                              @thomthom said:
                              I have written translators for several CAD file formats and a few simple converters for DXF. Most recently a DXF exporter for Solidworks to SigmaNest. (Creating additional geometry not in SW on export)
                              It is the nature of file formats to evolve to support more features and to crop structures that are no longer necessary for the latest version. If I recall correctly AutoCAD version 1.0 came out in 1982.
                              DXF was defined sometime thereafter... 1984 or so. Quarter of a century would be a long time to remain backward compatible for a privately held file format. πŸ˜‰
                              As I said earlier though. If all Jim is going to support is wireframe then it shouldn't be an issue.
                              • honoluludesktopH
                                honoluludesktop
                                Hi Jim, Am watching this topic for your progress. Btw, I see that you bookmarked the html for Dxf definitions. I did the same thing until I realized "Dah!", that I could bookmark the pdf on line as well. Sigh, old habits die hard:-(
                                  Jim
                                  New Version 0.51
                                  • Improved ELLIPSE method
                                  • Added import of TEXT entities.
                                  See first post for download.
                                  1859.dxf
                                  1859.skp
                                    driven
                                    hi Jim,
                                    should it work on mac?
                                    trying to load your .dxf gives
                                    Error; #<TypeError; reference to deleted Group>
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/freedxf/freedxf.rb;466;in `transform!'
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/freedxf/freedxf.rb;466;in `draw_text'
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/freedxf/freedxf.rb;133;in `draw'
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/freedxf/freedxf.rb;92;in `main'
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/freedxf/freedxf.rb;91;in `each'
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/freedxf/freedxf.rb;91;in `main'
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/freedxf/freedxf.rb;503
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/freedxf/freedxf.rb;466;in `call'
                                    haven't time to look further at the moment, so thought I'd ask first.
                                      Jim
                                      Thanks, John. I started seeing that error too, although not everytime. It's really baffling because it appears to have started when I made some changes in what should be an unrelated method. I will trap the error, but I am still not sure what exactly is happening. There will be an update (or 2) today.
                                        Does bitbucket reflect the latest changes?
                                        I went looking at it to work out what it imported DXF TEXT entities as. Text entity in SketchUp?
                                          Ok - tried it out. I see the text comes in as simple geometry. Would be useful with an option to get the text as native Text elements. And/or when the text is imported as geometry, add the text value to an attribute so it can be read by other Ruby scripts.
                                            Does it handle units at all? Or does it assume inches?
                                            • 1 / 8
