    [Plugin] Q JS ALIGN TOOLBAR
    63 Posts 35 Posters 113.3k Views 35 Watching
    • CadFatherC
      CadFather
      @thomthom said:
      The bounding box' centre point is not the centre of that extruded triangle.
      Chris, it's the background colour throwing you off.. (must have been on purpose!)
      • Chris FullmerC
        OOooohhh! I get it. Yes, Cadfather is right, I could not see a 3d object there at all. I just saw the front, bright face.
        So yes thom, you're right. That construction point is not the center of the geometry. 😳
          thehe
          messing with your head! 😉 😄
          • I
            ideas_arte
            http://www.addemoticons.com/emoticon/animated/AddEmoticons0423.gif
            Nice...!
            Thank you very much...!
            • Bob JamesB
              Bob James
              @cadfather said:
              (tested only on PC - unzip the contents to your plugins folder)
              Works on Mac except the toolbar doesn't "stick" - have to use View/Toolbars each time SU loads.
              • CadFatherC
                CadFather
                thanks Bob - i hope someone with a mac will be able to fix this 😒
                • B
                  BTM
                  Just add this:
                  case gp_quarr_jsalign_tb.get_last_state when 1 gp_quarr_jsalign_tb.restore when -1 gp_quarr_jsalign_tb.show end
                  • utilerU
                    utiler
                    Thanks Coen, good tip. Could have used it last week while trying to flatten some survey dwgs.... 👍
                    Just Curious...
                    • CadFatherC
                      CadFather
                      That's great Coen, thanks..and it is really fast as well
                      • O
                        opla457
                        A big thank for this plugin, so great - the function sketchup messed !!
                        • jason_marantoJ
                          jason_maranto
                          Thank you both for this wonderful script -- something I've always wanted in Sketchup.
                          Best,
                          Jason.
                          • bagateloB
                            bagatelo
                            I change the plugin to show menus in "Plugins" Menu. Now we can set keyboard keys, is very useful to me.
                            I thought about a function of "smart drop" for all of the possible directions of the axis, like this, the aligned objects if they would not fix in the most distant part of the object of alignment reference, but they would collide in the surface. Look image example. It would be as the plugin drop, but it would work in all possible directions by axes(9 possibilities, or 6, if we not consider middle). Maybe some keys like SHIFT can change this behavior.
                            jsAlign.zip
                            • bagateloB
                              bagatelo
                              Two years later I had another idea. Could someone modify this script to reposition the axes of the selected objects? Maybe by pressing a modifier key on the keyboard, such as alt or shift.
                              • V
                                Vicspa
                                very useful plug-in, thank you 👍
                                • Bob JamesB
                                  Bob James
                                  There does not seem to be a way to select which object the others are to align with. I've tried selecting #1 first and then #2, but get the same result if I select #2 first then #1.
                                  It would be very helpful if you could effectively say "make the other(s)" align with "this one"
                                  • PixeroP
                                    Pixero
                                    The script was written to work like many 2d align functions. Aligning to min, max or center, but for each axis.
                                    My original script (without the toolbar has some added functionality like that you can choose "custom" and enter a value (position) in one axis and align to that. When using a group you can choose if the groups max, center or min should align to the value.
                                    Not exactly what your after but might be useful sometimes.
                                    Here is the original script (without toolbar).
                                    JS Align
                                    • P
                                      Prevayl
                                      This tool is very useful. i just have one suggestion and im not sure if it was already mentioned but do to busy schedule,forgive if this was already suggested.
                                      But an added feature That functions similar to illustrator would be great where you an evenly distribute the objects(groups) between a distance.
                                      For example In adobe illustrator you can create 10 boxes and align them to a straight line but then you can equally distribute the spaces in between them based on the box furthest to the left and furthest to the right.
                                      That feature would make it easy to create a patio for instance with a gap in between each 2x4 and have it evenly spaced
                                      • F
                                        function
                                        it was brought up about a week ago
                                        http://forums.sketchucation.com/viewtopic.php?f=323&t=36006
                                        I couldn't get d.bur's suggestion to distribute evenly, so I don't think it's been created yet- I am a huge fan of the adobe style align/distribute box, and I use the OP's mod all the time! Hopefully someone can complete the package sooner or later.
                                        remember you can distribute the same object by moving and typing '/#' in the dimension box
                                        on a side note:
                                        d.bur's align script wouldhowever be a fine addition to this toolbar pack, "Align Along Line" for when ortho just can't do it - 👍
                                        • F
                                          fatihbarut
                                          thanks alot
                                          I really needed this
                                          • F
                                            fatihbarut
                                            max
                                            can we arrange something like this
                                            align first clicked group/component to second one?
                                            Not moving the second one.
                                            Because otherwise it is really not possible to stay the things where they are and have to arrange the position of first and second object everytime we aling...
                                            • 2 / 4
