    New, free, product for parts list and reporting
    27 Posts 11 Posters 4.9k Views 11 Watching
    • Al HartA
      Al Hart
      I think if you can make it so that it can report on the DC attributes, that would be huge. As DC's get used more and more, there are is going to be a lot of data that you can pull from them.
      Sketchup's built in reporting function can pull all the data, but unless you are an excel whiz, its hard to make sense of it all....
      We are looking at including some dynamic component attributes.
      We downloaded this DC model:
      Error 404 (Not Found)!!1
      (sketchup.google.com)
      But when I try to get a report my machine just hangs.
      (The standard DC report on the SketchUp File menu)
      Can someone else try it.
      (I tried to make a report from the downloaded model - although it does seem to have an instance of the component. Perhaps I can only get a report after placing it in a different model???)
      Al Hart
      IRender nXt from Render Plus
      • W
        wmanning
        Hi Al,
        I downloaded the model, then opened it in SU 7.1 on the PC and used the SketchUp menu File - Generate Report feature. Saved as .csv and also as .html and had no problems. The files are attached in the .zip
        Seems to be OK on my machine.
        William
        DynamicStairCase.zip
        • Al HartA
          Al Hart
          Thanks. I'll try it again.
          The list of DC attributes - which you included in the ZIP file reports - was what I was looking for.
          I'll present the same list to the user and let then select which attributes they want to see on the report - rather than just showing all of them.
          Al Hart
          • W
            watkins
            Dear Al,
            How does your download work? I note that it is a .exe file. Does the installer put files in places other than in the plugin folder, and if so, is there an uninstaller?
            Kind regards,
            Bob
            • Al HartA
              Al Hart
              @watkins said:
              Dear Al,
              Kind regards,
              Bob
              The .exe is an Install Shield installation program.
              The installation puts just one .rb in the SketchUp plugins folder, and everything else is in Program files/Render Plus Systems/RpReports.
              There is an uninstaller which removes everything. The easiest way to uninstall is to run the installer again (uninstall and re-install are options the second time)
              Al Hart
              • W
                watkins
                Dear Al,
                Thank you for the explanation. It looks like a very useful plugin.
                Kind regards,
                bob
                • F
                  fountainhead
                  Hi Al,
                  Downloaded and really like the potential for this program. It would be helpful if, once the dialogue is created for all attributes pertaining to a component, that the order of creation would be maintained when you A) use the report function, or B) edit the attributes. The current method reorganizes all of the attributes alphabetically. Even after selecting an order of printing by rearranging the attribute list, once close the list resorts to alphabetical layout again. This is likely easily solved and would greatly simplify use. One could determine and assign attributes in the order expected to report them when creating, and then print or edit that user determined order as required. I think that would be a lot better than having to always rearrange everytime you want to print...
                  I would gladly buy the Pro Version when available.
                  • Al HartA
                    Al Hart
                    @fountainhead said:
                    Hi Al,
                    Thank you for your comments.
                    I am working on the new version - which will let you select dynamic components as well.
                    The new version will remember the attributes selected, and the order an headings for the report, when you reload the dialogs to create a new report. However, it will forget them if you close and re-open SketchUp. (The Pro version will have a save/load functions which saves attribute names, headings and report order for reports)
                    Al Hart
                    • F
                      fountainhead
                      Great! When do you anticipate the release of the Pro Version?
                      • EdsonE
                        Edson
                        al,
                        with all due respect for the work you have being doing for years and mindful of the free goodies you have posted here, to release any "windows only" software in 2009 does not seem to me an intelligent move businesswise. by doing so any company turns its back to and shuts the door on thousands of mac users out there, a fast-growing community. i myself would have bought almost all the applications you offer if there were mac versions of them and would certainly be followed by many of my students. it is saddening to see your company does not feel it is worth the effort to port them to mac.
                        i do hope you do not take my criticism the wrong way.
                        http://www.mahfuz.arq.br
                        • Al HartA
                          Al Hart
                          @edson said:
                          al,
                          As I said earlier in this thread, we have been begging SketchUp to offers us some help in learning how to make SketchUp version. (But with no success).
                          TDB offered us come clues - which is nice because he and I are competitors in some areas - So we have started some more Mac work based on his suggestions.
                          We have released at least one Mac product - RpWallMaker. And we plan to release both NprTools and SpaceDesign in Mac versions. So just be patient if you can.
                          However, I do think that releasing SpaceDesign, even without a Mac version, was not un-:intelligent". We have to do everything we can to keep our business propspering. Otherwise we won't be here to try to make new things in the future.
                          Al Hart
                          • P
                            peweuk
                            Al, is there any news about this report. (Apologies if I've missed any update notice).
                              dedmin
                              Seems that SpaceDesign doesn't support cyrillic characters
                              • Al HartA
                                Al Hart
                                We can probably fix that. (We have to do special processing on characters to get SketchUp to store them properly as attributes on components.
                                Can you send a reply with some cyrillic characters in it, so I can paste them in and get them to work properly.
                                Thanks,
                                Al
                                Al Hart
                                  dedmin
                                  Thanks,
                                  Al
                                  Няма проблем - това е български език.
                                  Translate
                                  No problem - this is Bulgarian language.
                                  • 2 / 2
