    SketchUp 7.1?
    151 Posts 68 Posters 38.4k Views 68 Watching
    • JClementsJ Offline
      JClements
      @rickw said:
      @xrok1 said:
      There are very few plugins with near-universal utility, ...
      Yeah, my feeling about "Weld.rb" ... it has been around for long time now and it must be a fluke since its not in the core program. 😒
        Hehe...
        About two weeks ago, I started to teach SU in a special, afternoon class to secondary school kids. For the time being, without (almost) any plugins as the Program files folder is not accessible only for admins on their network and I didn't want to hassle with it (also, I believe that one needs to learn the basics first).
        Anyway, Weld was the only exception I asked the IT guys to install when they install SU on the computers. Yes, it IS part of the program (you just install it separately)
          anglaret
          Hello
          I read all the thread, and did not find notice of 2 problems we are having:
          • Selection is not good, it very often selects a group far from clik point, and other, I have
            sometimes to go very near lines to select one; clicking above does not select the upper line
          • Sometimes drawing a line create a moving line which go far from chosen end-point.
            Very annoying
            Marc
          • W Offline
            Wacov
            One problem I'm getting with selection is the material sampler. If you're anywhere near an edge, it'll give you the default material 😞
            • brodieB Offline
              brodie
              @anglaret said:
              Hello
                Very annoying
                Marc
              That sounds like a graphic driver issue. I had some random issues after downloading 7.1 as well. I don't think 7.1 necessarily works well with all the drivers that 7.0 did. I'd recommend updating to the newest driver and see what happens.
              -Brodie
              • arail1A Offline
                arail1
                Okay, I'll bite - what is Weld and what does it do?
                  d12dozr
                  Weld takes connected edges/lines and joins them into a polyline. If you then extrude the welded edges, the joints are smoothed. You can also use it to automatically close a face. You can get it here: http://www.smustard.com/script/Weld
                  http://goo.gl/f7ooYh
                  • F Offline
                    Fletch
                    I noticed the little selection square for the Eraser tool has not changed graphically, but seams to have "grown" so that it is not as accurate as it used to be... perhaps this is related to graphics card as mentioned. 😞 I find when I erase an edge that is near another edge but I don't actually touch the 'other edge'... both get erased anyway. I'm learning to overcompensate by zooming in to places to erase when I would not have had to zoom in previous version... small price to pay for much faster video performance 😄
                    Also, sometimes I notice the problem of drawing a line or copying something, it will look like it's locked onto the right point, say an endpoint... but will 'jump to some endpoint in the "background" instead of where it's showing locked onto in the preview of the point... so the line or object is not ending up being drawn in the right place. So, again, I'm just overcompensating by being 'extra' careful and 'taking no chances' when drawing, but again, a small price to pay for faster vid. performance.
                    Fletch
                    Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                      RickW
                      @gaieus said:
                      Hehe...Anyway, Weld was the only exception I asked the IT guys to install when they install SU on the computers. Yes, it IS part of the program (you just install it separately)
                      Okay, that clinches it. As soon as I am done with Repaint2, I'll need to carve out some time to work on Weld2... 😄
                      RickW
                      [www.smustard.com](http://www.smustard.com)
                        No Rick - that script does what it is for perfectly (unless you can get it to "recognise" exploded circle and arc entities and weld them back as such... 😒 )
                          JClements
                          Gai:
                          Now that would be wonderful.
                            anglaret
                            I notice that color selection from the drawing does not work regularly.
                            I am working in 2D and alt-click in paint select everything but the chosen square and do not recuparate the color from the square beside
                            Marc
                              a4chitect
                              Mouse clickpoint and selection offset - I have noticed the very same problem, at first I thought it was the mouse (reinstalled the drivers, switched mice, ...) problem persisted...
                              But since there is more of you complaining - I would like to add my complaints 😄
                              In SU 7.1 it is harder to select anything in the model, maybe it's just that it select things differently then before, and we'll get used to it, but after many hours of using SU 7.1 - it still feels weird. It feels like if you had to click not with the tip of the mouse cursor, but with the cursor 'body'
                                Speaker
                                I also have this issue in SketchUp 7, so perheps this problem is not caused by SketchUp.
                                http://www.youtube.com/user/latvietis1234
                                  remus
                                  ive seen that a few times myself, seems to only happen in certain models as far as i can tell.
                                  • broomstickB Offline
                                    broomstick
                                    can anyone tell me if 7.1 free version retains the 3ds exporting capability?
                                      remus
                                      i dont think the free version ever had 3ds export, might be wrong though.
                                        SU Free (any current or previous version) has never exported3DS.
                                        If you mean import, I think, yes but let a free user chime in first.
                                          d12dozr
                                          Yes, SU Free imports 3DS.
                                          • michaliszissiouM Offline
                                            michaliszissiou
                                            I agree, SU free, imports 3ds. If you know how to deal with 3ds, of course, (textures must be in the same dir with the 3ds, in some cases textures should have name with less than 8 letters). Its my usual work flow actually. http://forums.sketchucation.com/viewtopic.php?f=81&t=22686
                                            • 3 / 8
