    SketchUp 7.1?
    151 Posts 68 Posters 54.8k Views 68 Watching
    • brodieB Offline
      brodie
      @anglaret said:
      Hello
      I read all the thread, and did not find notice of 2 problems we are having:
      • Selection is not good, it very often selects a group far from clik point, and other, I have
        sometimes to go very near lines to select one; clicking above does not select the upper line
      • Sometimes drawing a line create a moving line which go far from chosen end-point.
        Very annoying
        Marc
      That sounds like a graphic driver issue. I had some random issues after downloading 7.1 as well. I don't think 7.1 necessarily works well with all the drivers that 7.0 did. I'd recommend updating to the newest driver and see what happens.
      -Brodie
      • arail1A Offline
        arail1
        Anyway, Weld was the only exception I asked the IT guys to install when they install SU on the computers. Yes, it IS part of the program (you just install it separately)
        Okay, I'll bite - what is Weld and what does it do?
          d12dozr
          Weld takes connected edges/lines and joins them into a polyline. If you then extrude the welded edges, the joints are smoothed. You can also use it to automatically close a face. You can get it here: http://www.smustard.com/script/Weld
          http://goo.gl/f7ooYh
          • FletchF Offline
            Fletch
            I noticed the little selection square for the Eraser tool has not changed graphically, but seams to have "grown" so that it is not as accurate as it used to be... perhaps this is related to graphics card as mentioned. 😞 I find when I erase an edge that is near another edge but I don't actually touch the 'other edge'... both get erased anyway. I'm learning to overcompensate by zooming in to places to erase when I would not have had to zoom in previous version... small price to pay for much faster video performance 😄
            Also, sometimes I notice the problem of drawing a line or copying something, it will look like it's locked onto the right point, say an endpoint... but will 'jump to some endpoint in the "background" instead of where it's showing locked onto in the preview of the point... so the line or object is not ending up being drawn in the right place. So, again, I'm just overcompensating by being 'extra' careful and 'taking no chances' when drawing, but again, a small price to pay for faster vid. performance.
            Fletch
              RickW
              @jclements said:
              Yeah, my feeling about "Weld.rb" ... it has been around for long time now and it must be a fluke since its not in the core program.
              @gaieus said:
              Hehe...Anyway, Weld was the only exception I asked the IT guys to install when they install SU on the computers. Yes, it IS part of the program (you just install it separately)
              Okay, that clinches it. As soon as I am done with Repaint2, I'll need to carve out some time to work on Weld2... 😄
              RickW
              www.smustard.com
                No Rick - that script does what it is for perfectly (unless you can get it to "recognise" exploded circle and arc entities and weld them back as such... 😒 )
                • JClementsJ Offline
                  JClements
                  Gai:
                  Now that would be wonderful.
                    anglaret
                    I notice that color selection from the drawing does not work regularly.
                    I am working in 2D and alt-click in paint select everything but the chosen square and do not recuparate the color from the square beside
                    Marc
                      a4chitect
                      Mouse clickpoint and selection offset - I have noticed the very same problem, at first I thought it was the mouse (reinstalled the drivers, switched mice, ...) problem persisted...
                      But since there is more of you complaining - I would like to add my complaints 😄
                      In SU 7.1 it is harder to select anything in the model, maybe it's just that it select things differently then before, and we'll get used to it, but after many hours of using SU 7.1 - it still feels weird. It feels like if you had to click not with the tip of the mouse cursor, but with the cursor 'body'
                        Speaker
                        I also have this issue in SketchUp 7, so perheps this problem is not caused by SketchUp.
                        http://www.youtube.com/user/latvietis1234
                          remus
                          ive seen that a few times myself, seems to only happen in certain models as far as i can tell.
                          • broomstickB Offline
                            broomstick
                            can anyone tell me if 7.1 free version retains the 3ds exporting capability?
                              remus
                              i dont think the free version ever had 3ds export, might be wrong though.
                                SU Free (any current or previous version) has never exported3DS.
                                If you mean import, I think, yes but let a free user chime in first.
                                  d12dozr
                                  Yes, SU Free imports 3DS.
                                  • michaliszissiouM Offline
                                    michaliszissiou
                                    I agree, SU free, imports 3ds. If you know how to deal with 3ds, of course, (textures must be in the same dir with the 3ds, in some cases textures should have name with less than 8 letters). Its my usual work flow actually. http://forums.sketchucation.com/viewtopic.php?f=81&t=22686
                                    • FletchF Offline
                                      Fletch
                                      Again, I'm thrilled with 7.1 - I'm on a laptop w/ junk graphics card and SU7.1 enables me to work in any model I have tried - impressive! (so I will never go back)
                                      but (there's always a 'but') one issue I have is pretty major for me in disrupting workflow... the Alt-Bucket sampler eye dropper. It USED to work fine. But NOW in 7.1 it seems to sample the edges or something. Who in the world ever wanted to sample the material applied to an edge? (Why can we even apply a mat to an edge anyway - that doesn't make sense to me either.)
                                      So, I know that when using Select Tool you want the 'dominant' choice to be an edge... very nice.
                                      But when using the Material Bucket Alt-click Eye Dropper tool... this should NEVER notice an edge... it forces me to zoom waayyyyyy in on materials on a face (like trying to sample the mat on a soffit, for example) much more than I had to in the past, I don't remember ever needing to zoom in at all in the past. This wouldn't be a major prob, but often you are in a particular camera position you don't want to get out of just to sample a nearby material... so this is one major wish of mine for next SU update... 7.1.1? 😄
                                      edit
                                      also, is it just me, or does the 7.1 distance sometimes come out funky? I mean, I used the move command and it said it was moving it 60 feet, but it actually was about 20feet... or I used the Extrude Line ruby and typed (1") but it extruded it about 10 inches... it's happened to me enough now that I'm actually getting a bit worried about it.
                                      Fletch
                                      • 8 / 8
