    Need help cutting a hole
    16 Posts 5 Posters 1.1k Views 5 Watching
    • dermotcollD Offline
      dermotcoll
      Hi Guys
      Need to cut a hole in the worksurface of a unit to show the sink bowls(3d warehouse item). I dont know where to go after a couplke of hours trying to find a solution.
      I have tried deleting the bottom surface, intersecting with model etc but I still cant get it to do what I need.
      Any ideas - Please??????
      When you burn your arse - you gotta sit on the blisters!!
        remus
        Have you got a pic showing what you want to achieve? i cat imagine a situation where intersecting wouldnt work πŸ˜•
          Hi, could you upload a pic of the worktop and sink? Even better the model itself so we can see your dilemma.
          Rich
          (Edit)
          Remus beat me to it, but like he said it should be straight forward
            Hi Dermot,
            For a successful intersection of the top, make sure that you are in the editing context of that entity in case it's a group/component. The intersection lines will be created in any case but only when you are "inside", will they actually affect your basic geometry (i.e. cut it).
            Of course, I am not sure this is the case with you but for a stab in the dark, I think it will do it.
              dermotcoll
              Sorry Guys - had to deal with two squealing kids and a dog there!!
              here is the pic
              Picture of sink unit
                Dermot,
                Gaieus seems to have solved your problem. Did you try it?
                  dermotcoll
                  I dont fully understand what he is telling me to do (my fault not gaieus!) Do I explode the top and then place the sink in position and intersect with model and then delete the sdurfaces marked by the intersection lines?
                    You can do that but you don't need to explode (if it's a group/component). Just place the sink, edit the top group/component (double click on it) and do the intersection "inside". Make sure to use "Intersect with model".
                      dermotcoll
                      Does it take a huge chunk of processing power to do this as my machine is struggling big time to cope with this intersect with model.
                        Well, you would only need to intersect the perimeter of the sink but as I see, when it's sunk into the top, there are lots of other edges being intersected.
                          dermotcoll
                          Thanks Gaieus & Rich
                          I finally got it - jeez but i'm slow at this!!! Pic to prove it!
                            Did it take a lot to clean up unwanted geometry?
                              dermotcoll
                              Quite a while - what I should have done was to put the unit / top on its own layer then when I needed to clean up just turned off the layer and I would have been left with all the unwanted geometry.
                              Thanks for all your help Gaieus
                                So what I would have done (provided you had the top as a separate group) is to
                                1. double click on the face of the top which should remain in place (this should select the face and both its external perimeter edges and the outer edges of the mess the sing made)
                                2. Copy it to the clipboard (Ctrl+C should do it)
                                3. now triple click everything and delete
                                4. paste in place what I need - the top with the clean hole in it.
                                  dermotcoll
                                  Cheers Gaieus
                                  I will try that in a later model - deadline looming large because of that last trainwreck!!!
                                  Thanks again
                                  • kmeadK Offline
                                    kmead
                                    This would be a case of think like a carpenter. The carpenter doesn't need the hole to exactly fit the sink, the sink just has to fit in the hole and since it has a return around the top edge, it will cover the parts of the hold that don't match the sink.
                                    The lazy man's way:
                                    First, hide the sink. Double click on the top until you get through the different groupings to where the top most surface is highlighted. Draw a rectangle on the surface of the top. Push pull the rectangle through the depth of the top. Turn on Hidden Geometry under the view Menu without exiting the sink top group, you will now see the ghosted view of the sink. Using the move tool or the push pull tool, move the sides of the hole until they are under the apron of the sink edge. Once that is done click out of the group, right click on the hidden sink and unhide it, turn off the hidden geometry under view and you are done. This uses very little geometry and represents what the carpenter will really do (they may put a radius in the corners but not always).
                                    Hope that was clear.
                                    I created Dilbertville, sorry about that...
