    Let's have a Hardware speed test for SU
    132 Posts 72 Posters 91.0k Views 72 Watching
      Still the same machine as here but with SU 7.1 now:
      • 3.0 GHz Dual core CPU
      • nVidia 9600 (1Gb) GPU
      • 4Gb RAM
      • Windows XP SP3 (32 bit)
        To me, the improvement in speed (with this test model) is very stunning:
      Shadows off
      Shadows on
      Interesting that no matter how many times I tried, the performance was better with shadows on. ๐Ÿ˜•
      (Of course while making the test with shadows on now, SU temporarily turns them off for increasing orbiting and such but still...)
        blajnov
        I had such result, without shadows and with shadows...
        • W Offline
          Wacov
          @wacov said:
          Using a Q6600 at 2.4GhZ, 4GB DDR2 RAM, and a GTX 295:
          Now, on SU7.1, using the same setup (At a higher resolution):
          That's a massive difference!
          The message? Get 7.1. NOW.
          • bazB Offline
            baz
            [/quote]
            The message? Get 7.1. NOW.[/quote]
            I got the message, wow!
            Baz
            shad off V7.0
            shad off, V7.1
              glenn
              Interesting test results:
              XP sp3, duo 2.8, 4gb ram, 8500gt 512mb
              Ran it with SU7.1, then saved it as SU6 and ran it with v6.4
              Glenn
                glenn
                hmmmm...I can't upload multiple images?
                ok, got it, sorry.
                • brodieB Offline
                  brodie
                  I got 21.1 fps with shadows off.
                  Computer specs are in my signature below
                  -Brodie
                    Glenn,
                    Now that's some impressive speed increase (of course, there areno textures in the model and such but still)
                    Brodie;
                    OK-ok... there are your computer specs but we don't know (just suspect maybe) what SU version you have!
                    • jeff hammondJ Offline
                      i didn't run this pre su7.1 but i'm willing to assume a huge difference since upgrading...
                      with an older quad mac..
                      with shadow ON:
                      shadows OFF:
                      • W Offline
                        Wacov
                        ๐Ÿ˜ฒ
                        Does SU run better on Macs? Or is it your RAM? Because... 150 fps... ? Wow...
                        • U Offline
                          Ultimatez 32
                          Here's something odd.....I tried the test on 2 models, one the test model and the other one my roller coaster model. Here's the result.....quite suprising:
                          coaster model
                          test model
                          The picture below shows my computer stats...... ๐Ÿ˜•
                          It's a laptop by the way
                          Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                            How about the video card and OpenGL hardware support ("acceleration" in Preferences > OpenGL)?
                              I got new Notebook so here's the results
                                @wacov said:
                                :shock:
                                i'm not sure because i've never used windows for comparison.. there was an export test around here a while ago in which the macs were able to export jpgs at more than twice the size as windows but other than that, i haven't seen anything alluding to SU being better with OS X..
                                in fact, there are often things i see that work on PCs that i can't do.
                                • F Offline
                                  francois le francais
                                  MY CONFIG : macbook pro - mid 2009 unibody 15" 4GbRam 512Mo 9600MGT HD500gb 5400rpm - snow leopard 10.6.1
                                  I ve run the cube test with each graphic configuration on the same machine running sketchup pro 7.0, and results are quite surprising :
                                  9400M : 5.336s - 27.4665s (shadows on) -- with SU7.1= 1.228 - 1.229(shadows on)
                                  9600M GT : 5.327s - 27,669s (shadows on) --with SU7.1= 1.324 - 1.225(shadows on)
                                  I've run the same test with my architecture diploma file (40000m2 hotel+parking+many cars+trees and textures = 4mb files)
                                  9400M : 6.572s - 99.579s (shadows on) --with SU7.1= 4.774 - 5.074(shadows on)
                                  9600M GT : 6.601s - 101.156s (shadows on) --with SU7.1= 5.034 -5.225(shadows on)
                                  That confirms my impression, I can't notice any difference between running sketchup with 9400 and with 9600. ๐Ÿ˜ž What do u think about that ? Could some mac users confirm these results ?
                                  And 7.1pro version is really impressive. ๐Ÿ˜
                                  related link (hardware recommendation) :
                                  http://forums.sketchucation.com/viewtopic.php?f=15&t=10750&st=0&sk=t&sd=a&start=285
                                    Pete
                                    Here are results form Macbook Pro 13"
                                    Strangely, I was getting 15-16 fps then I turned on shadows and it increased??
                                    • AnssiA Offline
                                      Anssi
                                      My results, first test with no shadows
                                      This one with shadows on
                                      • core i7-860, 2.8GHz
                                      • 8 GB memory
                                      • Nvidia QuadroFX 1800 graphics card with 768 Mb memory
                                      • 1080 x 1920 screen, SU maximized
                                      • Windows 7 Pro 64-bit
                                      • pyrolunaP Offline
                                        pyroluna
                                        sweet...
                                        and the GPU is an NVidia Quadro FX 770M... is that any good? ๐Ÿ˜†
                                        oh and with shadows off, the time was 1.141. Average frame=0.016 sec., 63.1 fr/s
                                          joppermann
                                          Ok. Not sure how to do screen shots but I will just give you the info.
                                          Without shadows.
                                          72 frames displayed in 3.420 seconds
                                          average frame = 0.047 seconds
                                          21.1 frames/second
                                          With shadows.
                                          72 frames displayed in 1.373 seconds
                                          average frame = 0.019 seconds
                                          52.5 frames/second
                                          AMD phenom II x4 black edition 3.0ghz
                                          8 gigs DDR2
                                          ATI HD4850 1024
                                          1920x1080
                                          win 7 64 home prem
                                          • V Offline
                                            Vicspa
                                            • 3 / 7
