    [Plugin] 2 Faces + Path ver. 1.5.
    72 Posts 48 Posters 80.1k Views 48 Watching
      @ Takesh san
      Did it have time-limit?
      No seems to works fine even today ๐Ÿ˜Ž
      Sorry for the model, it's just a test ๐Ÿ˜ณ
        There is a timer inside MAybe I am wrong but seems that is only if the calculate is too long for break it ๐Ÿ˜‰
        Get the current time of day.
        # set up an elapsed timer so we can calculate expected end time.
        iteration = [iteration.abs,@total].min # make sure we don't exceed the total count or have a value < 0
        pct = [1,(iteration*100)/@total].max # Calculate percentage complete.
        # round up to 1% if anything less than 1%.
        # start time, and that is the expected end time.
        end_time = Time.at(((((Time.now-@time1).to_f)/pct)*100 + @time1.to_f).to_i).strftime("%H:%M:%S")
        Maybe this makes conflict with your program?
        • N
          nankyo
          AMAZING ๐Ÿ™‚
          I was just waiting for something like that...
          it makes me feel i work with rhino ๐Ÿ˜„ ๐Ÿ˜ ๐Ÿ˜Ž
          • K
            kirill2008
            Guys, plugin is free and open sorce. The time when you'll become surfeited with it is actually the only time limit ๐Ÿ˜„
            It would be absurd to add time limit to open sorce script. Obviously ๐Ÿ˜„ so I'll try to find out what's the problem, I mean why it refused to work at the 8 of september.
            • jwlyon1J
              jwlyon1
              ๐Ÿ˜ฎ
              simply amazing. thank you very much!
              Macbook Pro/ iMac
              OSX 10.7.2 Sketchup 8
              rogue-z is here!
              • C
                chango70
                This is got to be one of the coolest plugins. It reminds of control curves on grasshopper. speaking of which i wonder when someone will make grasshopper for SU. I can always dream can't I.
                • N
                  notareal
                  While collecting parts of my yaw from the table I don't yet know where to use this... but seriously amazing.
                  • ElibjrE
                    Elibjr
                    Wow Krill. This looks amazing. With This you have turned a simple program into an amazing modeling tool. Thanks.
                    • FletchF
                      Fletch
                      Krill,
                      I am sitting in stunned amazement! You are smart, talented, creative, and just amazing.
                      Thank you for sharing โ—
                      Humbled,
                      Fletch
                      • jwlyon1J
                        jwlyon1
                        I discovered something and I am also having some problems...
                        First, here's a screenshot of my experiment file, I was looking at how the different orientation of the faces affected the outcome of the process. Interesting!
                        Screen shot
                        Now, I'm having some problems.
                        Won't work!
                        When I try to use the 2 Faces + Path plugin, it gives me an error: It is necessary to select two faces and one path curve.
                        As far as I can tell, I have (1) one curve and (2) two faces selected. The curve is made with two arcs, welded together with the weld.rb.
                        I've also attached the skp for this file. Any assistance would be greatly appreciated!
                        I forgot to add, it worked yesterday. Then today it stopped. I've reloaded the rb, but no luck. Here's a shot of it working yesterday...
                        Worked yesterday!
                        Goes with first Screen Shot
                        The file that won't work!
                        Macbook Pro/ iMac
                        rogue-z is here!
                        • JClementsJ
                          JClements
                          All I want to be able to do is produce Reduced Pipe Elbows; have the one surface scale to other along a radius (or another user created path) in EQUAL increments.
                          Unless I am misusing the options all I get is a contraction of diameters along the path which eventually get smaller than the diameter of the face at the other end of the path as shown below. This is not what I was hoping for.
                          Perhaps this not what this script is meant for. If not, could another script be developed that does equal incremental scaling? Perhaps only two options would be necessary, one to smooth the skin or not to smooth the skin.
                          The below image is what I'd like a blend along path to be capable of (I manually drew the elbow).
                          pathface.rb
                          Desired Result.skp
                          • simon le bonS
                            simon le bon
                            Dear Kirill,
                            Thank you so much for this fantastic tool:---- which certainly needs to be studied and tamed.. ๐Ÿค“
                            Cutting angles into the edges of a complex curved shape >>../" Yet we often need these kind of shapes whose section is in arithmetic progression along a path.
                            And the least we can say is that SketchUp is quite disarming to address this problem!"
                            But hopefully, we now have your 2Faces+Path to solve the problem pretty easily ๐Ÿ‘ ๐Ÿ‘
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Horny_2FacesPath7th.jpg
                            ๐Ÿ˜‰ simon
                            • U
                              urmomets
                              Nice ! Is there a way to download and try ?
                                dmatho
                                Yes, go to the first page, very first post.
                                Cheers,
                                . Diego .
                                  dylan
                                  Great Ruby, thanks Krill.
                                  People have been wanting this for a long time ๐Ÿ‘
                                  http://dmdarchitecture.co.uk/
                                  • P
                                    pr0bka
                                    Hey Kiril, didn't know where to post this so that it would be easier, so i thought id post on both.
                                    the 2 faces and path tool only works for faces along 1 path. is it possible to blend two lines (or splines) along a path ?
                                    heres an example.
                                    • CarrozzaC
                                      Carrozza
                                      Great ruby, Kirill!
                                        Kirill,
                                        Thank you for this plugin. It's very useful.
                                        I am having some problems with it, however. I've attempted to reproduce what you've shown in the last video for v1.4 with a circle, square and arc. I can get the geometry alright but I cannot get the front face color on the outside (short of opening the group, selecting the faces and reversing them the old fashioned way) nor can I get the color change from one end to the other as you did when you painted one face red.
                                        What am I missing? I did just install version 1.4 so it should be a fresh install of the plugin.
                                        Thanks again.
                                        Dave
                                        • ken28875K
                                          ken28875
                                          Hey! Seems a very strong and funny plug! ๐Ÿ˜Ž
                                          Very cool : result gives 3 groups in the same time ๐Ÿ‘
                                          Shell, faces and curves (curves not shown here)
                                          So you must move or hide / erase some of them for a render! โ˜€
                                          From ellipse to cross ๐Ÿ˜‰ (click the image)
                                          Salut Pilou,
                                          C'est genial ce que tu as fait.
                                          Can you please show us how you did it? I would like to see the different shapes and the curve.
                                          Merci beaucoup!
                                          Have a wonderful day.
                                          _KN
                                          Follow Your Dreams.
                                            An arc, an ellipse, a cross: when the drawing is made you can turn, move, scale original generators for explore variations ๐Ÿ‘
                                            Can't be more simple ๐Ÿ˜‰ A Crazzy plug! โ˜€
                                            Et voila ๐Ÿ˜Ž click image if scroll bar
                                            • 3 / 4
