    [Plugin] 2 Faces + Path ver. 1.5.
    72 Posts 48 Posters 78.8k Views 48 Watching
      accabrera
      Wow, I am gonna try it.
      It looks very interesting.
      Thanks.
      • takesh hT Offline
        takesh h
        It suddenly stopped working for me today, with SU6 and SU7.
        Whatever I select to start, it says "it is necessary to select two faces and one path curve", but I'm almost sure I'm doing it right, it was working for me beautifully till yesterday.
        Did it have time-limit? ๐Ÿ˜’
        • soloS Offline
          Strangely the same happened to me yesterday, just stopped working. I thought I'd forgotten how to use it but alas it was not, just stopped working.
            @ Takesh san
            No seems to works fine even today ๐Ÿ˜Ž
            Sorry for the model, it's just a test ๐Ÿ˜ณ
              There is a timer inside MAybe I am wrong but seems that is only if the calculate is too long for break it ๐Ÿ˜‰
              Get the current time of day.
              # set up an elapsed timer so we can calculate expected end time.
              iteration = [iteration.abs,@total].min # make sure we don't exceed the total count or have a value < 0
              pct = [1,(iteration*100)/@total].max # Calculate percentage complete.
              # round up to 1% if anything less than 1%.
              # start time, and that is the expected end time.
              end_time = Time.at(((((Time.now-@time1).to_f)/pct)*100 + @time1.to_f).to_i).strftime("%H:%M:%S")
              Maybe this makes conflict with your program?
              • N Offline
                nankyo
                AMAZING ๐Ÿ™‚
                I was just waiting for something like that...
                it makes me feel i work with rhino ๐Ÿ˜„ ๐Ÿ˜ ๐Ÿ˜Ž
                  kirill2008
                  Guys, plugin is free and open sorce. The time when you'll become surfeited with it is actually the only time limit ๐Ÿ˜„
                  It would be absurd to add time limit to open sorce script. Obviously ๐Ÿ˜„ so I'll try to find out what's the problem, I mean why it refused to work at the 8 of september.
                  • jwlyon1J Offline
                    jwlyon1
                    ๐Ÿ˜ฎ
                    simply amazing. thank you very much!
                    Macbook Pro/ iMac
                    OSX 10.7.2 Sketchup 8
                    rogue-z is here!
                      chango70
                      This is got to be one of the coolest plugins. It reminds of control curves on grasshopper. speaking of which i wonder when someone will make grasshopper for SU. I can always dream can't I.
                      • N Offline
                        notareal
                        While collecting parts of my yaw from the table I don't yet know where to use this... but seriously amazing.
                        • ElibjrE Offline
                          Elibjr
                          Wow Krill. This looks amazing. With This you have turned a simple program into an amazing modeling tool. Thanks.
                          • FletchF Offline
                            Fletch
                            Krill,
                            I am sitting in stunned amazement! You are smart, talented, creative, and just amazing.
                            Thank you for sharing โ—
                            Humbled,
                            Fletch
                            • jwlyon1J Offline
                              jwlyon1
                              I discovered something and I am also having some problems...
                              First, here's a screenshot of my experiment file, I was looking at how the different orientation of the faces affected the outcome of the process. Interesting!
                              Screen shot
                              Now, I'm having some problems.
                              Won't work!
                              When I try to use the 2 Faces + Path plugin, it gives me an error: It is necessary to select two faces and one path curve.
                              As far as I can tell, I have (1) one curve and (2) two faces selected. The curve is made with two arcs, welded together with the weld.rb.
                              I've also attached the skp for this file. Any assistance would be greatly appreciated!
                              I forgot to add, it worked yesterday. Then today it stopped. I've reloaded the rb, but no luck. Here's a shot of it working yesterday...
                              Worked yesterday!
                              Goes with first Screen Shot
                              The file that won't work!
                              Macbook Pro/ iMac
                              rogue-z is here!
                              • JClementsJ Offline
                                JClements
                                All I want to be able to do is produce Reduced Pipe Elbows; have the one surface scale to other along a radius (or another user created path) in EQUAL increments.
                                Unless I am misusing the options all I get is a contraction of diameters along the path which eventually get smaller than the diameter of the face at the other end of the path as shown below. This is not what I was hoping for.
                                Perhaps this not what this script is meant for. If not, could another script be developed that does equal incremental scaling? Perhaps only two options would be necessary, one to smooth the skin or not to smooth the skin.
                                The below image is what I'd like a blend along path to be capable of (I manually drew the elbow).
                                pathface.rb
                                Desired Result.skp
                                • simon le bonS Offline
                                  simon le bon
                                  Dear Kirill,
                                  Thank you so much for this fantastic tool:---- which certainly needs to be studied and tamed.. ๐Ÿค“
                                  Cutting angles into the edges of a complex curved shape >>../" Yet we often need these kind of shapes whose section is in arithmetic progression along a path.
                                  And the least we can say is that SketchUp is quite disarming to address this problem!"
                                  But hopefully, we now have your 2Faces+Path to solve the problem pretty easily ๐Ÿ‘ ๐Ÿ‘
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Horny_2FacesPath7th.jpg
                                  ๐Ÿ˜‰ simon
                                  • U Offline
                                    urmomets
                                    Nice ! Is there a way to download and try ?
                                      dmatho
                                      Yes, go to the first page, very first post.
                                      Cheers,
                                      . Diego .
                                        dylan
                                        Great Ruby, thanks Krill.
                                        People have been wanting this for a long time ๐Ÿ‘
                                        http://dmdarchitecture.co.uk/
                                          pr0bka
                                          Hey Kiril, didn't know where to post this so that it would be easier, so i thought id post on both.
                                          the 2 faces and path tool only works for faces along 1 path. is it possible to blend two lines (or splines) along a path ?
                                          heres an example.
                                          • CarrozzaC Offline
                                            Carrozza
                                            Great ruby, Kirill!
                                            • 2 / 4
